03-26-2014, 05:06 PM | #1 |
Rep 150
Help! Spacer size
Just bought a m235i and want to know what is the best option for spacers front and rear I was thinking 12 front and 20mm rear please let me know if anyone has experience.
2014 M235i Mineral Grey, JB4, ER DP, BMS Intake EWG Beta test, 35% e85,injen intake stage 3 fuel pump by fuel it
05-20-2014, 07:29 PM | #3 |
Rep 187
What I can guess is the offset is the same as 1 series.
So you can try front 10-12 mm. and rear 12-15 mm. I'm running 10 mm on front and rear without any issue. |
05-21-2014, 01:34 AM | #4 | |
Rep 661
05-21-2014, 07:27 AM | #5 | |
Rep 4,128
Drives: M235i & G30 540i
Lack of money is not the problem. It is merely a symptom of what's going on inside of you! - T Harv Eker
Follow me on Insta https://www.instagram.com/bmwm_life_/ https://www.instagram.com/autogiftua/ https://www.instagram.com/phoenixbmwlife/ |
05-21-2014, 09:40 AM | #6 |
Rep 269
10mm rear spacers will not fit, I've tried it. The hub ring is longer on the Fxx cars than the Exx (see my other thread in this section). You need a minimum of 13mm in the rear.
Soon I will order a set of 13-15mm for the rear and stick my 10mm on the front. |
05-21-2014, 10:03 AM | #7 | |
Rep 661
05-24-2014, 09:30 PM | #8 |
Rep 150
pics of 12mm front 14.8mm rear spacers
05-25-2014, 08:51 PM | #10 |
Rep 5,262
sorry for my ignorance, but how hard is to put the spacers on?
Do you just take the wheels off, put the spacer on top of the rotor, put the wheel back on ? |
05-26-2014, 04:06 PM | #11 | |
Rep 150
I believe they are m14x1.25?
05-28-2014, 12:12 PM | #17 |
Rep 150
you have to resize, 1600x1600 is the biggest. just open in preview if you have a mac and "resize"
