High RPM radiator fan, loss of power, oil temp low -- Thoughts?
03-11-2014, 11:37 PM | #1 |
Rep 1,544
Drives: '22 i4 M50
I wanted to get your thoughts on the following symptoms I experienced tonight. I drive a 2007 335i e92 6MT currently with 68k miles, and I had the water pump and thermostat changed 2 months / 5k miles ago with Tischer's waterpump kit, as preventative since I knew I would be driving a lot this year.
It was about 60F degrees out and I had been driving on the freeway for about 30 minutes at a cruising speed when all of a sudden, I couldn't accelerate past 70mph anymore or go pass 2.5k rpm. The engine radiator fan kicks it to max speed and is very loud now. I notice that my oil temp gauge says I'm at about 170F when my normal operating temperature is usually 220-240. No lights or warning messages are going off on the dash or I-drive. I don't have a BT tool to scan for codes either... Any thoughts on this? Could it be the water pump failing already?
2022 i4 M50, Dravit Grey. fully loaded minus the carbon fiber bits and 20" wheel package
2007 E92 335i, 6MT, Sparking Graphite, ZPP, ZSP, Nav, Logic7 (Sold) |
03-12-2014, 09:19 AM | #2 | |
Rep 2,898
Neil |
03-12-2014, 09:59 AM | #4 |
Rep 1,010
water pump.. just happened to me over the weekend, replaced the water pump a t-stat and I'm back in action today
2008 335xi Jet Black//Coral Red VTT Stage 1+// Procede V5//VRSF DPs//AMS FMIC//KW V1//M3 Sways & Sub Bushings// Alpina AT flash Apex EC-7//Michelin PSS//Dinan CAI |
03-12-2014, 11:43 AM | #6 |
Rep 1,376
You could always perform the water pump function test to see if its pumping fluid up to the reservoir. In case you do not know how:
-Car on, engine off (key in, press start without foot on brake) -Open your hood and take the reservoir cap off (make sure engine is cool!) -Put your hvac Temp all the way to 84 on both sides at the lowest fan speed -press and hold the gas pedal for approx. 25-30 seconds -at this point you should here the water pump shaft rotating, pumping fluid up into the reservoir. You will see fluid entering the reservoir from the front of it, if not, the pump has failed. |
03-12-2014, 12:11 PM | #7 | |
Rep 194
I would hate to see it being the water pump again. Mine did the same exact crap before it took a crap on me. Did the yellow then red reduced engine symbol pop out?
2009 BMW 335i Jet Black - BMS Dual Cones, GP Thunder 7500k Fog's, Hellst XRT H8 AE, JB4 G5 ISO Map 5 -
2001 Cobra True Blue - Terminator Swap, 460WHP - |
03-12-2014, 12:27 PM | #8 | ||
Rep 1,544
Drives: '22 i4 M50
Thanks everyone for the responses!
I guess my water pump and t-stat that I just replaced 2 months ago with brand new is faulty or flakey.
03-12-2014, 12:33 PM | #9 |
Rep 194
Maybe could be the thermostat only? Probably doesnt open up all the way like it should
03-12-2014, 04:35 PM | #11 |
Rep 1,257
03-12-2014, 04:46 PM | #12 |
Rep 194
But the fans are on, no reason why they should be on even less loud unless its getting hot. When my WP/TS went out, my oil temps looked perfectly fine. They were somewhere in the 180*'s but I still got the reduced engine light.
03-12-2014, 07:00 PM | #13 |
Rep 1,257
Hmmm...interesting. Mine failed on me as well, but I don't recall the oil temp as it was a few years ago.
03-12-2014, 07:03 PM | #14 | |
Rep 2,898
Neil |
03-12-2014, 07:38 PM | #15 |
38
Rep 634
Engine coolant temps respond to engine overheating conditions MUCH faster than oil temperature. Oil temps can be normal while coolant temps are very hot.
You will need to pull codes to be sure. |
03-12-2014, 08:44 PM | #16 | |
Rep 194
03-15-2014, 12:18 PM | #17 |
Rep 1,544
Drives: '22 i4 M50
Thanks for the responses everyone, I'll try to pull codes this weekend.
It was weird because my oil was around 220 since I had been driving awhile, then noticed the loss of power and high radiator fan RPM, and then the oil temp dropped gradually to 170F over maybe ~10mins?
03-19-2014, 12:20 PM | #18 |
Rep 1,544
Drives: '22 i4 M50
Scanned the car and had 2 codes stored:
2EE3: Coolant temperature sensor, plausibility, gradient 2FBF: Release on injection FYI, did some searching around and some people had the codes trip because of JB4 or Procede, or failing pump. I've had a JB4 for a long time and never had it tripped. There wasn't a one-size-fits-all solution though. http://www.e90post.com/forums/showthread.php?t=395973
