KEEP M3POST ALIVE BY DOING YOUR TIRERACK SHOPPING FROM THIS BANNER LINK! |
09-20-2014, 08:45 AM | #1 |
Instructor
Rep 83
For those running without TPMS ...
Question: if I opt to use a set of winter wheels/tires that either have the wrong TPMS or none at all, what is the extent of the electronic nannies I'll have to deal with on a daily basis?
I have a 2011 US model with Nav/iDrive. If it's just a matter of a message at start-up and a constant small warning light in the IP I can live with that for a couple months, but I don't want continuous gongs and flashing lights telling me what an ignoramus I am. And coding would cost more than just having the damn things installed... Thanks in advance... |
09-20-2014, 09:06 AM | #2 |
Rep 1,718
Drives: 2011 M3 Jet Black:ZCP, ZCV, ZP
Just a light on the dash no continuous noise
09-22-2014, 07:12 PM | #3 |
Rep 3,422
Yep, just a light on the dash. But I'd get a set because they can save your arse. They probably saved mine one time.
.02
M4 GTS, GT3, C63 S | E90 M3s, E39 M5
09-22-2014, 07:55 PM | #4 |
Rep 3,997
Coding is fairly easy. Might be worth learning how to code the car and do it yourself.
I recent disconnected my module and coded it out. Takes 5 mins and I can put it back. |
09-22-2014, 08:36 PM | #5 |
Rep 6,734
Drives: 'E46 M3 Race Car, '23 X7
I don't see the point in eliminating the TPMS monitors. I personally think it's a fantastic safety feature. Detecting a low tire early may prevent you from being stranded without a spare tire, in the middle of winter... I don't care what anyone says, nobody can detect low tire pressure while cruising on the highway.
'23 X7
'04 M3 - Fall Line Motorsports Built Race Car - S65 swap, Dry Sump, Bosch Stand-Alone ECU, Drenth Sequential Trans, MCS 3-Way, Flossmann Wide Body, Brembo Motorsports Brakes, Drexler LSD, BBS E88 Etc. INSTAGRAM - @Slicer_M |
09-23-2014, 05:05 PM | #6 |
Instructor
Rep 83
Thanks all. I agree, all else being equal I'd keep them, but if I'm able to pick up a winter set-up on the cheap that happens to have the older style or none at all I just wanted to know what I'd be up against.
