E90Post
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Regional Forums > Canada > hsd coilovers for 335i? install problems
Reply
      06-08-2014, 10:40 AM   #1
specialist
Drives: 335i
Question hsd coilovers for 335i? install problems
Has any installed them on their car?335i coupe
If so I wanted to to know how do you install the front suspension.
There is a black sleeve that does not fit in the front spindle. I didn't want so clamp on the threads. Any one else have this problems
      06-08-2014, 08:33 PM   #2
jim.e.
Drives: 07 E90
From what I can see, the black part on the front shock does not go in. Just the silver part.
      06-08-2014, 09:26 PM   #3
MyF15+F85
MyF15+F85's Avatar
50
Drives: 2015 F85 and 2015 F15
HSD
I hope that you have figured it out by now, if not ... maybe you should not attempt to install yourself ? Don't take it the wrong way but it is easy.
      06-15-2014, 09:31 AM   #4
specialist
Drives: 335i
I have never seen a coil over that you clamp on the threads. I have done coil overs on high end cars. I just finished a f430 last week. Also I have found out the answer you do clamp on the threads. What a bad design. I just should should of bought kw
      06-15-2014, 08:53 PM   #5
Evochuck
Drives: 335xi 09
Seems likes youd have to pry open the mount so you can fit the black sleeve in, that way the shock body is adjustable in height.
      06-16-2014, 06:34 PM   #6
e92m3jb
Drives: 08 m3
All e90 use this set up no matter what manufacturers
      06-16-2014, 08:26 PM   #7
specialist
Drives: 335i
If you look at the kw v2 look at the front shocks. Look at the bottom half after the sway bar link bracket. There are no threads so when you install them in the front spindle they DO NOT KRIMP on the thread of the coil.
Please see HSD picture above. I could show you i have both sets at my garage.
Why do you rip on me i am just trying to get answers. I am not a dumb ass.
When i go to shop tomorrow i will take a pic for you
      06-16-2014, 08:35 PM   #8
specialist
Drives: 335i
Here is a pic of a front JOM COILOVER Strut. If you look closely the thread will not be in the front Spindle like the kw v2.
I took these of my car i needed something better. Also tomorrow i will use my digital calliper to measure the diameters of the hole and the struts.
      06-17-2014, 03:54 AM   #9
TOPEC
<3 Flat Four
Drives: 335is LM Blue
specialist im pretty sure u r wrong, do u have the HSD coilovers? if so can u post a pic close up of the front lower shock body?
2011 335is Le Mans Blue
2016 X5 xdrive 35i Alpine White
      06-17-2014, 10:12 PM   #10
specialist
Drives: 335i
JOM Coilover Front
HSD Coilover Front
I took my car apart - Here are some pics
Slides right in
Same diameter as the black piece
      06-17-2014, 10:55 PM   #11
Evochuck
Drives: 335xi 09
Sounds like you either need to pry it open enough to fit the black piece in or have it machined so its a tad thinner.
      06-17-2014, 11:25 PM   #12
specialist
Drives: 335i
The spindle is about 52 inch/mm to stretch it out to 60 inch/mm that is nuts
      06-17-2014, 11:26 PM   #13
specialist
Drives: 335i
What do you think i want to know your thoughts about this?
      06-18-2014, 12:43 AM   #14
TOPEC
<3 Flat Four
form the looks of it, yes the black piece goes into the spindle so the spindle clamps onto the black ring and the strut body threads in and out to adjust height.
2 possibilities here, its meant to spread the spindle, or the manufacture screwed up the measurements, im guessing its meant to have the spindle spread so its a extremely tight fit. its just 9.1mm of difference, not that big actually
      06-18-2014, 08:56 AM   #15
specialist
Drives: 335i
to spread that spindle is soo hard i tried for a least 20 min with a big pry. I wanted to heat it but that is a really bad idea. The best way if i wanted to put the black piece is get another set of spindles and machine it bigger to fit it
      06-19-2014, 12:37 PM   #16
specialist
Drives: 335i
I guess no one has any ideas
      05-26-2018, 10:45 AM   #17
salimshk
Drives: BMW 330d M Sport Coupe
Anyone figure this out?
      05-26-2018, 10:52 AM   #18
6ixSpd
Save the manuals!
6ixSpd's Avatar
6035
Drives: '16 M3, '23 718 Spyder
Just get proper coilovers instead of ill-fittinf cheap crap? :
'16 M3 | '23 718 Spyder
Past: E92 M3, F87 M2, E39 M5, etc
      05-26-2018, 10:58 AM   #19
salimshk
£800 is cheap crap? Plus I've already bought em. Bank holiday weekend and I'm sitting here with my dick in my hands because I can't figure out how the bloody thing goes in. I can understand Specialist's frustration now
Reply
e90post
