E90Post
The Tire Rack
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Regional Forums > Australia > time for new rotors?
Reply
      03-30-2014, 09:54 PM   #1
jevanh
Drives: BMW 323i E90
Hi there a friend told me about r1 concepts stor in america and im after some new rotors and ceramic pads for low dusting.
The only problem is, is because i own a 323i and America's base model (i believe) is a 328i??? im not sure if it would fit.
So when i go an look at the compatibility table further down each ebay page it will say not compatible. But does the disc/rotor/caliper set up remain the same? Some help would be most appreciated.
Below are possible options i was looking at.
http://www.ebay.com/itm/F-R-Kit-PREM...item51b5b22395
http://www.ebay.com/itm/F-R-Kit-PREM...item51b5b23235
http://www.ebay.com/itm/REAR-KIT-PRE...item5af8473279
http://www.ebay.com/itm/FRT-KIT-PREM...item5af847325b
Thank you. =]
      03-31-2014, 12:57 AM   #2
cartaa100
cartaa100's Avatar
Australia
37
Drives: 335i, 640i, X6M50d, X3M40i
Personally i think that brand looks dodgy
      03-31-2014, 01:23 AM   #3
naynay
Australia
178
Drives: 2006 E92 335i FBO
http://www.e90post.com/forums/showthread.php?t=649337
      03-31-2014, 05:39 AM   #4
Zen
Australia
11
Drives: E92 335i
Thank you. =]
They have a rep on the forum, shoot them a PM.
I'm using it atm on my 335i and have no issues with it. Quality wise imo it is just as good as the ECS rotors.
08' E92 335I
Black Sapphire Metallic | M-Sport | GT-CS 19" Matte Anthracite | BMW Perf. Exhaust | JB4 | AR Design Catless DP | R1 Concepts Cross-drilled & Slotted Rotors | aFe DCI | ER Chargepipe with Forge DV | ER FMIC
      03-31-2014, 08:00 PM   #5
jevanh
Yeah i heard that they were okay and have not seen too many negative reviews after doing a search.
I do need help determining if the brake rotors form a 328i fit my 323i though...=/
The supplier has not replied.
wondering if anyone who has put them on that not a 335i lol?
      03-31-2014, 08:06 PM   #6
jevanh
the sponsor said this in order to help me
Hi,
I would need to know the U.S spec of your vehicle. Ask some of the members on the forum what the U.S spec of your car is. Let me know.
-Kevin
does anyone know what this means? sorry im so clueless..
      03-31-2014, 08:18 PM   #7
TK323
Australia
Drives: e90 323i
[QUOTE=jevanh;15700530]Yeah i heard that they were okay and have not seen too many negative reviews after doing a search.
wondering if anyone who has put them on that not a 335i lol?[/QUOTE
BMW part no.front disc 34116855006.
Rear disc 34216855007.
      03-31-2014, 09:35 PM   #8
Zen
Australia
11
Drives: E92 335i
Hi,
-Kevin
According to the part number supplied by @3234ME:
Front: 312x24mm
Rear: 300x20mm
08' E92 335I
      03-31-2014, 10:17 PM   #9
TK323
Australia
Drives: e90 323i
if you go to ECS Tuning you can compare and see if these part no's i sent match those they have for the 328i. i think they do.
      03-31-2014, 10:42 PM   #10
jevanh
Ok thanks guys so much for the help!. so when i look at:
http://www.ecstuning.com/BMW-E90-328...ors/ES2562082/
i see the same part number from the manufacturer but then if i were to look at
http://www.ecstuning.com/BMW-E90-328...ors/ES2190250/
the part number are not the same but booth have 312*24mm? will it still fit? was planning to get slotted one and ceramic pads.
thanks.
      03-31-2014, 11:09 PM   #11
TK323
Australia
Drives: e90 323i
thanks.
the reason they are different part numbers is one is A BMW part the other is ECS aftermarket part.312x24mm will fit. you can check on realoem.com if you like.
      04-01-2014, 05:56 PM   #12
jevanh
I went on real oem but the site was down for updates...
anyway i spoke to ecs and they provided me with this:
https://www.ecstuning.com/Checkout/?...tent=link2cart
incase that link doesnt work here are the individual links:
http://www.ecstuning.com/ES2539451/
http://www.ecstuning.com/ES2539453/
however they are both 300 x 24 or 300 x 20
not the measurements you guys gave me (part number supplied by 3234ME:
Front: 312x24mm
Rear: 300x20mm)
so would he 300 x 24 fit? or i best get 312 x 24?
also when changine pads and rotors will i need these:
http://www.ecstuning.com/ES2534772/
http://www.ecstuning.com/ES2534770/
thankyou thankyou thankyou!!
      04-01-2014, 06:55 PM   #13
Zen
Australia
11
Drives: E92 335i
Front: 312x24mm
Rear: 300x20mm)
Goto realoem.com and enter your last 7 digit of your vin and double check the OEM part specifications.
I personally would stick with OEM rotor dimensions if possible. I think those will fit, but you lose 12mm overall and I'm not sure if it will affect the overall braking.
08' E92 335I
      04-02-2014, 06:26 AM   #14
waterbottle1
waterbottle1's Avatar
153
Drives: F80 M3
I just installed some r1 drilled rotors and hawk ceramic pads.
Just bedded it in, and not bad.
I'm happy as it Bites well and stops well for my DD
      04-02-2014, 08:32 PM   #15
jevanh
Just been onto real oem and found that my rotors agree with what 3234me has said also where my front is 312 X 24 and rear is 300 X 20
http://realoem.com/bmw/showparts.do?...78&hg=34&fg=12
it gave me 2 part numbers for the rear? the only thing i am assuming is that one part is no longer made? and is substituted by another?
PN: 34216764651 (rear disc) it said ended in the notes
PN: 34216855007 (read disc) i am assuming the superseded the above one?
ALso R1 concepts have sent me the specs of their rotors for front and read
Front Rotors
Outer Diameter: 312mm
Height: 73.6mm
Nom Thick: 23.8mm
Min Thick: 22.4mm
Hub Reg: 79mm
Bolt Size: 14.5mm
Bolt Circle: 5x120mm
Weight 19.45lbs
Rear Rotors
Outer Diameter: 299.8mm
Height: 66.2mm
Nom Thick: 19.90mm
Min Thick: 18.4mm
Hub Reg: 75mm
Bolt Size: 14.7mm
Weight: 13.75lbs
from this info do you guys think it should be okay?
      04-02-2014, 10:42 PM   #16
Zen
Australia
11
Drives: E92 335i
Front Rotors
Height: 73.6mm
Nom Thick: 23.8mm
Min Thick: 22.4mm
Hub Reg: 79mm
Bolt Size: 14.5mm
Weight 19.45lbs
Rear Rotors
Height: 66.2mm
Nom Thick: 19.90mm
Min Thick: 18.4mm
Hub Reg: 75mm
Bolt Size: 14.7mm
Weight: 13.75lbs
The R1 rotors are pretty close to the oem spec. It should be fine.
08' E92 335I
Reply
e90post
