Need help for the first time in 7 years!!!
03-18-2014, 07:06 AM | #1 |
Rep 90
Hi everyone,
I’m not much of a poster since normally I can find all the information I need. But recently the car started giving fault codes. It started with a battery message and: P2c3b Lamba probe before catalyst P2a2b Mixture control lambda P29cd Misfire cyl 1 P29cf Misfire cyl 3 P29ce Misfire cyl 2 P29cc Multiple misfires P29e0 Mixture control This was on my winter tune a 13 psi roadcourse file (from a local shop). Then an indy shop replaced three coils (without consulting me) and a new battery, I guess cyl 1-3 and a full reset with inpa was done. Car drove normal for one or two days. The all the same codes popped up + P2c77 (O2 post cat lambda signal), and also all the same codes with an H instead of a P before the codes + H29d9. I the switched over to my summer file (PTF pro tune on 98 RON). When I drove away immediately I got the following codes: P2a18 DMTL heating control P29cf Misfire cyl 3 P29ce Misfire cyl 2 P29cc Multiple misfires Other details on the car: Have run two tanks of E40 three months back (tune not finalized yet), since then only 98 RON. It’s a 2007/04 335i E92 with: ETS 5” intercooler Stett intake BMS catless DP’s Full Milltek exhaust Forge DV’s Car never gave any fault codes until now. Could someone please help me with what would be the most sensible way of checking parts in a particular order? Thx!!! |
03-18-2014, 07:25 AM | #2 |
Rep 3,625
Looks like a bank one issue. Let's start with the easy, cheap fix which would be spark plugs. When were they last changed? From there I would look into injectors.
03-18-2014, 08:32 AM | #4 |
Rep 1,010
Try it on stock map first, if it runs fine stock, but not on your tune.. then try plugs
2008 335xi Jet Black//Coral Red VTT Stage 1+// Procede V5//VRSF DPs//AMS FMIC//KW V1//M3 Sways & Sub Bushings// Alpina AT flash Apex EC-7//Michelin PSS//Dinan CAI |
03-18-2014, 12:38 PM | #5 |
Rep 2,973
I'd say bad injectors. You have removed the 02 sensors I presume? otherwise bad pre-cat 02 sensor.
Arctic Metallic\CF Splitters, Spoiler, Mirror Covers\LED Tails\LSD\Tinted\Coded\Apex Square SM10-19"\LED Angel Eyes\Gloss Black Grill\Integrated V1 & Galaxy Tab\M-Performance Brakes\Cobb Tuned\xHP Flash\Resonator Removed and -> is your friend.
03-18-2014, 01:40 PM | #6 |
Rep 1,465
Drives: 2009 BMW 335xi
Plugs
03-19-2014, 07:19 AM | #8 |
Rep 639
Sounds like an o2 sensor based on all the faults. I'd try that first. Also make sure the shop didn't unplug the o2s and then mix up the wires when they plugged them back in
03-19-2014, 07:55 AM | #9 |
Rep 2,291
03-19-2014, 08:27 AM | #10 |
Rep 1,643
That's what happened to me when my dme fried...
2007 E92 335i MT
03-19-2014, 08:41 AM | #11 |
Rep 1,071
i had almost the same codes when my LPFP was going out and again when my front pre-cat o2 went out after the exhaust wheel hit the tip of it, LOL.... after i replaced it they went away
P2c3b Lamba probe before catalyst P2a2b Mixture control lambda P29cd Misfire cyl dont remember which cylinders were misfiring P29cf Misfire cyl P29ce Misfire cyl P29cc Multiple misfires P29e0 Mixture control
FFTEC 6466 Gen2, MHD Flash Tuned by Wedge, BMS PI Kit, FUEL-IT Stg 3 pump, HALTECH PS-1000, MFactory LSD w/lock down brace, ECS Trailing Arms, M3 control arms, M3 brace, DGR Coilovers, N20 tmap sensor, BMS OCC, VRSF exhaust w/4" tips, VRSF CP, Tial BOV. BigTom FMIC, Msport front & rear, m3 sides skirts.
03-19-2014, 12:07 PM | #13 |
Rep 719
Leaking injectors 100%.... Pull the plugs and check..
ASE master tech (many moons ago)335xi- JB4 G5 iso/e50 custom flash/Custom meth/Borla mids/Custom x-pipe/DCI/ER charge pipe/Dual Ebay BOV's/Alpina B3 flash/Paddle shifter retro fit
04-14-2014, 02:50 PM | #15 |
Rep 1,010
the pre-cat sensor right?
05-09-2015, 06:33 PM | #17 | |
Rep 1,340
