SnowCover wrote got a new iPhone 16 Pro Max. it keeps overheating when charging and then shuts down. when I'm only using it for music streaming, the temperature warning comes on in about 10 minutes, but the phone continues to work, even with the message that the phone needs to cool off. However, if I'm using music streaming and navigation(Apple Maps), then the phone overheats and shuts down in less than 5 minutes. It does not ever overheat or shutdown if I connect it via the USB-C cable, however.
It just happened about an hour ago when I left home at 6AM. Outside temperature was about 60 degrees. The AC inside the X1 was set to the usual 68 degrees. The phone was in the wireless charging pad with the roller coaster bar closed. The screen went dark and I looked at the phone and it had turned itself off. When I got to my office at 6:30AM, I was able to turn the phone back on again.
is this a problem with the iPhone 16 PM or the X1 wireless charging pad?
The charging pad in the X1 is essentially a “trickle” charger. It won’t charge a phone if there is less than 50% battery available, and if over 50%, will only charge about 10% an hour. I have that in writing from the service department of my dealer, as I have the same issue, but not limited to the iPhone 16 Pro.
