any downside to DCI in hot climate?
03-11-2014, 10:34 PM | #1 |
Rep 105
I live in Vegas and my car is my daily driver, seeing mostly commuter duty. I have the jb4 g5 and love it. I see that adding the BMS DCI increases whp and allows for using map 2 which results in further gains. This is very tempting but i am concerned about any downsides associated with the engine breathing much hotter underhood air while stuck in daily traffic with 115-degree ambient air temperature. I have read the testing done by burger, but that is testing of the car with airflow and under load, not sitting in stop-and-go traffic where heat soak is very real. Should I get the dci or is there a risk of shortening the life of my engine in this scenario?
03-11-2014, 11:05 PM | #2 | |
BimmerPost Supporting Vendor
24503
Rep 191,503
I have DCI on my car, you are free to try it anytime you like text me @ 702 494 9435
03-12-2014, 12:05 AM | #3 | |
Rep 423
03-12-2014, 12:12 AM | #4 |
Rep 385
IMO the BMS testing really leaves a lot unsaid.
I live in Arizona and def noted a difference in charge temps going between DCI and a Mr.5 intake. It was exactly how you stated; in traffic, stop and go, with 120* ambient. The testing done by BMS does not encompass these environmental conditions. On a hot day, engine warmed up from driving around a while, after idling just a few mins my charge temps were 185*. This didn't drop for a loooooong time, even once I got on the highway. I did just install the BMS cowl filters, which should help engine bay cooling. Otherwise the Mr.5 provided more resistance to heat soak. Cool day performance was great with both. |
03-12-2014, 12:14 AM | #5 | |
Rep 423
03-12-2014, 12:18 AM | #7 |
Rep 2,838
Drives: e92 335i, e34 525i & e60 530i
Besides JB4, do you have any other mods? FWIW, I have aFe dci and have no issues. Then again I have a FMIC, vented hood, and run e85. If you concerned about temps, you can try similar mods or meth.
03-12-2014, 12:36 AM | #8 | |
Rep 385
For me, on E50, it was worth going to the Mr.5 intake over the BMS DCI just due to heat soak of the engine back. At highway speeds there wasn't much of a difference at all, but def around town/stop and go traffic, which is common in phoenix, it was very noticeable. I recently switched back to DCI's as I'm targeting much higher boost and will be running vargas stage 2's soon. I'm hoping the cowl filters help with getting rid of heat. I also heat-tape wrapped my charge pipe, which did help a little bit. If you're using E85 it doesn't matter as much, or if you're spraying meth likewise. Either is fine. The BMS DCI's sound great and are cheap. Just in the dead of summer I get more performance out of my own Mr.5 version. |
03-12-2014, 08:06 AM | #9 |
Rep 6,478
It’s an intake…let’s not get too worked up over it. You are sending said air through a compressor and turbine wheel generating RIDICULOUS amounts of heat. The charge will see far more heat there than what it’s seeing at ambient engine bay temps. The strongest N54s on earth run open filter elements for the most part. If it’s good enough for Terry’s two singles, Tony’s 700+ WHP twins, Shiv’s 700+ WHP singles….it’s good enough for you and me.
E88 N54 Alpinweiss/Coral Red/Motiv HTA 3586r Tial .82AR/Other stuff...652WHP
F30 N55 XDrive EBII |
03-12-2014, 09:04 AM | #10 | |
Chief Executive
304
Rep 2,890
Drives: 2008 335xi 6spd Coupe
03-12-2014, 09:58 AM | #11 |
N54 E92
51
Rep 342
I run it and I feel it does increase IATs at low speeds, but the benefits exceed the heat issues imo. As 135Pats said... IATs are going to be high regardless on our setups. If I were you, I would consider running a solid methanol injection setup as well. It would give you a solid advantage in your environment. I just started running it, love it... no worries about summer IATs.
03-12-2014, 10:36 AM | #12 |
Rep 4,401
Drives: 2022 F97 X3M Comp LCI
reiterating what 135Pats mentions above, a proper FMIC will have a much larger benefit in lowering your IATs than the intake you choose.
BMW MY22 F97 X3MC LCI - CURRENT BUILD THREAD| Instagram: @danniexi
BMW MY16 F80 M3 - GONE BMW MY08 E92 335XI - GONE BMW MY06 E46 325XI - GONE |
03-12-2014, 12:59 PM | #13 | |||
Rep 385
I ran the tests, I saw the data, I can 100% tell you that an N54 in the dead of summer IN ARIZONA on a 335i with no cowl filter changeover will heat soak the shit out of the engine bay, and stay that way for a very long time. What do I mean by long? I mean 30 mins of highway driving for it to go "down" to 145* charge temps, while cruising. Your ecu IS pulling timing at those charge temps. You ARE making less power. I don't buy in to the normal "does this intake matter" 99% of the time. I don't think there is a huge difference. On a cool day, hell, even on a normal person's hot day, I think (based on my measurements) that the DCI is great -and it's a great value (what other intake cost $100 on a BMW?). When it's 120* out and you're dealing with things like traffic and stop lights... uh... nope. This isn't a bag on the DCI. It's perfect for most people. The Mr.5 version is ugly and a PITA, plus more expensive if you use nice filters (I used AFe). It will give you about 20-30* in actual charge temp differences (for a while anyway), and a significant reduction in time before extreme heat soak. I.e. sitting in traffic will still heat soak you but it'll take longer. Quote:
THIS IS NOT THE NORMAL DCI VS. CAI ARGUMENT. OP: Most of these guys do not live in a desert climate, and they're pretty good at repeating info posted from before with no real understanding of the problem you're facing. You are correct to place greater emphasis on heat rejection being in an extreme climate. As the outside temp goes way up, you're removing the large delta T required for efficient intercooler functionality, and just driving around, you will be pulling in air that's 150+ degrees. Mr.5 is better in this instance than the DCI. Meth injection would fix your air temp problem best, but that's another bag of worms you may or may not want to do. |
03-12-2014, 07:50 PM | #14 | |
Rep 105
Great discussion. Thanks everybody for your input. I have no mods other than the JB4 and am not looking to go crazy with adding more. I am leaning toward a DCI and downpipes so I can use a stronger map on the JB4, and with the occasional addition of E85 just for fun, but not going with full bolt ons or methanol injection.
I'd love to take my own measurements in my car on my roads on my commute both with and without a DCI. May I ask how you went about obtaining your numbers? Thanks again everybody!
03-12-2014, 08:41 PM | #17 |
2097
Rep 43,350
You need to free up the intake to make power in the mid range and especially up top where these cars lack power. A sealed intake just can't do that on ANY high powered setup, doesn't matter if you're in Sahara or the arctic. It all comes down to flow.
There's significantly more heat being exchanged in the compression process as well as the residual heat from the turbine housing which is literally inches from the compressor housing. What you should really be focusing on is getting a quality intercooler to bring that temperature back to ambient |
03-12-2014, 08:42 PM | #18 | |
Rep 2,872
I believe AFE makes a sealed unit, but i'm not 100% sure of what benefit that has over a stock airbox w/ a good drop in filter. I'm still kind of new to these engines.
BSM E90 6MT-JB4 G5 ISO-BMS DCI-Golf-Tee Mod-Hankook S1N2 Non-RFT-ER Chargepipe/TiAL BOV-E40 blend-VRSF V2's-M3 CDV-MHD/JB4 FLASH-VRSF 5" STEPPED FMIC
03-12-2014, 09:29 PM | #19 |
Rep 579
Drives: 08 AW e92 335i
I love these threads.
Keep over analyzing the DCI vs CAI thing please.
11.76 @ 124mph (123.9) full weight/street tires/no meth.
03-12-2014, 09:29 PM | #20 | |
Rep 385
I performed extensive data logging via cobb in as close to steady state conditions as I could. I normalized outside temp within a degree, and I found a "test track" that I could have some repeatable data on, and re-performed the data many times to establish a trend. Standard useful data acquisition stuff. Not the typical aftermarket car part testing we see, which is usually not very trustworthy IMO. I also did a test comparing heat soak times wrapping the charge pipe vs not wrapping it (with heat tape) and found the tape to make a 10* difference at worst case heat soak scenario. Real world charge temp difference of a couple degrees once heat soaked. Last edited by C.Pop; 03-12-2014 at 09:40 PM.. |
03-13-2014, 05:35 AM | #21 |
Rep 1,910
Ive run both the dual cone intake and the afe sealed intake elite stage 2 whatever you wanna call it lol. In warmer climates, I would suggest the afe sealed intake. I noticed a difference in power over the stock intake, and buraqs testing shows that. BUT....if you are going to run meth, intake air temp before the turbos doesn't really matter as you would value an intake that flows the best (undoubtedly the dci) over one with slightly cooler intake temps. That's why I went back to the dci setup, because I now run meth making flow a more important characteristic vs slightly cooler temps.
Current: 2017 F30 340i xdrive
Previous: 2008 e92 335i coupe: RB turbos, mach 116 race fuel, methanol, alot of boost. Previous: 2003 Honda Accord V6 coupe: AEM V2, zex 75 wet shot (sold) |
03-13-2014, 06:56 AM | #22 |
Rep 3,732
Drives: BMW S1000XR
I skipped all posts so I dont know if this has been said already; no issues with DCI and did you know the Berk and ER Time Attack cars ran with DCI's. Google them. Upgrade your FMIC.
BMWCCA member |
