Advice on a misfire diagnosis
03-25-2014, 10:15 AM | #1 |
Rep 55
Shows to be my first post but actually a long time member that forgot his password a few months ago. Couldn't get a mod to help me reset it so i just made a new account
Looking for advice as to what could be going on with my car. A couple days ago i went to start it and was getting a horrible misfire. Car was jerking around and sounded horrible! SES light popped on and started smelling a strong odor of fuel. I pulled codes and got a P0305 (cyl 5 misfire). I proceed to drive to work very carefully and notice half way there (now that the engine is warmed up) it is running fine. I get to work,clear codes, pull cyl 5 coil, swap to cyl 1 and everything seems to be fine except now im getting a oxygen sensor lean code that is popping up. This morning i go out for another cold start and it is running extremely bad now. Pull codes and getting p0304,p0305, and p0306 codes now (cyl 4,5,6 misfires). My #1 theory is my oxygen sensor is either failing or is broke. I had my downpipes taken out and factory cats put back in a few months ago. The fact that i got a oxygen sensor lean code has me thinking it is putting more fuel in those cylinders ultimately causing a misfire in those particular cylinders. And please correct me if i am wrong, but i do believe bank 2 sensor 1 is for cyl 4,5,6? My #2 theory is injector #5 is stuck open. but then why would i get misfires on 4 and 6 now. note: i have not pulled the plugs yet because i dont have the tool. just ordered one from bms about 30 mins ago. The car still runs right after warm so im guessing they are not completely fouled, just probably black as hell. Thanks in advance for any help or ideas, im just about ready to pull my hair out with this |
03-25-2014, 10:21 AM | #2 | |
Rep 1,093
07 335XI (A008006) 6AT ~94K miles JB4 G5 ISO VSRF DP's
09 135I M (VK80379) 6MT. Race Project car. 1) Install Cobb/piggyback? and Motiv 600 Kit[HTA3076R w/ tial .82] 2) JRZ or Moton suspension. 3) Build high flow intake manifold with multi-port fuel and relocate OFH 4) Build full cage 5) Complete staged twin setup with HTA4205R [w/Tial 1.16] 6) Complete dry sump system |
03-25-2014, 10:46 AM | #3 |
Rep 55
Ya that is what i was thinking as well. If the injector was stuck open i shouldn't be getting o2 lean codes. Im banking on the o2 sensor and i like your idea of swapping them. I will probably go that route and hope all the codes switch over to 1,2,3
03-25-2014, 11:11 AM | #4 |
Rep 55
Also, can anybody confirm what primary sensor controls cyl 4,5,&6? I know it is the front sensor but is it the one on the pass side or driver side?
that would help me out alot! thanks again |
03-25-2014, 11:27 AM | #5 | |
Rep 461
Keep in mind that one sensor is shorter than the other one. You'll have to re-route the wire in order for it to reach the connector. |
03-25-2014, 11:49 AM | #6 |
Rep 1,093
Passenger side is bank 2. Rear turbo downpipe routes to passenger side.
03-25-2014, 11:57 AM | #7 |
Rep 55
03-26-2014, 10:04 AM | #8 |
Rep 55
Well, the oxygen sensor did not fix the problem Went ahead limped it to the stealership this morning. Weird thing is, that after i installed the new sensor yesterday the car was running perfect. I even went out late last night to start it and she was purring like a kitten. Wake up this morning and boom! cyl 4 and 5 misfires. Its almost like its on a timer and can only take a shit at exactly 7:25am...uggghhh .... Should know shortly and i will update.
03-26-2014, 02:52 PM | #9 |
Rep 2,973
Injectors.
Leaky injectors will dump residual fuel in the cylinders overnight. Warmed up the car will do fine. In the morning it will run like a truck with a bad plug. Been there, done that. Replaced all six injectors under CPO.
Arctic Metallic\CF Splitters, Spoiler, Mirror Covers\LED Tails\LSD\Tinted\Coded\Apex Square SM10-19"\LED Angel Eyes\Gloss Black Grill\Integrated V1 & Galaxy Tab\M-Performance Brakes\Cobb Tuned\xHP Flash\Resonator Removed and -> is your friend.
03-26-2014, 05:09 PM | #10 |
Rep 55
Yes sir, just ordered my injectors and having them put in tomorrow. Hope im not burning my self for just doing 3
03-27-2014, 03:37 PM | #11 | |
3442
Rep 79,211
As long as you realize the other 3 may go down the road it won't burn as bad. |
03-30-2014, 10:50 AM | #12 |
Rep 75
I am having the exact same problem for nearly a year now and have been putting off the repair but will have to bite the bullet and replace them..... or get them cleaned.
I have seen the post about cleaning/refurbishing the injectors and looks like people are happy with ***********. I am waiting on his response if he ships to Canada. Does anyone know of a similar service in Canada in case he doesn't ship here? Last edited by TheM3Boy; 03-30-2014 at 07:47 PM.. |
03-31-2014, 11:06 AM | #14 |
Joint Chiefs of Staff
4927
Rep 116,037
