Cheap rear induction tube fix
03-26-2014, 03:00 PM | #1 |
DIYER
614
Rep 5,521
After doing many sets of turbos I was tired of fighting to make the rear induction tube stay on. I found this fix, it is a bit ghetto but works. There may be better fixes but this works flawless and is about a 5 min fix.
JB4 G5, Stage 3 LPFP, Stage 2 MOTIV PI, VM 6466 ST, Custom OCC W/ SS lines, ER FMIC, ER CP W/HKS BOV, M3 control arms, M3 guide rods, M3 upper links, M3 front & rear sway-bars, HPA rear toe arms, Wavetrac LSD, HPF Gen 2, DEFIV kit, KW clubsport, Delrin solid SF bushings, stoptech rotors, Rogue Tranny Mounts, 1M bumper, M3 CF hood, M3 fenders, M3 OEM sideskirts, Mtech rear bumper, CSL trunk, MORR VS8.2 rims 245/295
03-26-2014, 04:22 PM | #2 |
Rep 6,478
It's always surprised me that the turbo inlets are just kinda...hanging out there, nothing anchoring them what so ever.
So is the basic idea that by "tying" the intake to that stub on the manifold, it removes the unwanted slack and play from the entire rear inlet? If so, good thinking. Can't hurt.
E88 N54 Alpinweiss/Coral Red/Motiv HTA 3586r Tial .82AR/Other stuff...652WHP
F30 N55 XDrive EBII |
03-26-2014, 04:25 PM | #3 | |
DIYER
614
Rep 5,521
03-26-2014, 04:33 PM | #4 |
Rep 1,643
I was struggling to figure out what was going on here until 135pats made it more clear. If I'm understanding correctly, by making this modification hook near the air filter, this will prevent the rear turbo intake tube from separating from where it attaches at the rear turbo. If this is the case, than this is great - mine had separated for a long time and was gathering oil at the connection point that would drip downward and across the trans, appearing as a rear main seal leak.
2007 E92 335i MT
03-26-2014, 04:41 PM | #5 |
Rep 1,794
I'll definitely have to try this!
Is this the only modification you made or did you also have to mess with the bracket that holds the rear induction tube? |
03-26-2014, 04:46 PM | #6 |
Rep 2,621
Good work. How does the engine move under load?
I want bigger intake pipes - fixed on to the turbo - but they won't fit!!
Car: e91 330d with Viezu map
Gone but not forgotten: 2010 Jaguar XFR (Cat-back exhaust, pulley, intake mods and map), Highly Modified E90 335i LCI M Sport Manual (circa 480BHP/500lb ft) |
03-26-2014, 05:00 PM | #7 |
3442
Rep 79,211
Took me a minute but I get it it now. Neat idea. After 20K miles I found my rear turbo inlet barely on. I was thinking "I wonder how long that's not been connected".
03-27-2014, 07:01 PM | #9 | |
DIYER
614
Rep 5,521
03-27-2014, 07:02 PM | #10 |
DIYER
614
Rep 5,521
That bracket is not even in contact lol!
03-27-2014, 07:04 PM | #11 |
DIYER
614
Rep 5,521
ROFLMAO! I got that strut bar for only $300 brand new locally in Craigslist!
03-27-2014, 07:07 PM | #12 |
DIYER
614
Rep 5,521
LOL! When I first put on my RB'S my stock turbos didn't even have a gasket
03-27-2014, 09:12 PM | #13 |
Rep 567
My bracket seems very tight up against the tube. I wonder if some dealers bend them to remove the turbos? Either way I may make a bracket like Vargas just to be safe
07 335 6MT
03-27-2014, 09:13 PM | #14 |
Rep 1,257
03-27-2014, 09:54 PM | #15 |
The Wolf
256
Rep 992
Drives: stuff
Where is the oem bracket? My rear turbo was replaced and inlet fits loosely even with the oem airbox
03-27-2014, 10:13 PM | #16 | |
Rep 1,643
2007 E92 335i MT
03-28-2014, 01:29 AM | #17 |
DIYER
614
Rep 5,521
There is a bracket that is supposed to apply pressure to the tube....the weak bracket dies nothing. I have in past wedged things in between bracket and firewall to give more pressure and it never works.
03-28-2014, 10:43 AM | #19 |
The Wolf
256
Rep 992
Drives: stuff
I have BMS DCI installed now, but when I push on the front of the inlet it doesn't seem to really do anything, I guess I need to get it on a lift and have someone watch from below?
-2019 BMW m850i convertible
-2021 Dodge Charger Hellcat Redeye Widebody |
03-28-2014, 05:23 PM | #20 |
DIYER
614
Rep 5,521
That would be best, but add long as itsis tight in that spot you should be good.
03-28-2014, 05:23 PM | #21 |
DIYER
614
Rep 5,521
03-29-2014, 03:06 AM | #22 |
Rep 1,059
I don't understand why this needs to be done? When I installed my cones, they are on top of each other but the inlet pipe to the turbo doesn't move back, everything is in normal position...
