Next Level Auto Brokers
Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Technical Topics > Suspension | Brakes | Chassis
      11-29-2014, 03:28 PM   #1
zosoboogie
Drives: YMB M4/Silverstone
Brembo Brakes Question
Not sure if this question has been asked before however is there a noticeable braking difference between getting the Brembo GT Big Brake Kit and the Brembo GT-R Big Brake Kit on the track?
The price difference is huge and at the track I am not an expert driver at all so any honest input would be great, Thanks!
      11-29-2014, 03:50 PM   #2
gthal
gthal's Avatar
Drives: 2018 340i xDrive
My honest opinion is you are wasting your $$$.
I have been tracking cars for years and the OEM brakes with a set of track pads and fluid is all this car needs. I had no issues with very hard 30 minute lapping sessions at all. The OEM rotors and calipers are absolutely up to the task ESPECIALLY for a more intermediate driver.
If you upgrade to bigger Brembo brakes then you are doing it for the feel good factor only IMO. Spend your money on track wheels and tires and HPDE registration fees. Just my opinion.
2020 X3 M40i | Black | Current DD
2020 C8 Corvette | Z51 | Torch Red ... built and waiting for delivery
2016 M2 | Long Beach Blue | 6MT
2015 M4 | Austin Yellow | DCT
2012 MB C63AMG | 2011 E92 M3 | 2010 E92 M3
      11-29-2014, 04:03 PM   #3
zosoboogie
Cool thanks what about getting slotted rotors over the OEM rotors?
      11-29-2014, 04:12 PM   #4
Merli
Sunburnt Member
Australia
158
Drives: 2015 F82 M4
Generally, bigger brakes don't give you a performance increase by way of better stopping distances. They give you better performance by way of increased heat build up resistance and increased heat dissipation.
If your brakes can lock up your wheels (i.e. activate ABS), then your brakes aren't the weakest link.
If you want to increase braking performance (shorter stopping distances), put on stickier tyres (e.g. R-Compounds, Semi-slicks or Full racing slicks).
Of course NOW, with better tyres, you will be working your brakes much much harder, as they will generate a lot more heat in the rotors, pads and fluids, so then NOW you may benefit from uprated calipers, rotors and pads.
2019 Deep Blue Tesla Model 3 Performance | 2015 Mineral White F82 M4 | 2010 Burnt Orange Lotus Exige S2
Past: 2009 Ibis White S5 (APR Supercharged V8)
Past: 2004 Imola Red M3 Convertible
      11-29-2014, 04:16 PM   #5
thebishman
Drives: ‘24 iX M60
At your level the OEM brakes are perfect. Just replace the OEM brake fluid with something with a higher boiling point and you'll be good to go. As you get faster, then think about upgrading the pads. After that and when you're very comfortable on track, think about some DOT R compound tyres.
Bish
      11-29-2014, 05:00 PM   #6
gthal
gthal's Avatar
Slotted are arguably better for track use but, again, for an intermediate driver the OEM drilled rotors are more than fine.
      11-29-2014, 05:10 PM   #7
zosoboogie
I have some experience...thinking getting stainless steel brake lines, 600 degree brake fluid for the first or second rounds then later upgrading the rotors to slotted as on my last car the cross drilled rotors cracked. Rotors, pads and some sport cups 2s as I drive to the track as well, Sebring, Daytona and Homestead!!
      11-29-2014, 06:38 PM   #8
Reid
Reid's Avatar
253
Drives: white cars
Brake fluid is all you need. Upgrade to stainless lines only if you want slightly better feel.
Other than that, save your money and wait until the stock rotors are spent before replacing them.
f80post
