10-07-2014, 02:42 PM | #1 |
2152
Rep 5,011
KW Releases F80 M3 / F82 M4 Clubsport Coilover Photos!
Featured on BIMMERPOST.com From the KW press release: The KW Clubsport coilovers give BMW drivers who want to extract the maximum potential from their new M4 Coupé and M3 sedan on racetracks and on the street. KW Clubsport coilovers have been developed on the Nürburgring Nordschleife and allow separate adjustment of the rebound and compression similar to our Competition racing dampers. KW Variant 3 coilovers also offer a similar level of adjustment too. With so much adjustment available for the BMW M4 and BMW M3 suspension it allows fine-tuning for additional upgrades such as modified brakes, semi-slick tyres or increased engine power. With the rebound adjustment on the upper end of the piston rod the V3, Clubsport 2-way and 3-way coilovers can be adjusted with 16 clicks. With less rebound force the comfort will increase, whereas with increased rebound force the handling will improve and the bodywork roll reduced. Due to this, the steering precision will be improved when driving fast. The damping force in KW V3 and Clubsport 2-way can be adjusted manually with 12 clicks, with KW Clubsport 3-way offering further adjustment. Compression damping can be adjusted independently in the high and low speed range. High-speed compression adjustment can be varied between 14-steps and low-speed compression can be varied with 6-steps. A harder low-speed adjustment will cause a more direct steering behavior on the front axle and reduce oversteer at the rear axle. Furthermore, KW Clubsport top mounts improve the grip of sport and semi-slick tyres thanks to adjustable camber providing an optimal seating while driving through corners. No top mounts are available for Variant 3 coilovers, and the damping/spring rate is also different between the two coilovers. For those who want maximum performance on racetracks Clubsport is the ultimate solution. For sporty driving on the roads Variant 3 suits the M4 and M3 perfectly. Just like Variant 3 coilovers, KW Clubsport have a German TÜV Certificate meaning you can easily drive home with your M4 or M3 after hitting the track in total safety and control – simply change the settings to a more comfortable ride! A stainless steel threaded strut allows a German TÜV tested lowering range between 15-40mm on the front and rear axles, while KW adjustable lowering springs allow a continuous lowering of 5-25mm. Enjoy! Last edited by Sean@PSI; 10-07-2014 at 02:52 PM.. |
10-07-2014, 03:19 PM | #2 |
Croatian
884
Rep 3,613
Drives: PORSCHE
This is the @&*# !!
NARDO GREY '18 PANAMERA TURBO
Ducati V4 S Corse (track only) Husqvarna FS450 (track only) Looking for an SUV |
10-08-2014, 01:02 AM | #5 |
Rep 250
This is really great - and I am lucky that I have it already installed!
The setup and the performance of the CS in the M4 is really impressive until now. The car feels amazing - I am looking forward to be on the track for the first time with my M4 |
10-08-2014, 07:16 AM | #7 |
Rep 250
10-08-2014, 12:55 PM | #8 |
2152
Rep 5,011
10-10-2014, 08:41 AM | #11 |
Rep 592
Would love to test them in comparison to stock adaptive suspension. Can you elaborate on the handling difference in comparison to sport+ mode?
IG: hartmutkraft FB: seventeenjewels |
10-10-2014, 09:33 AM | #13 | |
Croatian
884
Rep 3,613
Drives: PORSCHE
10-10-2014, 10:34 AM | #14 |
Rep 435
You can install the KW DDC, when they are released. These replace the EDC but still remain electronically controlled.
10-10-2014, 11:21 AM | #15 |
Rep 3,039
I'm going to need a ride once you get these installed.
10-10-2014, 11:34 AM | #16 | |
Croatian
884
Rep 3,613
Drives: PORSCHE
10-10-2014, 01:03 PM | #19 |
Rep 3,446
Looks like a nice upgrade.
See my photography at http://ronscubadiver.wordpress.com
10-10-2014, 04:50 PM | #20 |
TIM YOYO
1504
Rep 3,283
Drives: 2013 M3
The adaptive suspension will continue to work fine... in a box... in your garage
Seriously though, this is a complete spring and damper replacement kit. You're literally taking the factory adaptive suspension off when you install this, so in terms of "affect", it completely eliminates it. Most people who want to go the aftermarket suspension route don't equip the car with adaptive suspension to begin with. If you do equip your car with adaptive suspension, you have to either buy an aftermarket suspension that supports it, or abandon adaptive altogether.
His: 2019 R1250GS - Black
Hers: 2013 X3 28i - N20 Mineral Silver / Sand Beige / Premium, Tech Past: 2013 ///M3 - Interlagos Blue Black M-DCT Past: 2010 135i - TiAg Coral Red 6MT ///M-Sport |
Tags |
bmw, coilover, kw suspension, precision sport, psi |
