09-17-2014, 10:23 PM | #1 |
Rep 43
Need New Shock Absorber
My mechanic said I need to replace the rear shock absorber. I dont track, just daily drive, any suggestion?
I found two different brands which are Monroe and Bilstein, which one is better? |
09-17-2014, 11:32 PM | #3 |
Rep 43
09-18-2014, 03:35 AM | #4 | |
Kind of a big deal
301
Rep 1,674
Drives: an 1M not often enough
Check here for stock part #1 |
09-18-2014, 11:21 AM | #5 | |
Rep 11,785
If you are replacing a PAIR of shocks you can consider the options. You probably should still stick with OEM Buy you could replace say, both front or both rear shocks with aftermarket shocks. Ideally if you are going to aftermarket shucks you would want to replace all FOUR shocks and struts. I would select bilstein over Monroe. |
