09-02-2014, 07:04 PM | #1 |
Rep 182
Will these tires fit?
Will the f15 467M 19" wheels, 19x9, I believe. Will they fit a base X5 that came with the 18" wheels without ant issues?
09-02-2014, 07:28 PM | #2 |
Rep 3,990
As long as your 19" wheels have 19" tires (XXX/XXR19), they will fit. If you're concerned about something particular, provide more details .
2014 X5 50i X-Line // Mineral White
09-02-2014, 07:45 PM | #3 |
Rep 182
09-02-2014, 07:49 PM | #4 |
Rep 3,990
In your manual, the tire size for 18-21 should be there. These all follow the OEM diameter where wheel rub will not occur. As long as your tires are that thickness, you'll be fine.
09-02-2014, 09:07 PM | #6 |
Rep 18,794
@BillK, if you are 19x9 all around, it is fine.
The M Sport setup always staggered, wider in the rear. In the case of 467M 19", on the M Sport is 19x9 front and 19x10 rear.
Email:sales@rgsport.com | IG:RGSport_USA | Web:RGSportShop.com Memorial Day SALE!! 05/24 - 06/03 • Coupon Code: "MEMORIAL" MSS • iSweep • RaceChip • Sterckenn • AutoTecknic • Akrapovic • Vossen Wheels • Eventuri Active Autowerke • KW • H&R • Ohlins • Remus • and more... |
09-03-2014, 04:54 AM | #7 |
Rep 1,417
Last year, BMW Canada was selling the 19" 467M as a $5300 winter tire package for F15, MY 2014 on. Dealer said it would also fit on Non-MSport F15. So yes they will fit as others here have confirmed.
09-03-2014, 06:56 AM | #8 |
Rep 182
Thanks a lot for the info. I was worried because the m contour has flared fenders, a little, and I thought these tires might protrude outward of the base fenders.
By the way, i believe the offset is 37mm. Does that matter? Actually i just saw the model 490's and they are looking really good to me Last edited by BillK; 09-03-2014 at 07:14 AM.. |
09-03-2014, 12:48 PM | #9 |
Rep 3,990
The flared fenders are only on the M-Sport and any staggered tire setup, unless you get them separately to be installed. I have 22" and don't have flared fenders. My setup is non-staggered. The reason for the fenders is like you said, the rear tire sticking out ever so slightly, but in most cases this won't be noticeable or much because the rear has less offset than the front to create that fender balance (while the rear appears fatter it's because it extends deeper indward). Fender rubbing occurs if you have a really low vehicle and huge tires or if the front diameter does not match oem specs, you will have a tiny bit of rub.
I have 285/35R22 on all 4 wheels for my non-staggered setup. At 100% full turn in reverse only, I get a very tiny rub against my inner front middle fender against two tiny pieces of plastic. This to me is miniscule and worth the extra tread. Your setup is FAR from this, so you're fine. Here's two pictures (left and ride front wheel well) of where the two plastic edges (plastic edge 5 and 6 on each side counting from the bottom up) are slightly rubbed at full turn in reverse: Left tire: Right tire:
09-03-2014, 08:05 PM | #11 |
Rep 3,990
You're very welcome . Passport BMW in Suitland-Silver Hill, MD. How about you?
09-03-2014, 11:59 PM | #12 | |
Rep 3,307
09-04-2014, 03:52 PM | #13 |
Rep 182
09-04-2014, 05:55 PM | #14 |
Rep 3,990
Nice. I usually get mine serviced from Rockville because it's closer (one guy there is solid that takes care of me).
09-04-2014, 07:34 PM | #15 | ||
Rep 18,794
