11-20-2014, 07:28 AM | #1 |
Rep 164
Changing Channels - One at a time
For the life of me I can't figure out how to change the Sirius channels one at a time without the 3+ step process in iDrive. I have multiple presets selected and frequently want to just go to the next (or previous) channel. Using the steering wheel control brings up the preset channels only, and the arrows on the dash do the same.
I'm sure I'm missing something and I've failed to discover it in the manual. . .help! TIA. |
11-26-2014, 02:44 PM | #2 | |
Rep 163
11-27-2014, 11:37 AM | #4 | |
Rep 164
Since you can have 40 presets, I bit the bullet and did all 40 channels I might listen to (in order) which has solved the problem. |
11-27-2014, 10:56 PM | #5 |
Rep 33
If you are in Presets then you will change to the next preset, but if you are in sat radio, it will go station by station. If you use them both a lot, I suggest you setup one of your favorites (1-8 on dashboard) for Presets and one for Sat Radio so you don't have to go through the idrive menus to go back and forth.
12-03-2014, 02:53 PM | #6 | |
Rep 164
