03-24-2014, 06:58 AM | #1 |
Rep 250
Replaced stock turn signals with LED [VIDEO]
Hey guys!
I recently took delivery of a 116i. Very happy with the car so far. Very smooth ride (especilly compared to my E92 M3), and OK performance. I added a Hartge Engine conversion, which gives you 171hp, and a lot more torque! What I dont understand is why BMW releases new cars to market with Halogen bulbs. So today I installed WeissLicht Spektrum turn signal bulbs front and rear (PY21W). The install was easy, and I let this video speak for itself
Current: 2018 X1 F48 & 2014 F20 116i. Before: 2009 BMW E90 320d LCI, 2008 E92 M3 &
03-24-2014, 07:43 AM | #3 | |
Rep 250
Hehe, joking.. - First clip shows OEM halogen - Second clip shows LED on the left, Stock on the right - Third clip is all LED Forresten, jeg er norsk
03-24-2014, 07:58 AM | #5 |
Rep 250
No, this is a top notch product. Brighter than stock. Lifetime warranty. NO error codes. I have used the same LED's on my M3 for a while, and very happy with the product.
03-25-2014, 12:09 PM | #8 |
Rep 250
Looks very crisp. Feels more premium all of the sudden
04-02-2014, 10:37 PM | #10 |
Rep 250
Yes, from bimmian
04-03-2014, 11:04 AM | #12 |
Harvesting Information
9
Rep 83
Hiya i've done this on my 125d. Just watch out for flickering upon startup, and also when you are 10 mins into a journey.
I needed to turn off cold and warm bulb checking via E-Sys to stop this flickering. It's caused by a tiny current sent to the bulb to check if its live or not, and if its not you get a bulb warning. However, the power requirements for LED are so much smaller than halogen, this tiny current causes the bulb to flicker briefly. With Halogen the current is insufficient to cause any visual impact on the bulb. I am preparing to do this again on Monday when i switch to my M135i so will post the necessary configuration changes if thats of any use
2014 F20 M135i | Too many options to list
I also do coding but i'm no expert. happy to help out though |
04-03-2014, 11:49 AM | #13 | |
Rep 250
05-08-2014, 12:55 AM | #16 | |
Rep 250
- Second clip shows LED on the left, Stock on the right - Third clip is all LED. Looks even better in real. Like a computerized flash.
05-08-2014, 05:08 AM | #17 |
Rep 130
Impossible to tell a difference by that clip. Mostly because of the massive glare and that one side of the car is well-lit and other is in the shade...
05-08-2014, 05:46 AM | #18 | |
Rep 250
If you seriously can't see the difference from halogen, on those front bulbs, im not sure what to say The mobile camera has a problem with lightning conditions when I film the rear. But I can still see a huge difference
05-08-2014, 01:35 PM | #19 |
Rep 130
Think you have the advantage of seeing the difference IRL. Then it becomes clear in the clip as well.
05-08-2014, 02:01 PM | #20 |
Rep 223
It is blindingly obvious how much different it is with the LED bulbs and I for one very much like it
Current: 2014 F21 M135i Estoril Blue
Previously: 2012 F21 116D M Sport Estoril Blue |
