06-29-2014, 11:30 AM | #1 |
Rep 170
Scratches on X1 Argh...
So I was leaving my Gf's place yesterday and noticed I have a nice long scratch on the drivers door... looks like some asshat took a knife and ran it down my door. It's deep enough for my fingernail to stay in the groove but not showing metal... have you guys had similar scratches? I want to avoid getting the car wet sanded and or going to the body shop.
06-29-2014, 01:38 PM | #2 |
Lucky13
213
Rep 1,762
Have not had that happen but considering you will probably have to wet sand it I would try filling the "groove" with clear coat paint from a paint stick. If you wet sand it your just sanding down the clear coat around the "groove". If it doesn't look a lot better then wet sand it and it may blend better since the "groove" has been filled.
1995 325i, 1996 328ci, 1997 528i, 1997 Z3 2.8, 2000 528i, 2001 X5 3.0, 2001 330i Convertible, 2002 M3 Convertible, 2003 M3 Coupe, 2004 M3 Coupe, 2004 Z4 3.0, 2004 X3 3.0, 2007 X3 3.0, 2007 335i Convertible, 2013 X1 28 sdrive, 2014 M235 manual, 2020 X3 30i Xdrive
06-29-2014, 08:33 PM | #3 |
Rep 1,922
Drives: 2011 e91
I have lights scratches everywhere on my car. I'm honestly disappointed in BMW's paint. It seems really thin and too easy to scratch for having to pay extra for it. I have had luck with them buffing out for the most part
2011 E91
2016 M2 - Sold 2014 X1 - Sold 2002 Land Rover Discovery II - 3" lift & 33s |
06-29-2014, 09:56 PM | #4 |
Lucky13
213
Rep 1,762
I've wet sanded a lot of deep scratches mostly with success but basically your lowering the paint around the deep scratch. If it's as deep as described it's probably not coming out with compound that's why I suggested filling it with clear coat and then wet sanding the area smooth but level then compound then polish. Just depends if it got below the clear coat if so then let a professional try. My method costs $10 if it works and a body shop won't even look at it for $150.
