LSD on an auto vs manual
03-13-2014, 09:50 PM | #1 |
Rep 1,062
I'm planning on drifting my car a little on the track. It's also going to be my back and forth from work a few days. Which is why im getting an auto. Just ewondering what the differences would be bbetween an auto and a manual both running a LSD.
Does one drift better than the other? How so? The auto does have paddle shifters. I'm ggoing to be keeping the car for the rest of its life ~15 years. And can all 2007 auto 335i's run the quaife LSD. I'm a noob but slowly and safely I'll be mmastering drifting. |
03-14-2014, 04:51 PM | #2 |
Rep 842
if you plan on drifting get a manual... there's a reason why all pro drifters run manuals... you have the option to clutch kick
03-14-2014, 05:01 PM | #3 |
Rep 965
Drives: e92 m3
AUTO sucks it will upshift every time you redline which you would be doing a lot while drifting
e92 m3 dct
gintani stage 2+ full ethanol custom pulley and meth kw clubsport,ap racing radical,volk te37sl,akrapovic rear,recaro profi xl,voltphreaks battery |
03-14-2014, 06:17 PM | #5 | |
Rep 2,973
If you car drift a DCT car, why wouldn't you be able to drift an auto with a transmission flash?
Arctic Metallic\CF Splitters, Spoiler, Mirror Covers\LED Tails\LSD\Tinted\Coded\Apex Square SM10-19"\LED Angel Eyes\Gloss Black Grill\Integrated V1 & Galaxy Tab\M-Performance Brakes\Cobb Tuned\xHP Flash\Resonator Removed and -> is your friend.
03-14-2014, 11:09 PM | #6 | |
Rep 1,755
03-14-2014, 11:16 PM | #7 | ||
Rep 965
Drives: e92 m3
e92 m3 dct
03-14-2014, 11:50 PM | #8 | |
Rep 3,732
Drives: BMW S1000XR
BMWCCA member |
03-16-2014, 02:39 PM | #10 |
Rep 185
what do you meaning jerking the car and losing speed? have you ever drifted? if you can't drift a manual car, how are you going to drift an automatic which is harder?
03-16-2014, 03:19 PM | #11 |
Rep 965
Drives: e92 m3
It's easy to power slide but maintaing the drift is almost impossible with an automatic.
e92 m3 dct
03-16-2014, 04:07 PM | #12 |
Rep 911
You will burn your AT and also your DCT in a split second...
But give it a try, but please record in with a camera...
BMW 335 E92 09 - Full options - DKG - MHD by Buraq - RB Next Gen - RB Inlets/Outlet - Forge Diverter Valves - AR Catless DP - Afe Intake - Helix IC - FuelIT Stage 2 LPFP - Ar Oil Cooler - PPK Water Cooler - M3 Suspension - JRZ RS1 Shocks - Eibach Pro Springs - Drexler LSD - BMW IS Exhaust - Carbon Endurance Brake Pads - Stainless Steel Brake Lines - M101 Wheels - Michelin PS2 - M-Tech Body - M-Strutbar
BMW M550i G30 2019 - BM3 |
03-16-2014, 04:16 PM | #13 |
Rep 965
Drives: e92 m3
Sell the car and get a z
e92 m3 dct
03-16-2014, 08:37 PM | #14 |
Rep 1,093
07 335XI (A008006) 6AT ~94K miles JB4 G5 ISO VSRF DP's
09 135I M (VK80379) 6MT. Race Project car. 1) Install Cobb/piggyback? and Motiv 600 Kit[HTA3076R w/ tial .82] 2) JRZ or Moton suspension. 3) Build high flow intake manifold with multi-port fuel and relocate OFH 4) Build full cage 5) Complete staged twin setup with HTA4205R [w/Tial 1.16] 6) Complete dry sump system |
03-17-2014, 10:47 AM | #16 | |
Rep 1,100
If you want to drift properly, learn manual.
2010 335i Coupe- Monaco Blue Metallic
03-17-2014, 12:35 PM | #17 |
Rep 2,973
I asked a question.
03-17-2014, 12:48 PM | #18 | |
Rep 2,973
This : http://www.drifting.com/forums/drift...automatic.html and http://auto.howstuffworks.com/auto-r.../drifting3.htm and http://en.wikipedia.org/wiki/Scandinavian_flick It can be done in an automatic, just easier with a manual. You need to break traction to initiate the drift. Just like using the e-brake on a FWD car to drift the same can be done with RWD. Done my share of drifting in a low powered RWD car, before people called it drifting and made it a sport. So if you are trying to use the same technique that you would use in a manual, no it won't work. That being said you will need to look at the various techniques. BTW - No, I don't drift but have been involved in car racing and auto cross longer than I would guess half the people on this forum have been alive. I had an e30 M3 that I would "drift" around the work parking lot. We had a huge lot with no barriers or poles. I'd get to work early just to play in the parking lot.
03-17-2014, 12:56 PM | #19 |
Rep 1,681
You can drift an auto, just not as well. I've seen some local drift events with automatic cars, pull the e-brake and you're good to go. If you're in manual mode and it doesn't upshift, it would work. Not great for the transmission, but not any different than driving at high revs. Converter should be locked at that point so nothing is slipping, it's getting hot, but unless you were redlining for 20 minutes, you're probably fine.
But the thing is, if you're asking this, you should probably learn to drift first. Please don't go out and try this on an on ramp or something. |
03-17-2014, 11:11 PM | #20 | |
Custom User Title
16
Rep 131
Either way OP, sounds like you want more control while sliding, and therefore LSD is of course a good idea. I can casually power slide corners with my auto 335i non-lsd and have fun still, albeit I'm not going guns blazing holding redline. I see an LSD in my future. |
03-18-2014, 12:40 PM | #21 |
Rep 2,973
You can alway flip the stick into neutral before pulling the ebrake then back into gear.
You can break traction with the right steering technique. Auto has option, you just need lots of practice.
