Dedicated vacuum port >Tial BOV
03-18-2014, 07:57 PM | #1 |
Rep 1,525
Just finished this up today in hopes to stop the fluttering I get from my Tial bov. Pretty straight forward, in the pic there I am finishing up sealing it.....wouldn't want a vacuum leak.
I still kept the oem port for my boost gauge. |
03-18-2014, 08:39 PM | #2 |
Rep 227
I thought this would fix my flutter... After tapping a new nipple, I took apart my tial bov and cleaned it. After everything was buttoned up there wasn't any flutter! I was happy as can be... A week or so later the flutter at low rpm/boost has come back.
Now I'm going to try to polish the bov piston and or oil it. If that still does not help I'll start clipping the spring. |
03-18-2014, 08:43 PM | #3 | |
Rep 1,525
vacuum
03-18-2014, 09:34 PM | #4 |
Rep 2,114
The spring is too stiff and or your engine has a shit load of carbon deposits preventing the valve from pulling the right vacuum pressure. I ended up dropping down to a white spring to get the right vacuum for my altitude and kill the flutter.
E92 '08 335Xi 6AT - Cobb AP3 Tuned by MAC Autosport, Original Prototype Xi DOCRace 6266 Single Turbo Swap, VRSF CP w/Synapse BOV, VRSF 7" FMIC, BMS Cowl, H&R Coilovers, Renn Motorsport RS-51's, Stoptech Stage 2 Slotted, xHP Stage 3, Earl's Racing Oil Cooler, Turner Boost Gauge, M3 Lip Spoiler.
Standing Mile Record Holder for Xi over a mile high: 168.2MPH @ 5512'; The Colorado Mile hosted by The US Mile. |
03-18-2014, 09:58 PM | #6 |
Rep 1,525
tial
Ive had the blasting done so that I don't think is related. I'm at 5500ft
03-18-2014, 10:18 PM | #7 |
Rep 2,114
What spring are you running? The yellow spring is too much for our altitudes. Max you should be running is the unpainted spring which falls between a yellow and a white.
03-19-2014, 09:57 PM | #8 |
Rep 1,525
spring
03-19-2014, 11:28 PM | #9 |
Rep 2,114
So what you're saying is you don't know what spring is in the BOV.
03-20-2014, 06:55 AM | #10 |
Rep 1,202
Spring is too stiff, go with black spring, shim it til its just closed at idle, use the dedicated port. Exactly what we did with the shop car, BOV then works as it should. The spring they recommend is too strong 80% of the time.
03-20-2014, 08:18 AM | #11 | |
Rep 632
2007 335i e90 6mt | Motiv 750 XR8267 | RB PCV | JB4 G5 | MHD Pump Flash | Walbro 255lph | VRSF CP & Tial BOV | NGK Plugs | Custom Side Exhaust | CxRacing FMIC | Spec 2+ & SSMFW | StopTech Drilled/Slotted Rotors | Hawk Performance Pads | DEFIV Lockdown kit | Mtec V3 | Apex PS7s | 35/15% Llumar ceramic
03-20-2014, 09:25 AM | #12 |
Rep 483
yes i have a tial and its closed at idle but does release boost at say 2-3 psi, its quite but you can hear it but loud as fuck under 17psi lol
03-20-2014, 11:41 AM | #13 |
Rep 722
Drives: 2008 BMW 335xi
03-20-2014, 05:39 PM | #14 |
Rep 1,525
spring
03-20-2014, 05:52 PM | #15 |
Rep 2,114
I have a white spring right now. Might go to unpainted since I just had walnut blasting done today.
03-20-2014, 06:15 PM | #16 |
Rep 1,525
spring
