09-06-2014, 03:10 PM | #1 |
Rep 105
Drives: e90 M3 IB/FR
Snapped coolant bleed screw
Any brilliant ideas out there for removing half of the coolant expansion tank bleed screw? I was flushing the radiator today, and while I was doing the final bleed, the screw snapped in half (with hardly any torque, which is awesome)....should have seen the fountain of coolant spouting up in the air! So, I'll grab a new one, but I'm having a rough time getting the old one out, without any top to it. I'd like to avoid drilling it, so I don't get a bunch of plastic shavings in my expansion tank.
Thanks.
09-06-2014, 07:52 PM | #4 | |
Rep 104
I think it is seriously annoying the amount of plastic they use in what is supposed to be a high end car. Plastic reservoir ok but plastic screw plugs..really? Nice job BMW |
09-06-2014, 08:38 PM | #5 |
Rep 2,719
Drives: M3
Garage List 2016 BMW X5M [0.00]
08 BMW M3 [0.00] 14 BMW X5 50i - sold [0.00] 09 BMW 335i - Sold [0.00] 09 BMW 328i - Sold [0.00] 07 BMW 328i - Sold [0.00] |
I used a screw driver method..... +1
Evolve, Eisenmann, Strasse, StopTech, Active Autowerke
09-07-2014, 09:09 PM | #6 |
Rep 893
09-08-2014, 09:32 AM | #8 | |
Rep 12,318
So the top of that left over part should look close to this:
Current:
16 F82 M4 GTS, Black Sapphire/Black, DCT 08 E92 M3, Sparkling Graphite/Bamboo Beige, 6MT 07 E85 Z4M Roadster, Alpine White/Red, 6MT 99 E36 M3, Techno Violet/Dove Grey, 6MT |
09-28-2014, 06:55 PM | #9 | |
Rep 1,616
09-28-2014, 08:49 PM | #10 | |
Rep 4,003
http://www.m3post.com/forums/showthread.php?t=886184
Grigio Telesto M4, 6MT. Coyote 5.0 F-150 991 GT3 |
09-28-2014, 08:59 PM | #11 | |
Rep 1,616
So it looks like BMW part number 11537793373 is for the E92 bleed screw and 17111712788 is the part number for the E46 bleed screw but they are both the same.
09-28-2014, 09:20 PM | #12 |
Rep 4,003
Glad I could help
01-07-2018, 05:02 PM | #13 |
Rep 1,264
This happened to me while driving! I got the low coolant warning, pulled over and saw coolant spilled all over the engine bay. I was nervously watching my P3 guage coolant temp while driving back home.
The heated flathead screw driver method works. Here's what I did. 1. Dry off the top of the snapped screw. 2. Turn the stove on and leave the flathead screwdriver tip on the flame for 90 each side. I just picked 90 seconds as I didn't want to melt the handle. 3. Walk to the car, presuming the hood is already open of course, center the screwdriver on top of the screw and push the screwdriver in with a little force downward. You should hear a little sizzle. I left it on there for 10 seconds after the sizzle stopped. 4. Repeat step 2 and 3. Resist any temptation to unscrew it while it's hot, that would be counter productive. 5. Wait 3 mins. 6. Unscrew using the notch you just created. If you're in a pinch to get a replacement bleeder screw, your local parts shop may have the Dorman brand in stock. I used it and it fits fine. $5 for two screws with gasket. I'll be changing mine every 60k miles as preventive maintenance from now on. |
01-01-2019, 04:54 PM | #14 |
Rep 307
Sorry to bump an older thread, but thank you for the above advice, my bleeder screw head snapped today during some routine maintenance I was doing and this method worked like a charm.
2008 E93 M3 | SSII | HRE P40's (Sold 2018)
2011 E90 M3 | Jerez Black (Sold 2019) 2019 Lexus IS300 (lasted 3 months) 2020 Toyota 4Runner TRD (fun truck) 2014 Tesla Model S P85 (wicked car) 2011.5 E92 M3 | Space Grey | ADV.1?s |
03-28-2021, 07:40 PM | #15 |
1966
Rep 1,926
Drives: E92 M3
I tried the method of heating up a screw driver but that was taking too long. I used a rubber mallet to hammer in the screw driver and that came out easily.
The Dorman screws are junk, snapped off very easily. |
06-06-2021, 06:23 PM | #16 |
Rep 2,197
Great thread! The heated screwdriver method worked for me as well. Heading to the dealer tomorrow to pick up two new bleeder screws. I would pick up a brass on from Turner, but they appear to be discontinued. Any idea if someone still makes them?
Bake
2011 Alpine White on Black 535i M-Sport 2013 Space Gray on Fox Red M3 Vert |
06-06-2021, 06:36 PM | #17 |
Derbo Tuning
3613
Rep 3,031
FWIW,
BMW TIS doesn't mention ever using the bleeder screw on the S65. If leaving the cap off is sufficient to BMW, it's good enough for me to avoid touching that bleeder screw.
IG:ruhrohz_m3
Journal: Link E9x ZCP Suspension Info: Link Track Chat Discord: https://discord.gg/VsKbTyqBVj SF Bay Area: DM For coding services |
06-08-2021, 11:05 AM | #18 |
mTekMods
2169
Rep 2,922
It doesnt but when the system is completely empty and you dont want to run the car its easiest to crack the screw then fill the system, the bleeder screw actually lets alot of air escape and allows coolant to flow.
2011 Frozen Black/Fox Red E90 M3 650+WHP
G-Power Supercharged First DCT to Manual Conversion Worldwide KW CS, BBS RI-A, BW Headers, Snow 2.5 |
06-08-2021, 11:27 AM | #19 | |
Rep 228
DRLane3997.50 |
06-14-2021, 06:40 AM | #20 | |
Rep 2,197
Bake
06-14-2021, 11:12 AM | #21 |
Rep 209
Drives: 2018 X5
I'm slowly lining up parts to flush my system. I haven't done it before on this car. Is this screw https://www.amazon.com/AUTOHAUX-Radi.../dp/B07ZQCCJNR for both the top bleeder screw and the drain plug? Or is the drain not plastic?
06-14-2021, 12:37 PM | #22 | |
Rep 209
Drives: 2018 X5
