11-17-2014, 12:58 PM | #1 |
Rep 33
Anyone running Mobil 1 5W50??
TLDR: Like the title says, wondering if anyone is running Mobil 1 5W50?
If not, why? Looks like a good oil on paper... More info: I was comparing the product data sheets of the Mobil 1 5W50 and 0W40 to the TWS 10W60, and I was wondering if anyone is running their 5W50? It looks like a good choice on paper, but I'm by no means an expert on oil and the information presented in these sheets is nowhere near complete.... 0W40 data sheet 5W50 data sheet 10W60 MSDS I see a lot of people are running the Mobil 1 0W40 with good results, but can't find anyone who is running their 5W50 and I'm just curious why. I did a search, but all I could find on 5W50 was someone asking about Redline's 5W50 oil, and a couple responses saying it's not recommended for vehicles with catalytic converters due to some of the additives (though nobody mentioned which additives, and I didn't see any additive info on Redline's site, so I'm not sure where they got this info) Redline Product Data My car has test pipes (primary cat delete) and I will probably end up deleting the secondary cats this winter, so I'm not concerned with cats - just want the best oil for the engine/climate. I I live in North-eastern Ohio, and won't be driving the car in winter, but early spring and late fall still see temps in the 30s for a while. In the summer, 75-85° and the vast majority of the time we won't see anything over 90° ambient. I do hope to get in a few track days and was a little concerned about the 0W40 on the track being much thinner at higher temp. i.e. The kinematic viscosity ratings 100°C =22.2 for the TWS, 17.5 for the 5W50, and down to 13.5 for the 0W40. I'm not sure how dramatic this change is in real life, so this might not be an issue. I'm just looking for someone with more expertise on the subject to chime in and get some other's thoughts and opinions. |
11-17-2014, 02:41 PM | #2 |
Rep 2,301
Yes, I was the one who brought this idea up early in the other thread. There are some draw backs to 5W50 that made me go with 0W40 instead.
-It should be ok for cold starts, but since I drive my M in the winter, starting below 0F would most likely see some initial metal on metal grinding before start up. -The oil is NOT BMW LL01 approved. -The oil is 2x the price of M1 0W40 with much more limited availability. Only NAPA carries it in my area.
'07 335I w/ Mods
'13 X1 Stock '11 X3 K&N |
11-17-2014, 02:46 PM | #3 | |
Rep 2,301
'07 335I w/ Mods
11-17-2014, 04:37 PM | #4 | |
Rep 33
Also, interestingly enough, the 5W50 has a lower MRV rating - which I've read (but could be wrong) that when interpreting MRV ratings, the lower the better. It is my understanding that this score relates to the pumpability of the oil at low temperature (i.e. -35°C is stated on the Mobil 1 data sheets), which would indicate the 5W50 is actually more pumpable at lower temperature. My main concern with the 0W40 is the HTHS viscosity rating being soooo much lower than the 5W50 and TWS 10W60. The HTHS rating of the 5W50 is much better (nearly 20% greater) than the 0W40. Castrol doesn't list this spec on their site (that I could find) but I read in this thread that the TWS is around 4.5. I'm not an oil expert, but it is my understanding that generally speaking, a higher HTHS rating equates to better protection at higher temperatures, and this would be my primary concern with the 0W40. If anyone more knowledgeable about interpreting oil data sheets has more input, I would love to hear some thoughts on what the MRV and HTHS really mean in practical application. (not just on paper) Last edited by cbrf23; 11-17-2014 at 05:30 PM.. Reason: corrected typo |
STR8-6IX537.00 |
11-17-2014, 05:21 PM | #6 | |
Rep 33
Also, can I ask where you found that? I was looking on Castrol's US and Canadian websites and couldn't find it. (actually I couldn't find anything on the Canadian site) Last edited by cbrf23; 11-17-2014 at 05:28 PM.. Reason: Added more information. |
11-17-2014, 10:52 PM | #7 | |||
Rep 2,301
'07 335I w/ Mods
11-18-2014, 02:53 AM | #8 | |
Rep 4,381
On shear; my last Blackstone gave a cSt of 19.8 after 14000 miles and 1 qrt topup which equates to ~ a 55 weigh oil...but taking a large selection of 10W60 UOAs they average out at ~52 weight at the time of oil change. I've also seen a Blackstone report on the 10W60 with very low miles and it was around the high 18s cSt which does indicate a very fast shear down to a 53/4 weight oil, but then stays around that number for large mileages. This from: http://www.widman.biz/English/Calculators/Graph.html if it helps. All virgin oil numbers, but you can put any numbers you like into the calculator and see how they compare. |
11-18-2014, 06:27 AM | #9 |
Rep 33
@SenorFunkyPants
Great info - thank you! @Killerfish2012 I did take another look at the data sheets. The MRV rating for the 0W40 was at a 5° lower temperature than the 5W50. Just saying "it's fine" because another car with a completely different engine uss it is not an answer I would put any stock in. LOL. The design of the engine is completely different including layout and size of the oil gallies, clearances, valve train design, etc. without even getting into comparing a 7k RPM TT V6 to an 8.5k RPM NA V8. I realize there have been a few vehicles with bearing failure issues and that is what has driven most people to switch to a thinner oil, but the main/rod bearings are only part of the equation. Too thin of an oil can result in valvetrain lash and other top end problems at higher temps, as well as oil pressure issues which can result in oil starvation. Again, I'm more concerned with track time on this particular oil, as we can probably all agree that 0W40 is a better oil if you daily drive the car and never plan to run it on the track. I want to drive it on the street and on the track. This whole conversation is getting a bit off topic. I never intended to debate the use of 0W40 - there is another (very long) thread for that. I really am just interested in knowing people's thoughts on the 5W50 and why it doesn't seem to be a popular a choice, as on paper it looks like a very good alternative to the TWS. *Full disclosure, I am and plan to continue to use the TWS 10W60 for now and the immediate future. I"m just curious about other options. Right now my plan is simply to install an oil pressure gauge and monitor the oil health through oil pressure/temp as well as oil analysis at each change. |
11-18-2014, 10:19 AM | #10 | ||||
Rep 2,301
'07 335I w/ Mods
11-18-2014, 11:28 AM | #11 | |
Rep 142
FWIW, I drove every day this past winter with 10W-60 (in Iowa, plenty of cold and snow), and my oil analysis in March showed no change in performance over the previous August analysis (also 10W-60). There were many days of sub-0°F where my car sat in the parking lot outside for 10 hours, even a few -20°F days. Not that I think it's an excellent idea to run 10W-60 in the winter, but especially at 30° I doubt there would be any new problems. |
11-18-2014, 11:31 AM | #12 | |
Rep 142
11-18-2014, 12:15 PM | #13 | |
Rep 4,381
I don't know why it doesn't agree with your chart (or I've misread it). Its an interesting point you make about low temp usage...again the man at Castrol, when I questioned if the 10W60 would flow poorly in cold temps, was quite surprised and said it wouldn't be a problem for UK users as the oil is good down to -21C. I looked around to try and find some images of bearings that had accelerated wear due to poor (cold) oil flow to see what the pattern might look like but was unsuccessful. I suspect though that they wouldn't look like the typical wear pattern we are used to seeing in S65 rod bearings. |
11-18-2014, 12:17 PM | #14 | |
Rep 33
From what I've gathered on the Bobistheoilguy forums, the 10W60 shears to about a 50 weight as well - which is what made me think of the 5W50. @Killerfish2012 I did not mean to say any one rating told the whole story about the oil - I was simply making a point since up until this last post, you have simply stated your opinions without providing any argument behind them. I appreciate the last post in that you have provided some of that information. I have looked at most of the 10W40 oil analyses on this site (I have not on any GT-R forums) but an oil analysis again is only part of the whole story. On top of that, I really haven't found any posts of oil analysis that tell me the conditions in which the car was used (i.e. what track, how many laps, sustained oil temp, etc) which would be needed to make the analysis valuable in evaluating the oil's suitability to the task. Driving on the track means different things to different drivers. One can take a car out to the track, and never see temps above 210° running one or two laps then waiting and running another one or two laps. Another could go to the same track to the track in the same vehicle, and run 10 consecutive laps and be hitting near 300°. In the first scenario, the oil is not getting hot enough to evaluate its suitability for the second scenario. For example, with 4 hours sustained driving at speeds between 95-110 mph the temp hovers the whole time just below the 210 mark. I would not consider this track duty, but is more than some cars will ever see on a track. I haven't seen anything other than anecdotal evidence - i.e. nothing showing temp/oil pressure on the track or anything like that - to really be comfortable running anything other than the BMW 10W60 that is recommended. As far as I'm aware, the Mobil 1 0W40 is not approved for use in this vehicle either, so I'm not sure why you were saying that about the 5W50 not being recommended. I don't plan to use anything other than the recommended 10W60 in my car. I'm just really curious why everyone jumped on board the 0W40 bandwagon and nobody has tried the 5W50. If I was going to run something other than the recommended oil, it seems like a better choice. And as far as brands, I was just comparing the Mobil 1 products as an example. |
11-18-2014, 03:02 PM | #15 | ||
Rep 2,301
I would actually run this oil myself, but need something to help me start a car parked overnight in sub 0F temperatures, and from experience a 5W just doesn't cut it during start up.
'07 335I w/ Mods
11-18-2014, 03:04 PM | #16 | |
Rep 2,301
'07 335I w/ Mods
11-18-2014, 06:26 PM | #18 | |||
Rep 33
There is someone over on the Bobistheoilguy forum (Doug Hillary) who was actually involved in the development of the original formulation that became the TWS 10W60 - kind of interesting to hear his thoughts on this oil. I can't find the post right now, but I believe he says it was originally called something like Castrol "R" and was originally rated as 10w-50 or something like that. (not positive off hand) Anyways, he does claim the current ester TWS 10W60 has some very unique properties in low temperature flow for it's viscosity rating. There was a good post over there where they were discussing how the TWS 10W60 shears to essentially a 50 weight oil very quickly, then stabilizes and remains that weight for the rest of the service life of the oil. I wonder if there is a similar effect on the cold rating (i.e. does the 10W become 5W or 0W?) Last edited by cbrf23; 11-18-2014 at 06:33 PM.. Reason: added more information |
11-19-2014, 02:54 AM | #19 |
Rep 4,381
I've read a few posts spread over the internet written by people involved with BMW and/or Castrol 10W60 (including the one by Doug Hilary you mentioned) and they all hold the oil in very high regard. I have no doubt that Mobil 1 0W40 is a great oil when used as recommended (I've used it myself in Porsches), but I remain unconvinced that it is a better oil for the S65 (in fact I suspect the contrary), at least for for the majority of users who live in warm climates. However there may well be a good case for using M1 as a winter oil for harsh climates.
11-19-2014, 04:09 PM | #20 | |
Rep 2,665
Drives: Goggomobil
Interesting fill ... the oil cap says BMW recommends Castrol and the dealer fills it with Shell. By the way, if you haven't seen this, it's my first Blackstone oil analysis. http://www.m3post.com/forums/showpos...&postcount=431
F86 X6///
11-19-2014, 04:36 PM | #21 | |
Rep 3,633
I don't get why everyone here is gonna be surprised or wondering what the dealer will recommend now that the Castrol deal is gone. This is simple business, that's all. BMW now has an agreement to recommend another brand. For the M cars (older motors now) they will still recommend a 10w60 but now it will not be Castrol. As far as the Lubro Moly, I know of one very good shop that uses it and recommends it but my brother was also just in a shop and saw an e9x that the owner used Lubro Moly in and was making noise. Swapped to Castrol and all went away, so who knows. |
11-19-2014, 04:52 PM | #22 | |
Rep 4,381
I know it seems like I'm some sort of massive Castrol fan but I'm not, I just feel that if people are going to recommend other M3 owners to move away from the OEM oil weight they should have a compelling case to support it. It will really stir things up if BMW suggest a different oil weight for the S65 when the new Shell contract starts!!...I have a feeling that they will stick with the Castrol 10W60 though. Nice Blackstone report BTW. |
Tags |
0w50, 10w60, 5w50, mobil 1, oil |
