      04-26-2012, 03:14 PM   #23
mattm
mattm's Avatar
Drives:
And I was thinking the Hoosiers ground that away like sand paper.
Matt Murray
I am perfectly capable of learning from my mistakes. I will surely learn a great deal today.
      04-26-2012, 10:02 PM   #24
kabalm18
My car drones and I LOVE IT!!!
kabalm18's Avatar
Drives: 1M & F10 535xi
Yep, that is what mine look like.
      04-26-2012, 11:39 PM   #25
Papethova
Drives: '08 135/ '11 1M
Then I guess its safe to say its not a new part but rather a different mounting position. Hopefully we can figure this out before my wheels come in and I have to cut to fit.
      04-27-2012, 04:27 PM   #26
To rub or not to rub, that's the question
Originally Posted by Pete_vB View Post
If you're talking about deformation on the middle 3 fins then yes, that is molded in.
Affirmative: different design of the middle three fins/notches + indent is OEM. Below some pictures (June 2011 build). Small black triangles at the bottom of some fins/notches: tell-tale signs of the "love story" between front tires and fender liners...
Front left:
Front right:
Actually, so far no clarity about that. Anyway, as for now, the heat gun might be your 1M's clearance friend (but do handle with care). At least resolved the clearance issue on mine.
Below two pictures posted on the German 1M forum (the second picture is of an early 2012 build 1M). Do you see any difference in design and/or mounting ?
(source: http://www.1erforum.de/bmw-1er-m-cou...ml#post1438743)
(http://www.1erforum.de/bmw-1er-m-cou...ml#post1438926)
      04-27-2012, 07:12 PM   #27
Papethova
They all look the same to me, do you see a difference??
      05-02-2012, 01:51 PM   #28
lcrain
Drives: e36 m3, TT-RS
Anyone in the US have this change made?
I am noticing a rub when turning to the left (mostly when backing up) in the front right fender. I have not noticed the left front fender rubbing. Not only is this annoying (least of my concerns) but I don't want to mess up the fender liner or the tire!
      05-03-2012, 04:19 PM   #29
Originally Posted by EmmDrei View Post
Thanks Artemis! I have my summer wheels back on for a week now. Had no problems with my 18" winter tyres, but when I now turn my wheel while reversing with the 19" stock setup, the right front tyre rubs.
As quoted above, a German 1M owner reported (Apr 14, 2012) that his 1M front fender liners were replaced upon initiative of his dealership (he visited his dealership for another reason and they spontaneously raised the topic themselves):
"I visited my dealer for another reason.
There I was informed, without [my] request, that the front fender liners must be replaced. Info from BMW. Upon query for the reason [of the replacement] the answer was something along the lines of «rubbing of the front wheels against the fender liners at full lock during reverse driving»".
("Ich war wegen einer anderen Geschichte bei meinem [dealer].
Da wurde mir ohne Nachfragen mitgeteilt, dass die vorderen Radhausschalen getauscht werden sollen. Info von BMW. Auf Nachfrage warum war die Antwort war in etwa.....Schleifen der Vorderräder an der Radhausschale mit eingeschlagenen Rädern beim rückwärts fahren."
http://www.1erforum.de/bmw-1er-m-cou...ml#post1451049
So if you experienced/noticed fender liner rubbing (check especially the front right), then keep your ears and eyes open during your next 1M service visit to the dealership. It might be that they raise the issue before you do.
Here's a take on the issue, via two pictures of stock 1M wheels and tires, by a Belgian bimmer forum member (Andra): the "indent zone" of the fender liner should be sitting a little lower, more particularly in the tire versus fender liner "contact zone" (source: http://www.bimmerboard.be/forum/inde...opic=26797.315). Seems to make sense IMHO.
Size:  18.8 KBName:  Stock_1M_Wheel_2.jpg
Furthermore, he correctly pointed out that rubbing tires can be a reason to fail a pass at the motor vehicle inspection in Belgium.
      05-03-2012, 04:27 PM   #30
kabalm18
kabalm18's Avatar
Maybe this is BMW's way of telling us that we must lower our cars. We need to make the touch zone fall into the indent after all.
BTW, can we post pictures while using the app?
      05-03-2012, 04:47 PM   #31
Actually, it could make sense what you jokingly commented: it ain't excluded that the 1M was sitting a little lower in the fenders during development (no contact tire versus fender line due to compliant indent height), but suspension was fine-tuned a little higher in the final stages of the 1M development (more ground clearance). Fast development, as we all know. Consequence: rubbing due to a lower sitting "contact zone" ("indent zone" located a little too high) = compliance issue.
      05-10-2012, 05:24 AM   #32
Grey Dove
Grey Dove's Avatar
Drives: Sold for a reptile
Aproved by the BMW inspector and gettin mine mounted may 25th.
The improved ones have a different mounting system.
      05-10-2012, 05:55 AM   #33
Originally Posted by gs/e60/1m? View Post
Approved by the BMW inspector and getting mine mounted May 25th.
Thanks for the info. Spread the word !
      05-10-2012, 06:45 AM   #34
eeghie
Kind of a big deal
301
Drives: an 1M not often enough
Approved by the BMW inspector and getting mine mounted may 25th.
any idea what the difference in mounting is?
      05-10-2012, 10:48 AM   #35
Grey Dove
Grey Dove's Avatar
Nope sorry
But I got clearance to step onto the workfloor and watch
      05-10-2012, 10:54 AM   #36
Pete_vB
Pete_vB's Avatar
Drives: '69 GT3, GT4, 1M, 912
Nope sorry
Sweet- take some pictures for us if you can.
1M, GT4, 1969 Porsche 911 w/ 997 GT3 Cup Motor (435hp & 2,100 lbs)
      05-10-2012, 11:25 AM   #37
Grey Dove
Grey Dove's Avatar
i'll try to not forget my camera
      05-10-2012, 11:32 AM   #38
mPlasticDesign
mPlasticDesign's Avatar
684
Drives: BMW 230i Msport w/LSD
Location: Astral Projecting: ∞ 23.516 -122 02.625 0242.101 ĕv'rē-hwâr'
Mine is lowered(HR sport) and no rubbing, but very little clearance!
      05-13-2012, 05:19 AM   #39
Thanks in advance for checking also the following during the replacement:
Any change in part numbers ?
  • front left = part# 51 71 8 051 591
  • front right = part# 51 71 8 051 592
Any change in shape or its mounting holes (see picture below) (note the indications "E82M L" and "E82M R"):
      05-25-2012, 03:29 PM   #40
Grey Dove
Grey Dove's Avatar
I had my front liners changed today under warranty.
The parts have the same code but no changes in the moulding form or mountings.
So bottomline much a do for nothing.
But I have some other serious probs. The upper and back liners at the front wheels showed some major holes due to wheelrubbing. I think this could be related to tracktime @ Spa. I've noticed a hole in the left wheel liner whereas there was none on the right side and Spa track has more right curvers/corners.
Pic below shows rubbing and bare metal
      05-25-2012, 05:57 PM   #41
Many thanks for the update, gs! I thought about you yesterday because you had mentioned the date of the replacement works.
Quite worrying to see the merciless impact on the fender. Also does not seem healthy for the tires longevity.
Have you noticed the reference on the sticker: "Achtung! E-82 M.Pyrat" ? Perfect idea for a decal on the outside of, for example, EINSER M.
      05-25-2012, 06:08 PM   #42
EINSER M
EINSER M's Avatar
Drives: BMW i3 rex
mort de rire Artemis!
i added NITTO tires as sponsor on the car and working on one more from DPE wheels USA. soon soon soon i hope!
      05-25-2012, 10:36 PM   #43
Papethova
Be careful, tire rubbing could lead to tire failure. I was in a car on the track with serious tire rubbing and we had no idea.
One lap after I got out the tire blew (120mph+) and the car slammed into the outside wall of a large banked curve , driver almost saved it.
      05-26-2012, 05:16 AM   #44
eeghie
Kind of a big deal
301
So no corrective action, just free replacements throughout the warranty period!?
1addicts
