01-23-2025, 12:28 PM | #23 | |
![]() ![]() 863
Rep 713
I bought a new car last month. The winter tires took a few days longer to arrive than originally anticipated. My car came equipped with all-seasons, so I did take delivery, then returned a few days later for the winter tires. Had it been equipped with summer tires, I would have refused delivery until the winter tires were installed. Summer tires are dangerous in the snow, on ice, and even on dry pavement below about 40 degrees F. They are designed to work great in the summer. Many are designed to work great on the track. They are contraindicated in the winter. Just as all-seasons are a compromise that make them not great on the track, so too are they a compromise that make them not great in the winter. They are far better than summer tires, but not optimized for winter conditions. They can range from okay to good, depending on the model. Winter tires are optimized for winter conditions. Where you live, it behooves you to install winter tires if you drive regularly in the winter. Consider buying minus-one: narrower tires with wider sidewalls and higher aspect rims and tires, and a square setup. The narrower tires will work better in the snow, all else equal. The wider sidewalls will give the rims more protection from the inevitable winter potholes. The square setup will allow you to rotate the tires, thus giving them additional life. In addition, they’ll probably be less expensive than the original size. Of course, you’ll have to buy rims as well as tires if you go this route.
A BMW car and several BMW motorcycles
Kaemslothel48.50 Ohio Enthusiast170.00 |
01-24-2025, 03:17 PM | #24 |
![]() ![]() ![]() 6133
Rep 6,885
Drives: 2018 340i M Sport
Garage List 2018 BMW 340i M Sport [8.89]
2020 BMW M340i xDrive [9.00] 2018 BMW 340i M Sport [8.00] 2006 BMW 330i Sport [6.60] 2004 BMW 330i ZHP [7.83] 2000 BMW 328i [6.17] |
Your best bet is to buy a 1” smaller square setup of wheels with winter tires and have a dedicated set you switch back and forth between the seasons. It won’t be hard to find a set in the classifieds here or on Facebook Marketplace.
![]() www.bmwcca.org member #388003 - Use me as a referral & you could win a one day ///M Driving School!! ___________________________________________ |
01-24-2025, 06:45 PM | #25 |
Rep 6,885
https://g20.bimmerpost.com/forums/sh....php?t=2153718
https://g20.bimmerpost.com/forums/sh....php?t=2154470. Offer him $500 - $600.
![]() www.bmwcca.org member #388003 - Use me as a referral & you could win a one day ///M Driving School!! ___________________________________________ Last edited by tturedraider; 01-24-2025 at 06:53 PM.. |
01-25-2025, 08:22 AM | #26 | |
ホンダ
1195
Rep 338
tracer bullet4281.50 |
01-27-2025, 10:43 AM | #27 | |
![]() ![]() 4646
Rep 8,185
As others have said, they consider AS tire mileage a plus over summer performance tire mileage or if they are truly worried about the lower mileage of a summer performance tire then you can’t afford to own a f8x. The f8x needs tires with a high level of grip even for street use. People complain it’s difficult, or impossible, to put the torque to the road on MPSS* spec tired so installing AS tires makes things orders of magnitude worse. Get a f3x instead with most models coming standard with AS tires. |
01-27-2025, 10:55 AM | #28 |
![]() ![]() 1477
Rep 1,191
short answer no....
long answer (Canadian) just get winter tyres.. dont mess around also depends on your local regional laws BUT if you drive a BMW and you wanna keep it, put winter tires on, ESPECIALLY if temps will fall below 7deg's daytime |
01-27-2025, 11:15 AM | #29 | |
![]() ![]() ![]() ![]() ![]() 954
Rep 845
Drives: '25 M240xi
The irony of someone who lives in the "Mid-Atlantic" raging about using winter specific tires. Most "winter performance" tires perform worse than All season and all weather tires in the wet/dry, educate yourself on tyre reviews youtube videos. No need to post the results for you as they are clear and complete. Why the fk do you keep talking about F8X? nothing in this entire thread is about F8X cars. OP doesnt have one, and isnt buying one.
2025 M240i Xdrive TNM - Eisenmann Exhaust - Dinan Springs - CF Goodies - More in process...
01-27-2025, 12:41 PM | #30 | |
![]() 170
Rep 128
The Wintrac Pro were very mushy in steering feel regardless of temperature, and it only got worse above 50 degrees. They were much more comfortable than the Goodyear's but on-par with the BFGoodrich's. They had good grip in the wet and dry, but both all season tires had better grip regardless of temperature and significantly better feel. Cold and wet (I'm putting here both above freezing low temps and rain as well as below freezing wet salted roads) is still better for the all seasons, as well as cold and dry and certainly warm and dry/wet (in Ohio it's fairly typical to get days in the 50s in the dead of winter). For snow and ice, I drove both in similar conditions (fresh 1-4 inches, compacted snow and plowed but unsalted roads). The Wintrac Pro were about the same as both all seasons - worked well on flat roads and were nice and predictable (and fun to slide around), but struggled on any hint of an incline for starting from a standstill. I couldn't climb the hill to my house on any of them with anything more than a dusting unless I timed the momentum well. Now, you might say that the Wintrac Pro are bad performance winter tires, and you may be right (although TireRack tests are quite favorable, particularly on snow (rather than ice)). Or that my all seasons are exactly the ones that are the best for these conditions (although they are pretty mid-pack, good enough for a good price for me). Perhaps you are comparing to touring all seasons, like the CrossClimate? These do indeed sacrifice dry/wet grip for better snow/ice grip and increased tread wear. Comparing to summer tires (Bridgestone Potenza Sport) the all seasons had less ultimate grip in both dry and wet, but to test that I really needed to push the car much more than I am comfortable on a public road. I.e. even if I ran summer tires my driving wouldn't really change and I wouldn't see an actual benefit. I also tracked the Potenza Sport a couple of times and they held up well, to the detriment of their life (they were at the wear bars by 6000 miles). I wouldn't think of tracking the all seasons, but I saw a few folks on track with UHP all seasons and they did pretty well (as novices). I really enjoy data, and both TireRack tests and TyreReviews show that the gap between all season and dedicated season tires is ever shrinking. TyreReviews in particular had a few tests where he threw in an all season and a summer tire into a winter tires test and the all seasons were pretty close in the snow, and better in the wet and dry. All seasons struggled on ice and summers obviously were absolutely terrible in snow/ice (but still very good in cold and dry/wet). All of this, coupled with the fairly snow-less winters in Ohio and me having the luxury of not driving in the snow if I don't want to, makes UHP all season tires work very well for me. Doesn't mean they'll work for everyone, but I feel that the knee-jerk reaction of "no season" tires is a little out of date with today's tires. |
01-27-2025, 05:54 PM | #31 |
Rep 22
Thanks for the great write-up. I think that we’re seeing things pretty much the same way – unless you absolutely must get around in any type of snow condition, UHP All Season tires are good enough.
ctcarbonari554.00 |
01-28-2025, 08:04 AM | #32 |
BMW Owner Since 1971
2635
Rep 1,577
Drives: 1964 700 Sport Cabriolet
01-28-2025, 08:07 AM | #33 | |
ホンダ
1195
Rep 338
I think he just works with what he has. But I agree, would have liked to see more tires in the test. |
01-28-2025, 09:22 AM | #34 | |
Rep 845
Drives: '25 M240xi
![]() I've run DWS06 in the past, they are not capable in snow any more than a Pilot sport AS tire.
01-28-2025, 09:30 AM | #35 | |
![]() 170
Rep 128
This makes TyreReviews hit-and-miss for relevance for the US market, which is sad as he is probably the most thorough tester and does very good test setups (in terms of tires tests and the types of tests he does). Tire availability is also not always 100%, same as with car comparisons, and he tends to be upfront and transparent about that. As for being a Hankook ad? If the DWS was included and won the comparison, would you claim a Continental ad? Sometimes mid-tier brands can shine, no need to try and find an ulterior motive. |
01-28-2025, 03:50 PM | #36 | |
![]() ![]() 224
Rep 189
03-01-2025, 01:58 PM | #37 | |
Rep 22
03-01-2025, 07:50 PM | #38 |
![]() 170
Rep 128
Have you driven in the before on studless snow tires? I had Vredestein Wintrac Pro (a performance winter tire) and they were very disappointing in snow and ice, barely any better than UHP all seasons. I'd be very curious how are your impressions of the MP Alpin and if you can compare them to "serious" winter tires.
03-02-2025, 07:52 AM | #39 |
![]() ![]() 4282
Rep 4,644
I won't doubt your view but I've got them on my X3 daily driver here in MN and love them. They are FAR better than the Potenza all-seasons I had before. Though that might not be a super high bar.
SCSIsoftware16.00 |
03-02-2025, 09:55 AM | #40 | |
Rep 22
I always had Performance Winter tires - usually the then current Pilot Alpins - on my three STIs before the Macan. The STIs never even seemed to know that the roads were slick. I did have Blizzaks on the family car back in the 90s. They truly were amazing in the snow. But the sidewalls were so flimsy that the low tire monitor (which was based on relative speed of the tires - this was before tire pressure sensors were available) would always turn on at the same dip in the road. The tire monitor mistook the decreased tire diameter for low tire pressure. As far as tires go - they were trash. While the flexibility of all-season/weather tires can eliminate the twice-a-year tire change over, having dedicated winter and summer tires really helps to bring out the best in a high-performance vehicle. |
BMWbiker862.50 Ohio Enthusiast170.00 |
Yesterday, 11:06 AM | #41 |
![]() ![]() ![]() ![]() 625
Rep 868
Drives: 2022 M850i Xdrive GC
I thought that I would be ok with AWD in my WRX when I had that brand new. (This was in 2013) I left the summer performance tires on and got stuck in my Cul-de-sac when we had a 13" snowfall. I went 13 feet outside my driveway and got stuck. I went to bowling and came back in one of the worst blizzards I can remember (I'm 42) I aimed for the center of the streets as to not go in the ditch. I made it home and halfway up mu driveway and then had to plow myself out as I got stuck again.
It is ALWAYS more beneficial to have winter dedicated tires if you live in a climate that has snow. Summer performance tires suck in the snow.
2022 M850i Xdrive Gran Coupe (Twilight Purple) | 2019 Audi RS5 Sportback (Navarra Blue) | 2021 Audi S4 (Quantum Gray) | 2018 BMW M5 (Singapore Gray) | 2019 Audi RS5 (Mythos Black) | 2020 X3M Comp (Black Sapphire) | 2019 Audi RS3 (Mythos Black) | (2018 STi Type RA (Black) #391/500) | (2018 Audi RS3 Nardo Gray) | 2015 STi Base (Black) | (2013 WRX Base (Black)
