10-13-2014, 01:19 PM | #1 |
Rep 202
Leak near oil filter housing
Anybody familiar or can relate to this issue
MODS: JB4 G5 ISO, VRSF V2 3"DPS, N55 mid, ER CP, TIAL BOV, BMS DCI
10-13-2014, 03:14 PM | #4 |
European Editor
10633
Rep 22,992
OFHG - oil filter housing gasket...
Google is your friend...
e90 - N54 Oil Filter Housing gasket replacement (2007 335i automatic) http://www.e90post.com/forums/showthread.php?t=791674 N54 Oil Filter Housing gasket replacement DIY http://forums.bimmerforums.com/forum...eplacement-DIY Oil filter housing leak http://www.1addicts.com/forums/showthread.php?t=711625 Don't over torque THAT oil filter housing... http://www.1addicts.com/forums/showthread.php?t=508450 DIY - Your Oil filter housing gasket is leaking http://www.e90post.com/forums/showthread.php?t=476419 N54 Oil Filter Housing gasket replacement DIY http://forums.bimmerforums.com/forum...eplacement-DIY
10-13-2014, 03:48 PM | #5 | |
Rep 202
10-13-2014, 03:49 PM | #6 | |
Rep 202
10-13-2014, 03:51 PM | #7 | |
Rep 202
10-13-2014, 04:00 PM | #8 | |
European Editor
10633
Rep 22,992
#4 in this diagram... Get some non-flammable (CRC) Brake Kleen and spray down that area. Then recheck it. I think its your OFHG. Who ever been changing your oil has been over torquing the filter cap. Dackel
10-13-2014, 05:57 PM | #10 |
European Editor
10633
Rep 22,992
Check.
10-13-2014, 06:33 PM | #11 | |
Rep 202
10-13-2014, 09:58 PM | #12 | |
Rep 202
10-15-2014, 01:27 PM | #13 |
Rep 195
I can tell you the common mistake here, and that is using a strap wrench to remove the cover. It's made of plastic, and the strap distorts the cover's shape or roundness.
Always use a purpose built cap wrench for the removal. It is made of aluminum, and you'll find it on Amazon for $15 or so. |
10-16-2014, 12:49 AM | #15 |
Rep 299
10-18-2014, 01:34 AM | #17 |
Rep 49
Spilled oil from service, aftermarket oil filter +oring ect ect ect...
Get some brake clean and clean that up and check after a few drive cycles. Typically oil filter housing gaskets leak from below, not the cap. What you see is residue..if it starts to leak again, get a cap oring from BMW/new oil filter. Never go aftermarket with the filters...for multiple reasons..nuff said. |
10-19-2014, 12:31 PM | #18 |
Rep 233
10-19-2014, 02:28 PM | #19 |
European Editor
10633
Rep 22,992
@DSSG
^^correct! Too many people over tighten the oil filter cap. I fully believe this is what causes the OFH to leak. Dack
10-19-2014, 08:15 PM | #20 |
Rep 210
aren't you just supposed to line up the vertical green lines on the cap and housing?
'11 135i M-Sport DCT, M3 RSFB, PPK, CP, BMS intake, Agency Power Axle Back, VRSF 5.5" FMIC, FSB, M3/M1 Front + Rear Control Arms, Ground Control Coilovers, Ground Control Camber Plates, E92 M3 Front Seats, VMR 701's Squared 255's, E92 M3 Steering Rack - Daily Driven, Occasionally Tracked - 157k miles <SOLD> >2021 HS M2C Manual
10-20-2014, 04:50 PM | #22 |
European Editor
10633
Rep 22,992
Noop. They put that green mark on at the factory tell IF the oil filter has been changed - later down the (service)road.
