07-07-2023, 12:52 PM | #23 |
Rep 1,547
Finally, here's pics of the EOS tow hook license plate holder. Thoughts on it will follow.
07-07-2023, 12:59 PM | #24 |
Rep 1,547
This plate holder was designed for the G42, I think, but works fine on the G87. It comes with (2) 7mm spacers, I used one.
It seems reasonably secure, except I worry it's going to rotate. There's no keying in the assembly to prevent the plate from rotating over time, and I'm going to keep an eye on it. It has a lock washer, but those don't always work. It's reasonably adjustable on the yaw axis. The plate holder itself has plenty of mount points so you can position it. Because I'm worried about rotation, I mounted the plate dead center over the tow hook spot. I think it looks fine there, but you could push it leftward if you wanted. I wouldn't put it in a car wash. It's not a quick-release system, so if you go to car washes, this is probably not the product for you. Bottom line: IF it doesn't rotate over time, it will be sufficient. Build quality is decent. I'm going to keep it for now, but if it slips I'll get something else. If anyone can post a similar review on the RHO or any other product, that would be great! |
rons e921439.50 |
07-07-2023, 01:03 PM | #25 |
Rep 1,547
Oh, P.S. Some parts are plastic. I expect this thing has a lifespan of 3 years tops, which is fine for the price.
PPS: Make sure you have a 17mm socket wrench. You cannot screw this into the toe-hook mount by hand, no way you'll get it tight enough. |
M2siast5997.50 |
07-07-2023, 01:06 PM | #26 |
Rep 1,510
Drives: G87, G26, E46, Mk6 5K
I have an unopened RHO sitting in my office if anyone in the NYC area is in need. Will save me the shipping back to Cali and you’ll avoid the shipping cost ordering from them.
Hit me up. |
07-07-2023, 01:15 PM | #27 |
Rep 1,547
07-07-2023, 01:25 PM | #28 |
Rep 1,510
07-07-2023, 02:03 PM | #30 | |
Rep 3,054
Drives: A Family Sedan
Some do it at the very bottom (black piano), some under the body colour part so it looks OEM (but the holes are hidden in the big gaping mouth underneath). |
Squidget3538.00 |
07-07-2023, 02:43 PM | #34 |
Rep 1,547
07-07-2023, 06:04 PM | #35 |
Rep 15
As an update for mine. The cheap ebay option is still holding up as well. Same reservations as my initial review, but considering its held, I call it a win.
Squidget glad to see yours is working out too. Looks good and with similar fitment to both mine and the RHO, if I properly remember the pic of that I saw when first posted. Looks like we have three solid options confirmed for the g87 with this mounting location. Sometime in the next few days I’ll update the OP for folks searching with links and pics for all 3. |
Squidget3538.00 |
07-07-2023, 07:12 PM | #36 | |
60-130 Enthusiast
1440
Rep 755
When I swap it to the G87 tomorrow I'm going to try to loctite everything. |
Squidget3538.00 |
