05-11-2014, 06:01 PM | #1 |
Rep 14
WTS: BNIB Rupes Big Foot Duetto Random Orbital Polisher LHR 12E Deluxe Kit
BNIB Rupes Big Foot Duetto Random Orbital Polisher LHR 12E Deluxe Kit So Like the title states I have a Rupes Big Foot Duetto Deluxe Kit for sale, Brand new in the box. Kit Retails for 599.99 on Ebay, Autogeek sells for 499.99 and DetailedImage sells for $485. I am selling for 465.00 Shipped to your door! Paypal Verified Payment is the only accepted form of payment. Questions or Concerns can be addressed via PM. Details about the Kit which are copied from Autogeek's Site: Italian-engineered for the perfect finish! The Rupes LHR 12E Duetto Random Orbital Polisher Deluxe Kit is the quintessential example of what happens when a tool company listens to their customers. Designed entirely on customer feedback, this complete polishing kit includes the powerful and lightweight Rupes LHR 12E Duetto Random Orbital Polisher and everything you need to damp-sand, cut, and buff your car to a flawless finish. Rupes compounds, foam pads, and machine sanding discs represent the best the industry has to offer. If a perfect finish is what you seek, the Rupes LHR 12E Duetto Random Orbital Polisher Deluxe Kit is for you. The Rupes LHR 12E Duetto doubles as a sander and a polisher! The Rupes LHR 12E Duetto is the result of countless hours of research and development to design what is arguably the most user-friendly dual action polisher available. Building upon the legendary "Big Foot" moniker set forth by the larger and more powerful LHR 15ES and LHR 21ES, the Duetto continues the Rupes tradition of engineering polishers that have a larger orbit (throw) than anything else on the market. The LHR 12E Duetto, the little brother to the larger LHR 15ES, features a respectable 12 mm orbit, enabling it to be a sander and polisher. Rupes is a company that takes customer feedback seriously, and the LHR 12E Duetto is proof. Designed with the professional detailer in mind, the Rupes LHR 12E Duetto is thoughtfully engineered with superb ergonomics and user-friendly switches and dials. The Rupes LHR 12E Duetto will provide hours of sanding and polishing with minimal user fatigue. The powerful 400 watt motor provides enough juice to keep the pad rotating, making the LHR 12E Duetto capable of removing heavy swirls, water spots, and scratches. Rupes LHR 12E Duetto removes swirls and water spots without burning paint!Dual Function: Sanding & Polishing The Rupes LHR 12E Duetto and its 12 mm orbit can be used with fine grit abrasives to speed up deep correction operations. The tool can then use foam pads and polishing compounds to refine the abrasive scratches and restore a flawless finish. Ergonomically Perfect With its non-slip rubber inserts on the front cover, the Rupes LHR 12E Duetto is perfect for all polishing operations in difficult to reach areas. The operator can produce the best results possible with little to no fatigue. Anti-Spinning Shroud The dual function anti-spinning shroud is designed to protect the operator against the moving parts and act as a clutch for the backing plate, preventing further stress on the foam polishing pad when it is not in direct contact with the surface. Design The attention to detail is not limited to just the innovative and attractive design. The modern lines and exceptional technical quality are combined with a number of details that are the result of meticulous research aimed at achieving maximum operator comfort. The non-slip rubber inserts are numerous and have many functions. In particular, the insert on the machine body is used to support the polisher when placed on a surface. Electronic Speed Control Module The speed controller is both practical and easy to use. The speed of the polisher can also be easily adjusted without interrupting the work. Rupes LHR 12E Duetto Random Orbital Polisher Deluxe Kit includes: Rupes LHR 12E Duetto is a smooth and powerful Italian-made dual action polisher Rupes LHR 12E Duetto Random Orbital Polisher The Rupes LHR 12E Duetto is the result of countless hours of research and development to design what is arguably the most user-friendly dual action polisher available. Building upon the legendary "Big Foot" moniker set forth by the larger and more powerful LHR 15ES and LHR 21ES, the Duetto continues the Rupes tradition of engineering polishers that have a larger orbit (throw) than anything else on the market. The LHR 12E Duetto, the little brother to the larger LHR 15ES, features a respectable 12 mm orbit, enabling it to be a sander and polisher. Rupes LHR 12E Duetto features a 5 inch backing plate Rupes LHR 12E Duetto 5 inch Backing Plate This high-quality backing plate was designed specifically for the Rupes LHR 12E Duetto. The Rupes LHR 12 Duetto also features a dual function anti-spinning shroud that is designed to protect the operator against the moving parts and act as a clutch for the backing plate, preventing further stress on the foam polishing pad when it is not in direct contact with the surface. Rupes Big Foot Soft Bag has enough room to swallow all of your gear! Rupes Big Foot Soft Polisher Bag The Rupes Big Foot Soft Polisher Bag swallows your Rupes polishers (more than one of them!) with room to spare for your pads, polishes and other misc polishing accessories that you keep close by for each detailing job. The bag is constructed of ultra-rugged, water resistant nylon canvas that is built to last - even in the hands of the most active detailer. Tote your Rupes polishers in style with the Rupes Big Foot Soft Polisher Bag! Rupes Big Foot Detailing Apron keeps your paintwork protected as you polish! Rupes Big Foot Detailing Apron The Rupes Big Foot Detailing Apron is a stylish, one-size-fits-all detailing apron that’s designed to keep you clean and protect your vehicle’s delicate paintwork as you polish. Made of 100% polyester, the Rupes Big Foot Detailing Apron lightweight and comfortable to wear and will not scratch your vehicle’s finish. The front of the Rupes Big Foot Detailing Apron has pockets to store pad brushes, car keys, buffing pads and more! Rupes Zephir Gloss Coarse Gel Compound quickly removes deep paint imperfections including swirls and scratches 8 oz. Rupes Zephir Gloss Coarse Gel Compound Rupes Zephir Gloss Coarse Gel Compound is the 1st step in the Rupes Big Foot Polishing System. This ultra-heavy cut compound utilizes advanced abrasive technology that quickly eliminates up to 1500 grit sanding marks on fresh paint while leaving minimal haze. Rupes Zephir Gloss Coarse Gel Compound is designed to be used with a Rupes Blue Coarse Foam Pad. Rupes Keramik Polish is the third step in the Big Foot Polishing System 8 oz. Rupes Keramik Gloss Fine Gel Polish Rupes Keramik Gloss Fine Gel Polish is the 3rd step in the Rupes Big Foot Polishing System. Ultra fine abrasives smooth over minor imperfections including swirl marks and clay-induced marring in all paint systems. Rupes Keramik Gloss Fine Gel Polish is exceptionally easy to use and is the perfect follow-up step to a more aggressive polish or compound. Rupes Keramik Gloss Fine Gel Polish is designed to be used with a Rupes Yellow Polishing Foam Pad. Rupes Blue Coarse Foam Pad quickly eliminates swirls and scratches 2 Rupes Blue Coarse Foam Pad, 6 Inches This pad is the first step in the Rupes Big Foot Polishing System. The Blue Coarse Foam Pad is very aggressive in its construction and was designed to be used with Rupes Zephir Gloss Coarse Gel Compound. This combination of pad and product, when used on the Rupes LHR 21ES, is capable of removing up to 1500 grit sanding marks on fresh paint. Swirls, light scratches, water spots and other paint imperfections will be effortlessly removed with this pad. Always follow this pad with a less aggressive pad/polish combination to maximize gloss and surface smoothness. Rupes Yellow Polishing Foam Pad is soft enough to provide a swirl-free finish 2 Rupes Yellow Polishing Foam Pad, 6 Inches This pad is the third step in the Rupes Big Foot Polishing System. The Yellow Polishing Foam Pad was designed to be used with Rupes Keramik Gloss Fine Gel Polish to remove light swirl marks, holograms, clay-induced marring, and other light paint imperfections. This pad finishes exceptionally well considering the mechanical polishing ability that it provides. Rupes 5 inch interface pad is designed to be used with the Rupes LHR 12E Duetto Rupes 5 Inch Interface Pad The Rupes 5 Inch Interface Pad is designed to sandwich between the backing plate and the sanding disc. It provides cushion for the sanding disc, making it possible to keep the disc flat on curved body panels. Rupes sanding discs are designed to be used on the LHR 12E Duetto 3 Rupes 5 Inch 2000 Grit Sanding Discs Use the Rupes 2000 Grit Sanding Disc on the LHR 12E Duetto to eliminate orange peel and other paint flaws. The long-lasting and fast-cutting abrasive is designed to create uniform material removal. Rupes Sanding Discs are designed to be used on the LHR 12E Duetto polisher 3 Rupes 5 Inch 3000 Grit Sanding Discs Use the Rupes 3000 Grit Sanding Disc on the LHR 12E Duetto to eliminate light orange peel and other paint flaws. The long-lasting and fast-cutting abrasive is designed to create uniform material removal. The 3000 grit sanding disc refines the surface after using the 2000 grit sanding disc, making your sanding marks easier to remove. Rupes Microfiber Polishing Cloths are soft and clear coat safe! 4 Rupes Microfiber Cloths Use these soft, high quality microfiber cloths to remove compound and polish residue. Flat-weave design provides the "bite" necessary to remove stubborn compound residue, especially in humid environments. Kit includes: Rupes LHR 12E Duetto Random Orbital Polisher Rupes LHR 12E Duetto 5 inch Backing Plate Rupes Big Foot Soft Polisher Bag Rupes Big Foot Detailing Apron 8 oz. Rupes Zephir Gloss Coarse Gel Compound 8 oz. Rupes Keramik Gloss Fine Gel Polish 2 Rupes Blue Coarse Foam Pad, 6 Inches 2 Rupes Yellow Polishing Foam Pad, 6 Inches Rupes 5 Inch Interface Pad 3 Rupes 5 Inch 2000 Grit Sanding Discs 3 Rupes 5 Inch 3000 Grit Sanding Discs 4 Rupes Microfiber Cloths Made in Italy. 1 year warranty.
2008 Sparkling Graphite Metallic 135i
Rear Fogs, F10 M5 Shift Knob, Blackline LCI Taillights, Berk Race Exhaust, BMS DCI, Sport Package, Coral Red Interior, Smoked Turn signals BMS 4 LED AE Lights, ER Charge Pipe, Synapses BOV Tuner Magazine 1K+ Likes on Facebook! |
10-07-2014, 03:29 PM | #2 |
Rep 194
is this new or used?
2012 LeMans Blue Metallic 135i Coupé - SOLD
2013 Mineral Grey Metallic 335i Sedan - Returned 2012 Black Sapphire Metallic 135i Coupé Still keeping it classy with a Clutch.. |
