08-19-2014, 01:06 PM | #1 |
Rep 87
Does anyone know if these do/will exist and if they would even fit given the very limited clearance near the muffler? I know this might be considered sacrilegious, but I need something to carry bikes and it is still unclear if the CF roof can be modified to have the threaded studs installed.
Any help is appreciated. |
08-19-2014, 01:26 PM | #2 | |
Rep 2,997
However, I believe one f80/f82 owner so far has used the roof-mounted suction-cup rack to take a bike with no problems. Quite a good system, though I think most people have trust issues with suction
AW/Carbonstructure 6MT 2015 M3 picked up 8/22/2014. Stripper except for adaptive suspension. Weighed at 3,450 pounds with 1/4 fuel. 70,000 miles as of February 2020.
08-19-2014, 01:57 PM | #3 | |
Rep 3,249
Just kidding. I don't know the answer, but I will tell you that the rear-view camera does have a "hitch zoom" function. Probably a generic iDrive feature though.
'21 /// M5 Comp - Frozen Brilliant White/Black
'18 Porsche GT3 Carrara White/Black/Red - Sold '18 /// M3 - Individual Imola/Black - Sold '15 /// M4 - YMB/SO - Sold '12 E92 ///M3 ZCP - AW/FR - Sold |
08-19-2014, 02:56 PM | #5 | |
Rep 87
I also do not trust the suction cups and do not want to put rack feet on the paint. Ideally someone figures out how to get the threaded inserts to work via a dealer install or something, but I figured investigating the hitch mount is another option too. |
08-19-2014, 03:20 PM | #6 |
Rep 611
Not only is a tow hitch NOT sacrilegious, it's completely internally consistent with the ///M philosophy of "do it all" high performance vehicles. The M3/M4 with a tow hitch and small wheel/tires/tools trailer would be the perfect track day setup.
Case in point: On several trips to the Nurburgring I've seen M3s and 911s with tow hitches and trailers carrying track day supplies. I've only been a few times, but I'd be willing to bet this isn't an uncommon sight. |
stormlv939.50 SYT_Shadow11504.50 |
08-19-2014, 03:22 PM | #7 |
Rep 616
You should ask your local UHaul if they have any hitch products for BMW Sedans, namely the M3.
ED 11/3/14 2015 M3, AW, SO, DCT, 19" blk wheels, HK, Lighting/Exec/Tech packages, ad. susp.
08-19-2014, 03:32 PM | #8 |
Rep 1,450
08-19-2014, 11:02 PM | #9 | |
Rep 2,371
Would love to do the same thing with my M, but based on the muffler, not sure it is going to be possible. If it is possible, I will install a hitch in a heartbeat. |
08-19-2014, 11:13 PM | #10 |
Rep 10
I have the invisihitch on my F31 and it's great. You can just take the end of the hitch off if you don't need it, and no one would know there was a hitch installed.
08-20-2014, 12:22 AM | #11 |
Rep 1,864
Drives: F80 M3
Garage List 2016 Porsche GT4 [0.00]
1999 Porsche Spec B ... [0.00] 2014 Ram 1500 Laram ... [0.00] 2007 Porsche GT3 RS [10.00] 2013 Tesla Model S 85 [0.00] |
Hitch would be so cool, not only for a bike rack but a single axle motorcycle trailer. Or drop it to the ground on 21's until it's useless except as a fashion accessory.
F80 M3 / Mineral Grey-Silverstone / CCB
08-20-2014, 04:31 AM | #12 |
Rep 19,368
You might try the company mentioned near the end of this thread:
http://www.m3post.com/forums/showthread.php?t=145306 I don't know if anyone ever tried it, nor whether they have or plan to have a product for the F8x. I don't think I've ever seen pics of a E9x M3 with a hitch installed. |
08-22-2014, 09:55 AM | #14 | |
Rep 150
08-22-2014, 03:41 PM | #15 | |
Diligentia Vis Celeritas
558
Rep 1,477
Drives: 335i
I'm planning to get one of these for my F30.
Ahead of the curve for specF30
07-09-2015, 03:23 PM | #16 |
Rep 87
I gave in and bought the invisihitch mount for the F30 at risk. I installed it a few weeks back and had no real issues with the install. Pretty much all of the steps are identical to the F30.
There is a secondary portion/piece of the heatshield which could likely be cut (they have instructions on hot to cut the F30 heatshield) but removing it seemed to work just as well, and I am not too worried about the exhaust temps in that particular area as the hitch does provide a little extra protection. I have been keeping an eye on it and have not noticed any issues. It does eliminate two of the four bolted mounts on the bottom of the diffuser, which has the potential to make that portion flop around, but again, I have not really noticed any problems. I left the bolts in so the bumper connects to the diffuser, but neither connect to the heatshield any longer. As you can see in the video, the hitch insert does move the diffuser up slightly, but only touches a small portion which isn't visible from the back of the car at all (I am sure a small piece of xpel or PPF would prevent damage). I am not sure that this would work with any of the carbon fiber rear diffusers though. I imagine it likely won't work. Video of the hitch adapter being removed/installed: https://www.dropbox.com/s/j04p4aipea...%20PM.mov?dl=0 Photo Album: https://www.dropbox.com/sh/apq3csfrz...qd-0jU0Wa?dl=0 With bikes: Last edited by Sivart321; 09-08-2015 at 01:37 PM.. |
DreaminBMW104.00 seis-speed2461.00 |
07-14-2015, 05:05 PM | #18 | |
Rep 34
Looks great. Do you have a link to purchase the mounting system? I'm in need to haul some bikes occasionally.
Thanks. Quote:
07-14-2015, 05:06 PM | #19 | |
Rep 87
Buy at your own risk. Technically designed for the F30 but works as I described above. |
07-14-2015, 05:36 PM | #21 | |
Rep 87
http://execuhitch.com/tow-hitches/bm...2-current.html |
07-15-2015, 09:36 AM | #22 | |
Rep 2,561
It does fit F30's and bolts to factory rear bumper enchantment points. Looks like a solid solution for those cars. I just called them, and they claim it does not F80/F82's properly: the clearance between the muffler and the hitch carrier is just too tight for their hitch ball attachment mechanism. The nicely illustrated post above show how F30 kit can be installed on F80 for bike-rack duty (with minor lower bumper interference). Just watch your fingers if you do it while the muffler is hot! At least that much is good news for the bikers! a
'19 TM3P (BK/BK)
'15 F80 M3 (SO/SS) ex-'17 I01 i3-BEV (PB/DD), ex-'15 I01 i3-REX, ex-E90, E46, E36's, E30's Last edited by afadeev; 07-15-2015 at 09:44 AM.. |
