11-10-2014, 09:10 AM | #1 |
Rep 661
Brake pad pictures...what do you think?
So how do these look. The BMW dealer said my brakes were fine but an independent dealer a couple months ago said I only had 20% left on the rears.
First picture is front and the second is the rear. I have a month of maintenance and I'd like to get the rears done under it unless they have many more miles left on them. |
11-10-2014, 10:45 AM | #2 |
Rep 1,470
Rears wear very slow compared to front. Are both inside and outside pads equally worn and same in both sides with no taper? You clearly have more than 1000 miles left, so I doubt dealer will do anything.
Stoptech 380mm/355mm | PFC08 / Pagid RS-29 | Akrapovic EVO - CF tips | Benvo Tune | MS UDP | AA air filter | MCS 2-way with 700/1000lb springs | Solid bushings and adjustable links | RD front swaybar | Apex EC-7 18x10 square 275/35-18 NT01 | Turner Race Studs | GT4 Brake Cooling | GT4 Power Steering Cooling | Alekshop Oil Cooler | Performance Steering Wheel | | CF Spoiler | Varis System 1 Full CF Diffuser | Extended Paddle Shifters | Schroth Quick Fit Pro | Turner Steering Rack Stops | Vorshlag Camber Plates
11-10-2014, 03:27 PM | #4 |
Automobilist
396
Rep 2,632
My dealership advises that the pads be replaced at 5mm, but I'm not sure if that applies to the maintenance program. Will they only replace when the wear indicator is lit?
11-10-2014, 04:22 PM | #5 |
Rep 136
Drives: 2010 E90 M3, 2002 M coupe
I have 63,500 on the car and it is still on the original brakes... according to the service info in the car's computer. Needless to say, I checked them this weekend and the front piston boot was torn. I think the interval is really lame.
"M3 drivers have no friends." -Jezza |
11-11-2014, 02:02 PM | #7 |
Rep 3,633
why is the interval lame? I have 60k on original brakes as well and they still have lots of life as I drive all highway. Your boot being torn has nothing to do with the brake service intervals, as they get changed when the pad sensor kicks on (or a little earlier for those of us who don't want to change the sensor).
11-11-2014, 02:02 PM | #8 |
Rep 3,633
11-11-2014, 09:39 PM | #9 |
Rep 6,149
Find someone with worn OEM pads, slap them on and go back to a different dealer.
If you will be purchasing ANY AT&T services online or in store could you mention that you were referred by me? My Employee Referral ID is eo4489. This would be a great help and it costs you nothing, thank you!
