Best mods to make the N54 stronger ( longevity )
03-28-2014, 04:51 PM | #1 |
Wastegate Rattle
114
Rep 897
What would be the best things to do or to improve on the N54 to make sure it lives a nice long and healthy life ? Especially since most of them are modded... ?
03-28-2014, 05:12 PM | #2 |
Rep 1,093
Downpipes and a rich stage 1 tune. Lower back pressure and EGTs will extend turbo life (theoretically). The engine itself it bullet proof. Now if you put downpipes on and turn around and ring out all its worth your back to square one (which is still a long healthy life IMO). The major things that go wrong on this car are not upgradable (except turbos). The water pump and oil gaskets seem to be the main things so they just have to be replaced as needed.
03-28-2014, 05:18 PM | #3 |
Rep 2,063
Drives: 2007 335i Coupe
Garage List 1991 BMW E30 325i s ... [8.50]
1995 BMW 318Ti [0.00] 2007 BMW 335i Coupe [10.00] 1962 VW KarmanGhia [10.00] 2007 BMW Mini Cooper [9.00] |
Just pop this in and let's see what happens "LONGEVITY" .... Sorry I'm trollin forgive me
03-28-2014, 06:26 PM | #5 | |
ex deus machina
124
Rep 968
upgrade trans cooler if auto Use good oil (like Motul 8100 X-cess) Downpipes like others said, keep stock intake for maximum air filtration. I would say meth injection with very minimal boost additive, helps clean the inside of the engine, control carbon build up, no knock
Daily: G30 M550i, Bluestone, JB4, 1 step colder plugs, 6WB retrofit
Winter Beast: Audi S4 4.2L V8, Supercharger, brakes, suspension & exhaust mods Wifes': F15 M50d clone, DUDMD tune, WMI, MPBK Gone: E92 335i N54 468rwtq |
03-28-2014, 06:44 PM | #6 | |
Rep 2,898
Neil |
03-28-2014, 07:33 PM | #8 |
Rep 864
GRP V
“Redline is Group V (polyol ester) based (POE or esters).
“Amsoil and Mobil-1 are Group IV (poly-alpha olefin) based (PAO or synthesized hydrocarbons SHC). “Castrol Syntec and all the others calling themselves synthetic are Group III (hydrocracked slack wax). “The petroleum motor alls are all mineral oil based and make up Group II. ”We really should group Red Line by itself, and put the others in separate categories (according to the groups) because their performance is so different |
03-28-2014, 07:42 PM | #9 |
Rep 103
An oil catch can is important. There's oily, carbony vapors from the crankcase that get circled through the engine that get sent to the catch can instead of your inlet port.
03-28-2014, 07:43 PM | #10 | |
Rep 2,898
Neil |
03-28-2014, 07:45 PM | #11 |
Rep 1,643
Have you folks running the group v oils noticed any different behavior or observations from your cars?
Also, is it ok to switch to a group V oil if one has been using BMW oil for 100k miles? (Changed evry 6k).
2007 E92 335i MT
03-28-2014, 07:51 PM | #12 |
Rep 2,898
Based on Blackstone oil analyses, my engine shows significantly less wear when I run Motul 300V. Mind you, I spend a lot of time on the track (road courses) and really push my car.
And no problem switching oil. Neil |
03-28-2014, 08:08 PM | #13 | |
Guest
Rep n/a
Drives:
03-28-2014, 08:18 PM | #14 |
Rep 6,478
Motul
300V or XCESS are outstanding oils.
E88 N54 Alpinweiss/Coral Red/Motiv HTA 3586r Tial .82AR/Other stuff...652WHP
F30 N55 XDrive EBII |
03-28-2014, 08:58 PM | #16 |
Wastegate Rattle
114
Rep 897
Just to clarify,
I have JB4, AFE intake, Charge pipe with tial bov, downpipes. About the oil catch can, is there a DIY ? What is "BMS occ and a RB pcv valve" ? I do not plan on adding Meth injection. Thanks for the info ! |
03-28-2014, 09:34 PM | #18 |
Rep 465
My car didn't like the BMS OCC, it started smoking BAD and leaking oil from oil pan and rear main seal, took it off and it stopped smoking right away and the leaks appear to have stopped (I have yet to clean it up and reinspect, but no more drips in garage). My car has 120k miles so maybe for a younger engine it wont matter but for longevity I wouldn't recommend an OCC. I do have the upgraded RB PCV tho.
03-28-2014, 10:10 PM | #21 | |
Rep 1,643
Any other anecdotal observations from when anyone switched over to group V from BMW branded oil?
2007 E92 335i MT
03-28-2014, 10:56 PM | #22 |
Rep 6,478
Go to the BMS website, all products have DIYs. An OCC is simple. Rob's PCV valve is just a replacement for the stock valve, which is not a particularly well engineered piece. The entire venting system is poor on this car IMO. Just ends up dumping oil into the rear turbo.
