10-01-2014, 09:25 AM | #1 |
Rep 383
'08 - 77k Miles - Rod Bearing Replacement Completed
Here's the separate post to my rod bearing replacement on my '08 with 77k miles.
My original Blackstone Oil Analysis thread was located here - http://www.m3post.com/forums/showthread.php?t=1037392 Of note - 1. I purchased this car used and the only info I could find was from running the VIN history. It appeared to be complete and up to date. 2. I have no idea on previous oil type or intervals. 3. I used and will be using Rotella T6 5w40. 4. I used WPC bearings and ARP rod bolts in for the swap. 5. Cost will vary depending on what you have done, what components you use, and what else they find in there. I would suspect for a straight forward job it should run you in the neighborhood of around $1800-$2300 plus tax. I make no claims what the shop will quote you. I would like to give a shout out to the shop who did the work - Bolt Motorsports - Richardson, Texas - Just outside of Dallas. http://www.boltmotorsports.com/ They specialize in exotics and other high horsepower cars like vettes, etc. Coulter Dean has a soft spot for BMW's, so he had no problem taking in my E90. Bolt Motorsports appears to do some methodical work. I couldn't have done the labeling or pictures better myself. Onto the pictures....I'm glad I had things done. Coulter mentioned that it appeared my pan was off at some point because they found some gasket scraping marks. It's also possible the bearings may have been swapped before, but it can't be said for certain. Last edited by douglee25; 10-02-2014 at 07:07 AM.. |
10-01-2014, 09:33 AM | #2 |
Rep 1,678
Drives: 2011 MCB E92 M3
Did you go with WPC treated bearings and ARP bolts? If so, where did you pick them up at?
2011 Monte Carlo Blue E92 ///M3 - ESS VT2-625
10-01-2014, 09:40 AM | #3 |
Rep 383
10-01-2014, 02:47 PM | #6 |
Rep 383
10-01-2014, 03:47 PM | #7 |
DSC Off!
307
Rep 718
More info please
Great to know as I'm in Dallas, and I'll be looking to do this in another year or so. I'm aware of several other M3 owners in the DFW area that have been looking for a reputable shop for bearing maintenance - yes, I said maintenance.
Please PM me the cost if you're not comfortable sharing here. I'm on my second engine - mine blew throwing rod bearings 1 and 4 at 82,000 miles. I plan to do this when this engine has 50,000 miles. Thanks, OP! |
10-01-2014, 05:05 PM | #8 |
Rep 4,744
Drives: S65 1M Clone & E92 M3 4.6L
not too bad at all. my 09 w/ 27k looked worse ( but still not terrible)
10-01-2014, 10:04 PM | #12 |
Rep 4,003
Were blackstone tests done prior to this? If they were I'm curious to know what they said.
Thanks
Grigio Telesto M4, 6MT. Coyote 5.0 F-150 991 GT3 |
10-02-2014, 01:36 AM | #13 |
Grease Monkey
295
Rep 2,646
Drives: 2011 E90 M3,1994 Euro E36 M3/4
These bearings look better than most S65 bearings I've seen at that kind of mileage.
The engine had no sign of contamination in the oil by looking at the bearings which would lead me to believe the engine was serviced quite regularly by it's previous owner(s) Of note is considerable wear at the edges and parting lines. The parting line wear is most likely excessive crush on the bearings and the wear on the edges most likely mean slightly distorted rod big end bores. Is is also possible that the edges could be experiencing a bit of fillet ride but the photos are not lodge enough for me to say for sure. All in all your engine looks better than most I've seen and you can be confident it will last for quite some time with the new bearings installed! |
10-02-2014, 02:06 AM | #14 | |
Rep 2,224
Wonder why pan had been off. Perhaps threaded drain holes or for bearings. |
10-02-2014, 02:28 AM | #15 | |
Rep 4,381
Its a shame that some bearing replacement threads end up randomly spread across several different threads as it dilutes the response. It also makes tracking the results more difficult. These bearing replacement posts all need to go in one thread (as a Sticky) so that they can be better logged. As should the engine failures which should go to "Blown motors, Bearing failure S65 Registry" (also should be a sticky) Last edited by SenorFunkyPants; 10-02-2014 at 07:03 AM.. |
10-02-2014, 07:06 AM | #16 | |||||||
Rep 383
See updated original post. Quote:
I hope that answers a lot of questions for people. Let me know if there's something else. Thanks. Doug |
