12-08-2014, 07:02 PM | #1 |
Rep 325
Some questions about clutch bleeding...
Hey guys I'm tackling a whole bunch of projects on my car at once....
Figure if I already lifted the car and removed the plastic panneling its time to to install the modified CDV. some questions about bleeding the clutch.... Is reverse bleeding as easy as it looks? (already bought a oiler can and some tubing) Does the pedal need to be actuated when I reverse bleed? how about afterwards? Should I let out some fluid out first or just begin reverse bleeding? How important is priming the tube first? |
12-08-2014, 08:37 PM | #2 |
Rep 1,293
By reverse bleeding I assume you mean using a vacuum bleeder. I have never tried this with the clutch, but a couple comments... The space is pretty tight. I wouldn't want to try to actuate the vacuum, keep the tube on the bleed screw, and turn the wrench at the same time. I'm sure it it possible, but I have to imagine it would be a PITA. Also keep in mind that the bleed screw is plastic and can snap off if you're not careful.
Just an FYI... I used a pressure bleeder when swapping out my CDV. Even after running several ounces of clean brake fluid through the bleed screw with zero bubbles, the pedal pressure was nonexistent. I had to pump the clutch 50-100 times before the clutch pressure was back to normal. I've had zero issues since. |
12-08-2014, 08:40 PM | #3 |
Rep 325
Thanks! You seem to be the only guy online today...
Mods: Clutch stop, BMW performance SSK, BMW PE exhaust, CDV delete, Clutch pedal spring delete (CPS delete) : ) - check out the the DIY:http://www.1addicts.com/forums/showthread.php?t=1122797
12-09-2014, 08:57 AM | #4 |
Rep 325
12-09-2014, 08:58 AM | #5 |
Rep 325
Tool recommendation anyone?
12-09-2014, 09:06 AM | #6 | |
European Editor
10633
Rep 22,992
When I did my CDV delete I just used my pressure bleeder. I use a Motive unit like this. http://motiveproducts.3dcartstores.c...der_p_115.html My backup plan was to use an oiler can and reverse bleed IF it did not work. Using the Motive presser bleeder I did have some issues with getting some trapped air out. I might just use an oiler next time around - I need to do a CDV on another car.
