09-14-2012, 10:34 AM | #67 |
Rep 232
09-16-2012, 06:30 PM | #68 |
Rep 50
While the new liners have what it seems to be is a significantly more scalloped area where the tire rubs during full lock...it still rubs, so I took a cutter to the area and slightly removed the area to make more of a clearance. That trick worked completely. Before I did this, the tire would rub just below on the "ribs" in the liner. I removed the bottom portion without disturbing the "rib".
09-16-2012, 06:51 PM | #71 |
Rep 50
Trying to post some pixs, but I received this instead:
"Your submission could not be processed because a security token was missing or mismatched. If this occurred unexpectedly, please inform the administrator and describe the action you performed before you received this error." I guess I'm not allowed to post pixs? |
09-16-2012, 07:47 PM | #72 | |
Rep 3,070
09-17-2012, 03:42 PM | #75 |
Rep 50
Sorry, not very good pixs, but I hope you can see in the 2nd pix, that the area where at full lock, the liner has a bit of extra scalloping for clearance. When I clean the wheels this weekend, I'll remove the wheel/tires and get a better pix...
09-18-2012, 09:18 PM | #76 |
Rep 4,848
Thanks for this, I might try cutting some of the plastic off too.
Macan S Diesel - Carrera White
Macan Turbo - White 1///M - Valencia Orange |
09-19-2012, 08:50 PM | #77 |
Rep 630
FWIW, I had ordered the liners in June, anticipating paying out of pocket for them. There had been a *little* rubbing when I first installed the Hoosiers. Two pieces were on order from Germany. I wasn't in a rush. Plus they were pretty expensive. Then this thread appeared and I/we saw that they were being replaced in Europe. Then I saw that Niello did it. That created a nice precedent.
Today I took the car in for a radio problem (left side mid and high end working intermittently, really annoying if you're talking on the phone or punching digits like for voice mail). I also asked about the liners and that Niello did them. I had also spoken to the shop foreman (a friend) two days ago. Well I pick up the car today with an amp on order (not a stocking item) and the liners installed under warranty. Woo hoo!
Matt Murray
I am perfectly capable of learning from my mistakes. I will surely learn a great deal today. |
09-19-2012, 09:11 PM | #78 | |
Rep 1,963
12-11-2012, 05:54 PM | #80 |
Rep 1,801
Can someone tell me what are the specs of the 270M winter tire pkg BMW offers for the 1M? I brought the car to the dealer today to get the rubbing issue checked, and they refused to replace the liner saying that my tires were not the recommended size.
I'm running the Pirelli Sottozero in the same size as OEM 245/35/19 front and 265/35/19 rear. Only thing is i'm on Alufelgen SF-71 19x8.5 +15 infront, but its only a 3.3mm from stock? Maybe i should print this thread for my SA? |
01-14-2013, 01:16 PM | #81 |
Rep 4,744
Drives: S65 1M Clone & E92 M3 4.6L
1m Fender Liners - BMW part revision
I know a while back there was a thread about the 1M fender liners rubbing in the front at full lock and BMW issuing replacements if people complained but I don't know if it has been pointed out that BMW actually revised the front fender liners to give more clearance.
When the 1M first came out I purchased the 1M fender liners for my ER front end and last when building my 1M front end I noticed that the new liners are different. BMW has moulded them to allow more clearance. Old 1M liner - note the groove was from some rubbing. Originally it was much flatter New 1M fender liner - Note the larger groove |
01-14-2013, 05:00 PM | #82 |
Rep 96
Do you have the part number for the new liner or are they just reusing the old part number? Depending on price, this might be a good proactive change and simple enough that it's not worth going through the dealer.
-Andrew S.
01-14-2013, 05:31 PM | #83 |
Rep 3,070
+1. Exactly!
"The mark of a great car is one whose overall competence exceeds what you should expect from its individual components and the 1M does just that", Chris Harris.
BMW 1M-SOLD-: TECH: Evolve Race+N55mids, Evolve IC, Michelin PSS, ER cp, aFe filter, CDVx, Vorshlag camber plates, BMS OCC EXTERIOR: trunk spoiler, blacklines, black grills, IND goodies INTERIOR: Alcantara steering wheel, steel pedals, custom mats, MPower e-brake. |
01-14-2013, 05:58 PM | #84 | |
Rep 4,096
Usually the part # will be stamped on/in the part so should be readily available? |
01-14-2013, 06:49 PM | #85 |
Rep 4,848
Thanks for this. I have a unique problem that it rubs at the back though and not the front.
01-14-2013, 08:19 PM | #87 |
Rep 2,091
So the dealer should replace this under warranty if asked?
2012 Audi R8 V10TT| 6MT| Suzuka Grey
2015 Ferrari 458 Speciale| Rosso Scuderia 2020 BMW X7| Mineral White 2024 718 GT4 RS | Arctic Grey |
