08-30-2014, 06:13 AM | #1 |
Rep 162
Akrapovic slip on, do I need adaptors?
I'm looking at buying a used Akrapovic slip on and initially just want to attach it to my factory x pipe. I've read I need adaptors, is this true?
The car it came off was fitted with a Gintani X pipe so not sure the seller has them. Thanks in advance |
08-30-2014, 07:11 AM | #2 |
Rep 102
I'm pretty sure it just bolts on (or slips on lol) to the factory X-pipe. I just bought one for my car 30min ago. If it does require some adapter, then I will buy the evo X-pipe before wasting my time installing the slip on.
MS Intake, MS Pulley, Akrapovic GT4, Akrapovic Slipon, BPM Tune, KW-V3.
08-30-2014, 07:25 AM | #3 |
Rep 162
Ok thanks for the reply. I noticed on another post that the adaptors apparently come with both the slip on and the evo but you don't use them when fitting the evo as you remove the factory x pipe.
08-30-2014, 09:06 AM | #5 |
Rep 893
For a stock or an X-pipe with stock-like 'flanges', you'll need the adapters. If the previous owner has it one the Gintani, good chance they'll be included with the sell.
The one reason you wouldn't need the adapter is if you have the Akra GT4 or Evo X-pipe. |
08-30-2014, 03:11 PM | #8 |
Rep 162
[QUOTE=vastano;16553466]For a stock or an X-pipe with stock-like 'flanges', you'll need the adapters. If the previous owner has it one the Gintani, good chance they'll be included with the sell.
Awesome, thanks |
09-02-2014, 01:52 PM | #9 | |
Rep 147
Drives: E92 M3
09-03-2014, 04:13 AM | #10 |
Rep 105
IND sells them http://ind-distribution.com/ind/cate...-pipe-adapters
09-03-2014, 06:43 AM | #11 |
Rep 1,470
I have a pair I will sell. Make me an offer.
Stoptech 380mm/355mm | PFC08 / Pagid RS-29 | Akrapovic EVO - CF tips | Benvo Tune | MS UDP | AA air filter | MCS 2-way with 700/1000lb springs | Solid bushings and adjustable links | RD front swaybar | Apex EC-7 18x10 square 275/35-18 NT01 | Turner Race Studs | GT4 Brake Cooling | GT4 Power Steering Cooling | Alekshop Oil Cooler | Performance Steering Wheel | | CF Spoiler | Varis System 1 Full CF Diffuser | Extended Paddle Shifters | Schroth Quick Fit Pro | Turner Steering Rack Stops | Vorshlag Camber Plates
09-13-2014, 09:17 AM | #12 |
Rep 459
Don't want to be a thread jacker but I may need a set of these...doesn't seem you can receive PM's but if these are still available let me know.
No toys right now...
My old M3: |
09-13-2014, 09:28 AM | #13 |
Rep 767
This is correct. I have the Evo slip on. The adapters come included from Akrapovic and should work with any aftermarket x-pipe or OEM. I think the confusion comes from people trying to use an Akra x-pipe with another axle back system. Then you'll need the adapters from RKP that iND sells.
2019 McLaren 720s / 2018 Lamborghini Huracan Performante / 2019 Porsche Macan Turbo / 2016 BMW M3/// IG @jon.hagerty
09-13-2014, 11:56 AM | #15 | |
Rep 1,470
