09-10-2014, 08:48 AM | #1 |
Rep 27
How do i open exhaust flaps for X5 50i?
I love the "throaty" sound of the V8, and was told the exhaust can be tricked to stay open. Sounds too "tame" when they're closed IMO. : )
Disconnect vacuum pump? Can anyone tell me the process for this? Thank you! |
09-10-2014, 09:13 AM | #3 | |
Rep 525
the 50i sounds very mean, throuty and rumbling upon cold start. just like my 335i the valves would open until it had some heat flow and then close and quiet down. so i assume these 50is sound so good on startup cold because they have valves. must be careful over time due to the fact locked open valves may throw codes, and will gunk up and get stuck from carbon buildup |
09-10-2014, 11:02 AM | #4 |
Rep 18,794
As I remember, there is no valves on the 5.0 and 3.5d.
Email:sales@rgsport.com | IG:RGSport_USA | Web:RGSportShop.com Memorial Day SALE!! 05/24 - 06/03 • Coupon Code: "MEMORIAL" MSS • iSweep • RaceChip • Sterckenn • AutoTecknic • Akrapovic • Vossen Wheels • Eventuri Active Autowerke • KW • H&R • Ohlins • Remus • and more... |
09-10-2014, 01:44 PM | #5 |
Rep 532
Or is there a reasonably priced exhaust system (perhaps just the muffler) that can add more sound? I see that there is a local vendor offering cat back system for over $3k.
09-10-2014, 06:21 PM | #7 |
Rep 512
I think the loud cold start is actually the wastegates are held open for a few seconds. My M5 is CRAZY loud on cold start then mellows out with the turner muffler delete setup. I have no valves in the mufflers and its still loud when cold and mellows out. If you have the valves its simple to just take off the unit and wire tie the flaps open.
09-10-2014, 06:53 PM | #8 |
Rep 525
NO Valves layer under the car for a bit and no valves anywhere.
One strange thing I noticed is that in the midsection of the exhaust pipe we have some type of resonator muffler on each of the pipes. But they look different. One looks like a muffler and on the other pipe it looks like a cat. Not the same shape of resonator |
09-10-2014, 11:35 PM | #9 | |
Rep 18,794
I would take them out to get a growl out of it.
09-10-2014, 11:38 PM | #10 | |
Rep 18,794
I did that to mine, but it still not enough growl for me.
09-11-2014, 08:47 AM | #12 | |
Rep 18,794
I would just leave the downpipes and remove the center pieces. In the 35i, the center pipe are clean, all straight pipes between the downpipe and the muffler.
09-11-2014, 09:18 PM | #13 | |
Rep 27
Maybe we can get to to growl with your idea! See you in the am!! |
09-11-2014, 09:57 PM | #14 | ||
Rep 18,794
09-11-2014, 09:58 PM | #15 |
Rep 3,990
Let me know how this goes, Ben! I'm really curious to know how the 5.0i sounds after you guys experiment with this. If you guys make a video clip for us, that would be great as well! Thanks, buddy .
2014 X5 50i X-Line // Mineral White
09-12-2014, 11:23 AM | #16 |
Rep 532
09-12-2014, 12:05 PM | #17 |
Rep 665
Drives: 2024 X5MC LCI, 2017 F86 X6M
I don't think there are flaps on the F15 but what I really love in contrast to the older models is that when you put the car in sport or sport plus mode, you actually feel the difference (noise, performance and exhaust sound).
I especially love it when I rev the car and let the pedal go, it sounds just like a Cayenne turbo or GTS exhaust and even better. Great work on the new engines. |
09-12-2014, 12:09 PM | #18 |
Rep 525
i really think im going to delete the middle resonators and just stick in electronic actuated cutouts so i can have a gurgly tone and a all hell broke loose tone.
09-12-2014, 01:59 PM | #19 | |
Rep 3,990
09-12-2014, 03:21 PM | #20 |
Rep 18,794
I just finished with @Tcap car, unfortunately I was correct, there is no valve on the 5.0. Only 2 big resonators on the mid-pipe.
I would personally remove it and let the V8 sounds like a V8. Aside from that, I personally installed the BMS N63tu Stage 1 tune. And @Tcap enjoys it. Installation actually took only 2 minutes. 1 minute to pull in the car and open up the hood. The rest just plugging them in. Coded his car, installed the grill trim and front/rear painted reflector.
09-13-2014, 11:06 AM | #21 |
Rep 18,794
Found this guys post on the 6's forum. He removes the rear muffler (based on what he said, still waiting for his confirmation on what he removes).
I believe, these sounds are what you guys are after. http://i174.photobucket.com/albums/w...ps183f5b6f.mp4
09-13-2014, 12:40 PM | #22 | |
Rep 27
Thanks, #r33 |
