04-25-2012, 04:01 PM | #1 |
Rep 13,138
Warranty: BMW replaces free of charge 1M front fender liners (rubbing issue)
We all experienced that, also with the stock 19" rims and tires (359 M Y-spoke Competition + PS2) at recommended tire pressure, clearance between front tires and front fender liners is a close call.
Apparently some 1M owners complained about rubbing issues with the stock 270M 18" winter set-up offered by BMW (especially front right when full lock to the left): unsafe encounters between tire and line fender, too close for comfort (safety and tire longevity issue). A German 1M forum reported that BMW apparently addressed the issue and now replaces - upon customer's request and free of charge - the front fender liners. No official product recall, though: you gotta ask for it and the dealership will take care of it (reference is made to a BMW letter, however no copy has surfaced yet). Part numbers remained unchanged:
(source of the diagram: http://realoem.com/bmw/showparts.do?...61&hg=51&fg=70) Maybe BMW did not change the fender liners design but rather optimized the way these are fitted inside the wheel fender (closer to the cooler, to create more wheel clearance) ? Anyways, those with replaced fender liners reported that the rubbing issue has been resolved or at least reduced. Anyone outside Germany heard about this warranty issue and/or got the front fender liners replaced in the meantime ? BMW seems to take this matter seriously, which we all should appreciate of course. The BMW PuMA case reference is 49636119-01. With this reference any BMW dealership can retrieve info about this issue, as reported by BMW. ("PuMA" ("Problem und Maßnahmenmanagement Aftersales" = "Problem and Measures management Aftersales") is a worldwide BMW database of all reported problems and most with the their appropriate fixes. It's BMW's online technical hotline for dealers. Info is considered to be confidential. If an issue is not reported yet, the dealer fills out a form for submittal to BMW's technical gurus and subsequently they send back a response outlining what BMW wants the dealer to do to fix the car. Sometimes it's "replace such-and-such" and sometimes they ask for more diagnostic info). Generally speaking: re product recall, we may reasonably assume that BMW will be extra cautious: two months ago it was announced in the press that BMWNA will pay a $3 million fine to settle US government allegations that it failed to promptly notify auto regulators about safety defects and recalls. "While BMW denies that it violated federal law, it agreed to make internal changes to its recall decision-making process in order to «ensure timely reporting to consumers and the federal government in the future.»" http://www.businessweek.com/news/201...t-reports.html http://business.inquirer.net/44115/b...-recall-issues http://gulfnews.com/business/automot...-fine-1.979223 (picture source: http://www.1erforum.de/bmw-1er-m-cou...ml#post1291989)
///M is art ↔ Artemis
Last edited by Artemis; 08-15-2014 at 04:51 PM.. Reason: Added diagram + PuMA case reference |
04-25-2012, 04:19 PM | #3 |
Rep 5,730
Drives: BMW i3 rex
Garage List 2018 I01 i3s | CURRENT [0.00]
2018 G01 X3 | CURRENT [0.00] 2017 I01 i3 | SOLD [0.00] 2017 F48 X1 | SOLD ... [0.00] 2016 I01 i3 | SOLD [0.00] 2017 F22 M240 | SOLD [8.00] 2016 F25 X3 diesel ... [0.00] 2006 E60 550 | SOLD [6.00] 2011 E90 335 | SOLD [8.66] 2012 E82 135 | SOLD [5.50] 2011 E82 1M | SOLD [7.94] 2007 E85 Z4M| SOLD [4.50] 2003 E53 X5 4.6is S ... [9.00] 2008 E92 328 | SOLD [0.00] 2008 E82 135 | SOLD [0.00] 2008 E90 335 | SOLD [0.00] 2003 E46 M3 | SOLD [7.50] 2006 E90 330 | SOLD [10.00] 2003 E46 330ZHP | SOLD [0.00] |
yes! thanx for bringing that up to our attention thank you!
04-25-2012, 04:46 PM | #4 |
Rep 13,138
Same German 1M forum reported already since November 2011 about the fender liner issue (logical: fitting winter tires with the Winter weather approaching - first Winter season for the 1M) and replacement under warranty by BMW since February 2012:
04-25-2012, 04:50 PM | #5 |
Rep 75
I have experienced this very problem with my winter tires mounted on the 270M. Previous to the usage of the winter rims I did not experience any rubbing with the original wheel/tire set up. HOWEVER after going back to the summer tires I experience a slight rubbing. This could be due to the winter tires damaging the fender liners and thus they now have even less clearance. I will talk to my dealer and let him know that this is a general problem and that BMW has agreed to replace the liners.
Thanks for posting this Artemis! |
04-25-2012, 04:54 PM | #6 |
European Editor
10616
Rep 22,992
So... to be clear there is no improved part... just that dealers are replacing the damamge fender liner(with the same part) and installinng them to clear the tires mounted on the car.
04-25-2012, 05:29 PM | #7 | |
Rep 13,138
"Die Innenradkästen wurden bei uns auch getauscht. Der Händler hatte uns diesbezüglich angesprochen. Jetzt schleift der Original Winterradsatz jedenfalls nicht mehr !" - "Also geht auf jedenfall über Garantie lass dir nichts erzählen. Es existiert ein Schreiben bei BMW über die Innenradkästen !" - "Mein Händler hat auch gesagt es laufe über die Garantie" - "Bei mir auch vor ca 3 Wochen Austausch auf Garantie" - "War gestern bei der 2000er Inspektion. Dabei wurden die Radläufe gewechselt" - "Da wurde mir ohne Nachfragen mitgeteilt, dass die vorderen Radhausschalen getauscht werden sollen. Info von BMW. Auf Nachfrage warum war die Antwort war in etwa.....Schleifen der Vorderräder an der Radhausschale mit eingeschlagenen Rädern beim rückwärts fahren" - "Neue Radkasten sind verbaut haben aber die gleiche Teilenummer wie die alten. Also die Räder schleifen noch ganz minim kein vergleich zu vorher aber sie schleifen". http://www.1erforum.de/bmw-1er-m-cou...fe-108152.html Someone reported that, regarding the front fender liners, BMW probably modified its 1M production at the Leipzig plant. This would then be the explantion for the finding that part numbers have not been changed (so more recent 1Ms might already feature the modified fender liners set-up and, hence, will not experience the issue). "Er [dealer] hat sich das angeguckt und auch gesehen und dann im PC nachgeschaut ob es eine Serienstandsverbesserung gibt. Gab/Gib es nicht also können sie auch nix machen" - "Hat mein [dealer] auch gesagt und danach hab ich ihne gebeten sich zu informieren.... 1/2Tag später eine Anruf vom [dealer] ja es gibt auf Beanstandung seitens der Kunden austausch Radkästen! Die werden angeblich von den original Radkästen modifiziert im Werk daher evtl. keine separaten Teilenummer. [Dealer] kanns mir nur so erklären."
04-25-2012, 07:04 PM | #9 |
Rep 5,730
Drives: BMW i3 rex
04-25-2012, 08:30 PM | #10 |
My car drones and I LOVE IT!!!
200
Rep 613
I am glad you posted this. I was looking at the liner a couple of days ago and noticed that an area of the vent part looked to be molded to give room for the tire to squeeze in. I couldn't tell if it was shaped like that by design or if it was caused by rubbing.(I am on the stock suspension and tires.). Now I think I have the modified wheel well liner. Cool.
04-26-2012, 04:05 AM | #12 | |
Kind of a big deal
301
Rep 1,674
Drives: an 1M not often enough
04-26-2012, 04:21 AM | #13 |
Kind of a big deal
301
Rep 1,674
Posted question on the german forum to get the new way of mounting clarified, let's see what they come back with.
04-26-2012, 04:51 AM | #14 |
Rep 401
Drives: 2011 Saphire Black 1M Coupé
Thanks Artemis! I have my summer wheels back on for a week now. Had no problems with my 18" winter tyres, but when I now turn my wheel while reversing with the 19" stock setup, the right front tyre rubs.
I'll have my dealer check what the deal is.
The best piece of road - worldwide.
04-26-2012, 08:58 AM | #15 | |
Rep 3,094
04-26-2012, 09:47 AM | #17 |
Rep 1,358
I saw this issue on the 1m I drove at the performance center. It rubbed the entire time I drove the car and was pretty invasive under certain conditions. They told me it was because they had different tires than stock on the front. Sounded like a hollow claim though considering these are supposed to be factory stock prepped cars. There is definitely some issue with the front right tire coming into contact with something under high load conditions or possibly large steering input. I've read others stating the same on this forum in the past.
04-26-2012, 09:50 AM | #18 |
Rep 3,094
04-26-2012, 12:38 PM | #20 |
Rep 13,138
The shape of the notches shown on the pictures is OEM and perfectly normal, though (the ones in the middle inclined = OEM). It already indicates that BMW knew that it was a close call. However, still not enough for 100% clearance for the 270 winter set-up on most 1Ms (see also the rubbing traces on the pictures). Fender liner should be "deeper" (towards cooler) to avoid any rubbing at all.
04-26-2012, 02:56 PM | #22 |
Rep 898
Drives: '69 GT3, GT4, 1M, 912
If you're talking about deformation on the middle 3 fins then yes, that is molded in.
1M, GT4, 1969 Porsche 911 w/ 997 GT3 Cup Motor (435hp & 2,100 lbs)
