06-13-2014, 12:29 PM | #1 |
Rep 6,958
Drives: 2018 M2 AW DCT
Mirror cap replacement
Can someone post the instructions for replacing the mirror caps on an M235i?
I just bought the M Performance caps from Sun Motors. Great price by the way. At their price I decided not to try the after market ones. |
06-13-2014, 12:46 PM | #2 |
Rep 333
I believe you can just pop them right out with your hands firmly press against them.
The OEM ones are in $500-600 range, right? The aftermarket ones are like $100-150. Maybe I'm too cheap but I'd rather spend the money elsewhere since I can't tell the difference from two feet away when they are on the car. |
06-13-2014, 04:59 PM | #3 |
Rep 8,942
Grab the corner on top, closest to the car and pull hard. It will pop right off. I found it hard to get a good grip on the top edge.
06-20-2014, 07:07 PM | #4 |
Rep 6,958
The M Performance mirror caps are a bear to put on. They are held in place by three screws. They require disassembly of the mirrors.
I gave up and had the dealer install them. One added note: they do look great once installed. Last edited by DanG; 06-21-2014 at 11:00 PM.. |
06-23-2014, 12:02 PM | #5 | |
Rep 8,942
2022 Macan S
2016 F31 328i xDrive Sport Wagon 2006 E46 330ci ZHP Convertible |
06-23-2014, 12:42 PM | #6 |
Rep 75
06-23-2014, 12:50 PM | #7 | |
Rep 6,958
06-23-2014, 01:24 PM | #8 | |
Rep 75
06-23-2014, 01:46 PM | #9 |
Rep 1,254
I believe it is very similar to these DIY's on E90
http://www.e90post.com/forums/showthread.php?t=74675
06-23-2014, 02:22 PM | #10 | |
Rep 6,958
Here it is also: http://ind-distribution.com/ind/m235...d-mirror-cover |
06-23-2014, 02:52 PM | #11 | |
Rep 75
Thanks DanG |
06-23-2014, 04:28 PM | #12 | ||
Rep 8,942
2022 Macan S
06-23-2014, 04:47 PM | #13 |
Rep 75
06-23-2014, 05:31 PM | #14 |
Rep 6,958
06-23-2014, 06:11 PM | #15 |
Rep 8,942
Just be careful to line them up and push them straight on. They don't clip in then rotate down to lock or anything like that. The first one I kind of fucked up but was lucky and got it off without breaking anything and did it properly the second time.
2022 Macan S
06-24-2014, 09:33 AM | #16 |
Rep 197
+1. it is very difficult to get your fingers under the edge b/c the gap is small. i had to use a plastic tool to pry up one of the corners and then work my way around until they popped off. once you have the stock caps removed, the CF knockoffs snap on very easily.
06-29-2014, 07:24 AM | #17 |
Rep 1,756
Why don't they give the option of colour coded mirrors on the M235i? I really don't like the silver ones that come as standard, they would be better off just painting them the same as the car and giving a carbon option from the factory
06-29-2014, 07:26 AM | #18 |
Rep 1,254
+1 i had mine painted body color along with the diffuser
06-29-2014, 10:46 AM | #19 |
Rep 210
You literally just pull them off as everyone has mentioned.
The CF mirror caps are the only non-BMW part I bought as for $150 vs $500 for nearly identical looks, it was an easy choice. These are the full 1:1 replacement housings. Looks great with the 18% ceramic tint. Really makes the grey mirrors seem like such an odd choice by BMW. |
06-29-2014, 03:39 PM | #21 |
Rep 1,254
I would think around 200 if you take it off yourself maybe 250 if they do it. It was part of my deal when I bought the car from the dealer. So I don't know the actual cost.
