11-01-2014, 11:51 PM | #3 |
Supreme Allied Commander
3885
Rep 54,494
Drives: F80 M3
There is zero adjustment on the F8x chassis. 3 bolts and 2 offset dowels equals to no movement at all. In addition, the tower is designed in a way that the upper mount is somewhat captured.
11-02-2014, 09:58 AM | #4 | |
Rep 1,424
11-03-2014, 10:18 AM | #5 |
3885
Rep 54,494
Drives: F80 M3
11-03-2014, 12:10 PM | #6 |
Rep 2,991
There aren't pins. The strut tower bars bolt directly to our top hats. You'll need a camber plate to adjust... and the strut tower bar mounts are going to make a Dinan-style offset plate much more difficult.
11-03-2014, 01:15 PM | #7 |
3885
Rep 54,494
Drives: F80 M3
Dinan is out of luck on this one. Camber plates using stock or sport type springs will be nearly impossible without adding significant stack height to the mount. A true camber plate is the only way to go.
11-04-2014, 12:36 PM | #8 |
Rep 1,424
Thats good info. So it is all or nothing. Unlike the E92 M3 where a person could just buy camber plates the new car requires coil overs + camber plates to save tires on the track/add performance. Maybe I would spec the car with passive susp. then plan on MCS singles.
11-04-2014, 05:49 PM | #9 | |
Rep 2,991
Plus, the F80 stock suspension is fantastic compared to the E92. |
11-05-2014, 07:02 AM | #10 |
Rep 1,749
putting in the KW HAS on our M4 now and was surprised at all the changes made to this generation M car versus all the previous.
no removable alignment pin in front no oblong strut tower holes for mini neg camber it requires removing about a dozen plastic fasteners and just as many nuts, plastic and rubber covers. the passenger side strut has a bolt that is entirely covered by the chasis brace which must be unbolted (6 bolts) to gain access to it. rear the struts are bolted in from the bottom. at least no removing of all the interior trunk panels. did that anyways but there is so many more fasteners on this car. multilink rear lower trailing arm needs to be unbolted from subframe and wheel hub in order to get the springs out.
"It gave you amazing satisfaction, but anyone who says he loved it is either a liar or he wasn't going fast enough." - Jackie Stewart on racing at the Nurburgring
11-05-2014, 01:17 PM | #11 | |
3885
Rep 54,494
Drives: F80 M3
Yes, the front strut top is more time consuming to get to. The rear spring should be an easy, just remove the inner nut and bolt so you do not disturb the camber settings. |
11-06-2014, 05:35 AM | #12 |
Rep 1,749
correct not the actual connection point on the wheel hub in rear. i meant unbolting the mounting point of the shock which has nothing to do with alignment. toe setting is the wheel hub knuckle.
Tags |
camber, negative, stock |
