BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > Wheels + Tires Sponsored by The Tire Rack
  TireRack
KEEP M3POST ALIVE BY DOING YOUR TIRERACK SHOPPING FROM THIS BANNER LINK!
      12-07-2007, 05:26 AM   #1
MrHarris
yodog
MrHarris's Avatar
Drives: '86 Corolla
2009 BMW  [10.00]
Fattest Tires Possible?
Anyone know what the fattest tires for the front and rears can be put on? Particularly the rears, because I would like to get something thicker than 265's on the rears.
      12-07-2007, 06:47 AM   #2
Epacy
Reincarnated
Epacy's Avatar
245
Drives: 02 Maxima SE
2008 M3  [0.00]
Reason?
      12-07-2007, 07:48 PM   #3
MrHarris
yodog
MrHarris's Avatar
Drives: '86 Corolla
2009 BMW  [10.00]
in my opinion m3's look better with something like 285's in the rear. just wondering if the rear fenders are similar in size to the e46 m3. the new e92's fenders are way more subtle so it's hard to tell.
      01-04-2008, 01:59 AM   #4
Sick Speed
Speed
Sick Speed's Avatar
65
Drives: 2008 335i E92 Coupe
I run 295s (rear) on mine. No reason the new M should not be able to take 295s either.
You don't want to be too wide on your fronts or you will plow through turns. 245 up front max.
SS
      01-04-2008, 10:32 AM   #5
gadget
gadget's Avatar
Drives: 09 e92///M SSII DCT
Is there a a performance gain with wider tires? I assume the wider the tire, the better the ability for the car to put the power to the ground, but I'll guess there is some negative connotation to handling and track performance if you go too wide.
I too like the look of wide tires in the rear but don't want to compromise perfomance.
      01-05-2008, 01:29 AM   #6
swamp2
swamp2's Avatar
Drives: E92 M3
SS
Did you mean oversteer in stead of plow? Plow = understeer. All other things being equal increasing the front tire width increases its front grip which will lessen understeer if present or worsen oversteer if present. BMWs (and almost all production cars) are factory tuned to understeer as it is by far the safest negative handling set up. Sporty cars are factory tuned for understeer but typically for mild understeer. Increasing the width of the fronts a bit more than increasing the rears will help balance the car more toward neutral. But this is really best for very experienced drivers. Increasing the fronts too much can cause the steering feel and weight to worsen. The 265s on the rear are under-tiring the car for its power for sure. I bet you could fit 305s on the rear.
I'm sure that enigma or e36jakeo would have some good specific recommendations for tire sizes to properly balance feel, looks and performance. Until you have actually given it a try though, everyone will have to guess to some extent.
      01-14-2008, 05:47 PM   #7
bimmerluver
bimmerluver's Avatar
Drives: 2018 430I GC
2007 328i coupe  [0.00]
2006 x3  [0.00]
how bout' this specs?
im planning to buy 19x10 275/30/19 for the rear 245/30/19 for the front... will this fit my 328i coupe 07 or x3 06' with sport package?
      01-14-2008, 06:39 PM   #8
dillon733
dillon733's Avatar
96
Drives: Jet Black e92 M3
wouldn't 265's be the width
      01-16-2008, 09:58 PM   #9
enigma
Drives: E92 M3 and Elise
On my E46 I ran 285/30-18 front and rear for the track and autocross. Stuck with stock for the street.
On a stock setup you really can not use wide/low profile front tires. The car needs more static camber and/or more roll stifness before I would start putting wide fronts on.
I'll start asking the 335 guys what they use. But really we won't know until someone gets a car and starts to measure parts.
m3post
