newb question on whether common issues relate to chip upgrades
03-21-2014, 12:14 PM | #1 |
Rep 77
Drives: 2015 535i xdrive, 2014 x5 35i
i'm owner of sub 10k mile n54.
i'm new to e90, previously having e36. after getting car, i saw online that there are some common failures such as hpfp, injectors, turbos, wastegate, gunk in valves/cylinder tops, etc. my question is whether you've seen online that the those with upgrades such as cobb/jb4, etc have much higher percentage of issues than those with non-upgraded cars? |
03-21-2014, 12:17 PM | #2 | |
3442
Rep 79,211
In a nut shell if your HPFP was weak and you got a tune and it failed it was going to fail anyway. If your injectors were on their way out and you got a tune and they failed it was going to fail anyway. So it just brings out the weaknesses sooner. If your spark plugs, injectors, fuel pump and the like are up to date and maintained you can tune this car happily well past 100K miles easily. |
03-21-2014, 12:35 PM | #4 |
Rep 3,552
chip upgrade/tune/piggyback/flash is all interchangeable. we understand what he means.
HPFP and turbos have problems in stock n54's. So putting a tune in your car will work many things harder, but we cant exactly say that your HPFP or turbos will indefinitely fail from the tune. we could say that you'll see a misfire eventually. from spark plugs or a faulty coil pack.
12.0 @ 117 |
03-21-2014, 12:40 PM | #5 |
Rep 978
I obviously understood him too.
But I don't see why it's so hard to refer to it as a tune vs. a chip if you do understand how it really works. I had my old A4 chippedby APR. The ECU was pulled out and a new chip was soldered in. THAT'S a chip upgrade. |
03-21-2014, 12:50 PM | #6 | ||
Rep 1,643
2007 E92 335i MT
03-21-2014, 01:05 PM | #7 | |
Joint Chiefs of Staff
4927
Rep 116,037
One of the reasons we recommend spark plugs be changed when getting a tune if they haven't been changed in the last 15K or so. Mike |
03-21-2014, 08:09 PM | #8 |
Rep 77
thanks guys
