My dyno results
04-26-2014, 05:58 PM | #6 | |
Rep 3,093
Nice numbers there mate.
04-26-2014, 08:36 PM | #7 |
Rep 1,031
Drives: 335 E92 DCT
Nice
04-26-2014, 09:48 PM | #8 |
Rep 6,285
Nice work, do you know what are normal numbers on that dyno for a FBO N54? No doubt the FMIC should yield some extra power!
Advan's dyno generally reads closer to 300 for guys running FBO and E85? Does she run any different on ethanol? (idle fine etc?) |
04-27-2014, 05:17 AM | #10 |
Rep 1,165
Drives: f83 / E93 335 / E70 X5 40d
04-27-2014, 08:26 AM | #12 | |
Rep 186
What are your mods and what tune are you running? Your power curve looks a little bumpy, there's a few spikes in it. With a jb4, and the e85 back end flash with downpipes, intercooler should be around the 285ish mark. So you could probably squeeze a bit more with the right flash. |
04-27-2014, 09:12 AM | #13 |
Rep 1,426
Mod list by order
- cf wing - jb4 - stett intake - stett charge pipe and tial bov - bmw performance exhaust - vrsf catless dump pipes - BCBR coilovers dont know if jb4 is better than procede but i have the jb4 and map5 is pretty good if you want to run e85. i wouldnt recommend using it as a daily though as i heard it is corrosive towards anything that isnt metal. unless you have metal fuel line and injectors. |
04-27-2014, 09:13 AM | #14 | |
Rep 1,426
04-27-2014, 09:18 AM | #15 |
Rep 1,426
oh, the tuner said that the afr graph doesnt look so healthy but there was an 2014 m5 that ran last and it has the same curve as mine. can someone please tell me that its normal for our cars to run a bit lean. maybe due to tougher european emission standards?
04-27-2014, 09:26 AM | #16 |
Rep 441
Drives: 2008 335xi sedan
Well i just had a real blonde moment lol. I couldnt figure out how with fbo and e85 you were only making 273whp and why no one else was questioning it. Finally just realized that its 273kw lol
04-27-2014, 02:49 PM | #19 |
Rep 441
ya I googled the coversion but I was still scratching my head for a good 2-3 minutes before I realized in was in KW
2008 335xi Sedan in Monaco Blue/Beige Dakota Leather/Cold Weather/Premium Package/ Navigation/ Logic7
Alpina B3 Flash, JB4 G5, BMS DCI, BMS OCC, VRSF DP, VRSF 7" FMIC, 30% tint, matte black kidney grills, paint matched e90 spoiler, paint matched front splitter, black finishing rods, BMW OEM Blacklines, Cyba air scoops, powder coated matte black wheels, Koni + Eibachs, more to come. |
04-27-2014, 06:26 PM | #20 |
164
Rep 1,460
AF looks OK for the Proceed, COBB will look a lot better.
Power is down and falls off badly. I would say it was pulled down to hard on the dyno, the car should ride up on the rollers and rest on the front chocks to get a true/best result. |
04-27-2014, 10:04 PM | #22 | |
164
Rep 1,460
BUT yes 100% the rear wheels should ride up on the front set of rollers, there are some cars that cant do this but this is through lack of power or torque to pull itself up onto the front rollers in this case you do what you can to get the best CONTESTANT result. Dyno's can be a pain to operate sometimes, as your trying to manage wheel spin, air temperature, oil temperature, water temperature, tyre temperature, operate the keyboard, drive the car and hand controller, operate the laptop, and read three screens all at the same time, on top of this its about 50deg in the car and exhaust noise is 110+DB. Well this is the case when tuning a hi-powered 400+kw atw monster and all this with out blowing up a $40,000 engine Just find a dyno shop that actually does some tuning as chances are they know what they are doing. If you want to have a shop run up your car but are worried about there ability have them show you some dyno sheets and explain to you what it all means, a good graph should fill the page and be easy to understand. |
