California 'Cats are running wild.'
05-09-2014, 04:21 PM | #1 |
Rep 1
Hi all, Long time reader, second time poster. Father of a Beautiful Girl 07 e90. Our second to her older sister 86 e30.
Check engine light came on (72000) out of the blue yesterday, as a concerned father she went to see the doctor. Not the BMW shop (she was adopted with 50K on her speedo) but to the local guy who has the identical car. There is a a fair amount of trust with him. I'm told her Cat is bad. I am in Southern California, Catalytic's are very important here. Reading up, there are two cats. This is a part I am not familiar with failure on. I have also never had a car with a stainless steel gas tank because emissions before. 1. Is this normal? 2. Some threads mention testing again to confirm that its not the Cat. 3. Previous cars tell me check engine for Timing Belts that fail (is this a concern?) Any fellow Southern Californian's experienced this? In short, am I getting snowed on a summer day? This seems like an odd part to go out. I can replace it but I don't want to chase further errors. Thank you for your help and all your help in the past. |
05-09-2014, 07:43 PM | #4 | |
Rep 1
My questioning the cat being bad, I am unfamiliar with this part failing like this on a car with limited (less than 250K miles) and one that has no rust problems. There is no idle difference from before and after. Thanks. Is this a common problem? Thanks again. |
05-10-2014, 10:24 AM | #5 | |
Rep 461
05-11-2014, 06:22 PM | #6 |
Rep 1
05-12-2014, 02:06 AM | #7 |
Rep 303
Did you start having the problems diagnosed before 70K miles? If you did then under CA emissions warranty code it would be covered under the 7yr / 70K mile warranty. If it's just passed the 70K then you may want to go to a BMW dealer and work w/ them to see if BMW will work w/ you and still cover it under warranty.
05-12-2014, 02:41 AM | #9 | |
Rep 303
05-12-2014, 07:33 AM | #10 | |
Rep 461
I am very curious as to what code they saw to come to that conclusion. I would ask them for the codes they pulled. This is the first I hear of a bad cat on this platform. And as others have said emission components are covered under warranty. |
05-12-2014, 01:06 PM | #11 |
Rep 2,973
If the cats are actually bad.
http://www.arb.ca.gov/msprog/warranty.pdf you say it's got 72K miles. Contact BMW. In Ca. cats are covered 7 years/70k miles. 72K, ask BMW for some help.
Arctic Metallic\CF Splitters, Spoiler, Mirror Covers\LED Tails\LSD\Tinted\Coded\Apex Square SM10-19"\LED Angel Eyes\Gloss Black Grill\Integrated V1 & Galaxy Tab\M-Performance Brakes\Cobb Tuned\xHP Flash\Resonator Removed and -> is your friend.
