      11-29-2014, 06:44 PM   #1
tglazed
Drives: 135i
Shredded serpentine belt
So while driving to work today, my serpentine belt shredded. I was five minutes from work and coasted the rest of the way. I put in a new tensioner pulley and put on a new belt and the car then shredded the new belt. Everything was aligned. One thing that wasn't making sense while I was putting the new idler pulley on was that the top pulley was not grooves when it should be. Can anyone confirm if this part is suppose to be grooved?
      11-30-2014, 09:44 AM   #2
Recklessdr1ver
Drives: 2009 AW E82 N54
It should be smooth. Mine was shredded once and the shop I took it to had a difficult time trying to figure out the same thing but that's the way it is
      11-30-2014, 03:42 PM   #3
tglazed
Drives: 135i
I have my fan out and am checking all my pulleys to make sure no belt reminants was lodged in between them. I'm spinning the ac compressor pulley and it is taking some force to spin it. I wouldn't say a lot of force but should it turn as freely as the rest of the pulleys or should I take out the ac compressor unit.
      11-30-2014, 04:23 PM   #4
tglazed
Drives: 135i
Also what are reasons why my belt would have shredded. I have done lots of research and can't figure it out. No contact with the subframe. No weird sounds. Not sure what to look for
      11-30-2014, 04:25 PM   #5
Freon
Drives: 2009 135i
Have you inspected all the pulleys for damage? If something got caught between the belt and any of the pulleys it could have damaged the pulley and left a sharp edge.
2009 BMW 135i 6MT Sport, AFE intake, Cobb AP, Apex 18x8.5+9.5, 255/275 PSS
      11-30-2014, 04:32 PM   #6
tglazed
Drives: 135i
Yes but there was one thing that caught my attention. I was circling my finger around the crank shaft and found a sharp metal edge on the bottom passenger side of the pulley. (Sharp metal edge is not on the pulley, it is coming from something else) Can't get a clear picture with my phone so I'm not sure if it is part of something or not. But the belt was literally shredded perfectly even. Is it possible that the belt jumped and just kept getting shredded? Also, I put a new tensioner on a week before this all happened. Is it possible that the new tensioner was the old recalled tensioner and that is why the belt jumped and shredded?
      12-07-2014, 03:12 PM   #7
tglazed
Drives: 135i
Well I checked all pulleys and belts and replaced the tensioner thinking I may of had a bad one. Everything was fine but my car decided to shred another belt today. Could really use some help here. I can't figure out why the hell the belt is getting shredded. Pulleys have all been replaced... It runs fine for about a week then shreds the belt. Not sure what is going on here.
      12-08-2014, 10:41 AM   #8
tglazed
Drives: 135i
Anyone? I'm getting a laser alignment tool to check everything and make sure there aren't any crooked pulleys
      12-08-2014, 11:13 AM   #9
MightyMouseTech
MightyMouseTech's Avatar
4338
Drives: 13 135i 6MT LeMans Blue MSport
The A/C pulley should spin just as smooth/freely as the other pulleys, as long as the A/C is turned off and the clutch is disengaged. May be the clutch stuck on, or a bad bearing on the compressor pulley.
      12-08-2014, 01:15 PM   #10
tglazed
Drives: 135i
If the ac pulley was seized, would that make the belt shred though? I'll take a look at it tomorrow because it is my day off. And why would it take an entire week to make the belt shred
      12-08-2014, 01:57 PM   #11
MightyMouseTech
4338
Damn right it would.
      12-08-2014, 02:08 PM   #12
tglazed
Drives: 135i
I'm going to record me spinning it before doing anything. That way you can give me your opinion if it needs replaced. Also, what would I replace if it is the ac compressor. The whole unit or just the bearing?
      12-08-2014, 02:25 PM   #13
MightyMouseTech
4338
Depends if you can get the bearing off the snout of the compressor. You will probably need the complete A/C clutch, which should come with a new bearing. You will need feeler gauges to set the clearance on the new clutch.
      12-08-2014, 02:50 PM   #14
tglazed
Drives: 135i
I'm a rookie when it comes to the ac system. So just looking and reading about parts. I would need a new ac clutch? I do not need an entire ac compressor that is 560 dollars on ecstuning.
Thanks for your help by the way
      12-08-2014, 05:41 PM   #15
pdisher
privateer
pdisher's Avatar
Drives: 2011 MB E350 - Bluetec
will this work?
http://www.turnermotorsport.com/p-43...526956716.aspx
      12-08-2014, 06:42 PM   #16
tglazed
Drives: 135i
No that's for naturally aspirated motors. Not sure if it would matter but wouldn't want to risk it
      12-08-2014, 06:53 PM   #17
Dackelone
European Editor
Dackelone's Avatar
Germany
10633
Drives: N54 e82
Some guys have had a shredded belt issues - do to launching the car from a start HARD or when making power shifts(hard 1st to 2nd). The motor mounts allow the engine to move enough that the front crankshaft pulley will contact the front core support. Do that enough times and your belt will pay the price. I remember a few guys who had to replace the front crank pulley bc of this. And it wasn't a cheap repair from what I remember. That harmonic pulley was bucko's.
It could also be one of your tensioner pulleys. One of the ball bearings could be damaged, and when it gets caught JUST right inside the tensioner's race, it locks up and causes the belt to be damaged.
Dack
      12-08-2014, 08:39 PM   #18
tglazed
Drives: 135i
I checked the powersteering pulley and crank pulley to see if any of those had happened. No marks or anything and both pulleys are in perfect working order. No chips or anything. I've replqced the tensioner pulley twice and the idler pulleys twice so those are out. I'm going to look into the ac compressor unit. And making sure the pulleys are all perfectly aligned
      12-08-2014, 09:21 PM   #19
tglazed
Drives: 135i
Would a 2007 335i and a 2008 135i have the same ac compressor. Obviously they are both n54's but did they change the compressor at all?
      12-09-2014, 12:49 PM   #20
tglazed
Drives: 135i
Videos aren't working but Ill keep trying today. A bit frustrated. The a/c compressor seems to be fine. Everything is aligned and runs great and then a week later it shreds the belt. I am 100 % lost on what would be causing the belt to shred. There are no belt burn marks anywhere. No slivers, the belt is being routed the proper way. Anyone know the correct torque for the alternator bolts. I made sure that it was aligned and am not sure what torque to put the bolts back at.
      12-09-2014, 03:01 PM   #21
tglazed
Drives: 135i
http://img.photobucket.com/albums/v7...5i-motor-9.jpg
Is anyones belt routed like this because I am not routing mine this way.
      12-10-2014, 01:11 AM   #22
joe86
Drives: 08 135 coupe
1addicts
