10-11-2014, 12:45 AM | #1 |
NOOB
1603
Rep 1,356
Top won't close...frustrated
So last night I went out and had a good 20km drive with the top down. When I got there I closed the top with no problems. When I left, I again opened the top with no problems. When I got home and attempted to put the top back up, it only went about 1/3 way and now its just stuck in that position.
Basically the trunk is lifted but the entire 2 piece roof is sitting inside the trunk. I was able to reach in and make sure the cover thing is securely latched down but I didn't suspect that was the problem anyway since I have used the top 3 times that night without that issue. The top open button just blinks. When I go to press the top open button, the top close button goes on. Then I press the top close button and nothing happens. When I press either button, the cabin lights and cluster dim a little as if power is being pulled. Also note that the engine is running whenever I operate the top. So now I'm stuck at this position and the top will neither open nor close. The fuse isn't the problem as I've also checked. I doubt its a battery issue as I've had it running for some time and now I'm just thinking what other options I have aside from bringing it to a shop for diagnostics and handing over an organ of their choice. Any ideas guys?
@BMWclassicdivision
10-11-2014, 01:32 AM | #2 |
Rep 1,448
It's likely a sensor failure or worst case the pump.
Either way I thinks it's a dealer job. Mine is going in tomorrow for them to look at why it's jerking when closing. Next car isn't going to be convertible! |
10-11-2014, 09:42 AM | #4 |
35is driver
16
Rep 60
Trunk partition?
Check the trunk partition. If the sensor was just marginally making contact the vibrations could have dislodged it. It happened to me once this way.
10-11-2014, 12:06 PM | #5 |
Rep 190
Check to see that there is nothing lodged in the moving parts. This happened to me once. Something in the trunk was moving around and ended up getting caught in the mechanism arms. I removed the offender and top was fine.
10-11-2014, 12:39 PM | #6 |
Rep 2,387
Conversely, I can't imagine living without a convertible.
2016 340i XDrive, EBII/black, 6 MT, M Sport, Track Handling, Cold Weather, Tech, Lighting, Driver Assistance Plus.
2012 Z4 35i, ED 2/24/2012, Melbourne Red Metallic, Black Leather, Carbon Trim, 6MT, M Sport, CW, PP, PS, NAV, CA. |
10-11-2014, 01:52 PM | #7 |
Rep 1,448
Having one is one thing.. having one that's problematic is another.
These cars are IMHO far too complex and with that there are so many things that can go wrong.. and have in my case. I've learned my lesson and the next car will be simpler. |
10-11-2014, 03:09 PM | #8 |
Rep 2,387
I understand your concerns, but good luck finding a "simpler" car. There's nothing out there that isn't a jumble of computers nowadays. BMW doesn't have a lock on complexity. I guess a non-convertible would be simpler but what about all the other issues you've had? I think you just got a bad build like a few other people on here.
10-11-2014, 03:20 PM | #9 |
Rep 10,509
OP, have you tried pressing the open button, and let the trunk lid close up all the way?
Once I opened the roof, and then noticed there were some small raindrops coming so I tried to close the roof mid cycle, and I got the red blinking error light. I had to complete the open cycle, and then I could do the close cycle normally. It is a bit of a long shot, but I hope it helps. Also, if you are able to properly open the roof at least you can drive the car into the dealer, rather than having it on a flatbed with the trunk partly open The complexity almost makes the manually operating soft tops of yester-year appealing eh? |
10-11-2014, 09:55 PM | #11 | |
Rep 10,509
The surprises on other cars can be even nastier than what we have experienced in the E89 (i.e. C7 z51 losing engines from bad oil filters, 987.1 boxster/cayman having power steering overheat and oil starvation issues, E46 M3 bearing issues, 996 rear main seal, etc etc etc) All cars have an Achilles' heel, and the internet has way of magnifying these issues. |
10-12-2014, 07:03 AM | #12 | |
NOOB
1603
Rep 1,356
I'm also sure that there's nothing in the trunk and I've tried releasing and attaching the partition again with no luck. |
10-13-2014, 09:28 AM | #13 |
Rep 1,668
I have seen this happen on another Z i was goign to purchase. It wnet down but wouldnt come back up. red light just blinked. It was a sensor that was the fairlure.
Enjoying an E89 Z4, F30 320i and Fiat Abarth //
E85 Z4 (sold), E82 128i (sold), Fiat Pop 500 (sold) |
10-13-2014, 10:39 AM | #14 |
Rep 1,448
Meh well they've decided they can't do anything about my roof closing with a loud bump. They say its similar to those they have in the car park/lot. It isn't but perhaps its just an age of car/seasonal thing as its not doing it quite so much at the moment. They said there's no adjustment for that sort of thing, which I know there is a shim kit but the dealer says no. Whatever, I guess as usual I'll sort it myself somehow. On the flip side while there they said the alternator is failing so they've ordered a new one for fitment in a few weeks time. Damned expensive figures they quoted me too so I'm glad I have insured warranty, it will still cost me a couple of hundred but it would have been four times my excess if I'd paid for it myself.
10-13-2014, 03:12 PM | #15 | |
Rep 10,509
I broke the partition cover on my car so I'm having roof issues too... Hope you get it fixed soon. |
10-18-2014, 06:43 AM | #17 |
NOOB
1603
Rep 1,356
Well it is not the sensor so gonna be a cluster fxxk of bad news this point forward as we found oil all over the trunk, presumably some sort of hydraulic hose burst. Not sure if related but the red positive of the battery is burnt and luckily a fire didn't start.
Back order parts will probably take a good 6 to 8 weeks. I hope this bill stays under $2k usd. I'll report again once I get more info as I still haven't gone to the shop to see what's up. |
10-18-2014, 07:29 AM | #18 |
BMWZ4Rider
71
Rep 801
Ouch.
2009 BMW Z4 35i/SMG/DCT/Premium,Cold, Sound PK/Com Acc/Ash/PDC/Wind Deflector/Smoked Reflectors/Red Calipers/Cl Mask/M Series Grill/6000K LED's/De-Badged/M Pedals/CF Mirrors-Engine Cover/Stubby/20% Tint/H8 LED's/LCI Side Markers/Sniper Sprint Spoiler/VMR V710/H&R Sport Springs/KN.
10-18-2014, 01:57 PM | #20 | |
Rep 10,509
10-18-2014, 11:14 PM | #21 |
NOOB
1603
Rep 1,356
Yeah sad news is I've been trying to sell this car for several months now and this happens. For the 3 years I've had it, I've only driven roughly 10k kms on it. I question myself everyday why I got this car in the first place lol. Oh well, shit happens.
@BMWclassicdivision
10-21-2014, 07:09 AM | #22 |
Rep 85
Took my car into BMW today as was getting an error when closing the top - would stop when half way closed with an error saying there was an obstruction detected.
Found it to be that insulation had rubbed off on one of the wires (after 5 years of daily roof operation) that run between the roof sections (right hand side) so that when the roof was in that position it could earth, giving a false signal that there was a problem. Easy fix for the BMW guys to repair the wire. Roof working perfect again. |
