04-22-2014, 08:10 PM | #3 |
Rep 54
I could be wrong but I think if you have to pass an emissions test you could have issues. I'm in NY and would like to add a dp but not sure if a HFC will 1) pass NY emissions and/or 2) throw a CEL that would have be cleared before the inspection (and dealer visits).
04-22-2014, 09:24 PM | #4 |
Rep 123
Actually, a fellow forum member pointed out that the post July 2013 builds have a 4" (catted) pipe as stock. That's why those N55s make an extra 15 bhp with the MPPK. No need for a bigger downpipe.
04-22-2014, 10:06 PM | #5 |
Rep 159
04-24-2014, 09:37 PM | #6 |
BimmerPost Supporting Vendor
24446
Rep 191,382
You will get more power with catless downpipes no matter which tune you have.
Its just a lot easier and faster for the turbos to reach desired boost target
04-25-2014, 10:27 AM | #8 | |
Diligentia Vis Celeritas
558
Rep 1,477
Drives: 335i
So for a 2014, what is the consensus on the most effective way to get a little bit more performance (i.e. reduced turbo lag, increased throttle response, and maybe a little bump in power), as well as a more aggressive sound - without CELs? (I have MPPK and MPE, so I'd prefer to work with these upgrades... ) HFC down pipe - no appreciable gain? Charge pipe - no appreciable difference other than being less prone to failure under high boost? Any other restrictive piping that can be upgraded from the down pipe to the axle-back MPE?
Ahead of the curve for specF30
04-25-2014, 11:09 AM | #9 | |
Rep 161
04-25-2014, 01:11 PM | #10 | |
Rep 123
The elephant in the room is the environmental impact of going catless, and I don't see that discussed much. I am not a tree-hugger, but I also want to do my part for the greater good. [End of soapbox speech] With the 4" catted pipe, there is something of a cake and eat it too situation. |
04-25-2014, 01:24 PM | #11 | ||
558
Rep 1,477
Drives: 335i
I've heard some conflicting info as to whether the stock piping back to the exhaust is a choke point or not... (and now it seems like the possibility of a larger down pipe on the 2014s is yet another variable in getting the real story here). It would be great to get some definitive info on what replacement parts will actually improve performance (throttle response and turbo lag, or more power) as well as sound, without throwing CELs.
04-25-2014, 05:22 PM | #12 | |||
Rep 1,112
05-03-2014, 08:56 AM | #13 | |
Rep 54
I'm really considering a HFC downpipe. It seems like the most cost effective solution for increased gains without a tune (I have the new MPPK). Tough to pull the trigger on the purchase without really knowing what the gains should be, as well as whether it'll throw a CEL or not. |
05-03-2014, 09:44 AM | #14 | |
Rep 123
05-03-2014, 11:39 AM | #15 |
Rep 54
yeah, not sure what kind of performance gain you would see if swapping out the stock 4" downpipe for an aftermarket one. have to assume that there would be some gains involved, right?
05-03-2014, 12:06 PM | #16 |
Rep 123
I would guess that the majority of the gains that BMW left on the table were from the 3.5" restriction.
05-03-2014, 02:48 PM | #17 |
558
Rep 1,477
Drives: 335i
The cats in the stock DP probably add some restriction too... maybe it would be the best bang for the buck to just replace the stock cats in the 2014's 4" DP with a single, less restrictive cat.
