New 2009 2010 BMW Z4 - ZPOST
Go Back   New 2009 2010 BMW Z4 - ZPOST > BMW Z4 Forum (E89) > 2009-Current Z4 Forum (E89) General Discussion
      01-02-2015, 12:03 PM   #1
digidee
Drives: 2013 Z4 (E89)
DIY - E89 Replace the Ashtray with Sunglasses Holder
DIY E89 - How to replace the ashtray with sunglasses holder.
If you drive an E89 (or any Z4 for that matter) you know that space is a premium so if you are a nonsmoker, this is a great way to gain a little more storage inside the cockpit. I have the 8-speed Steptronic Sport transmission without a navigation system. As far as I can tell, the sunglasses holder comes with the navigation system setup. Without the navigation, you get the ashtray.
I guess smokers don't need navigation?
Overall, this is a very simple and inexpensive swap. The storage unit or sunglasses holder (#5166 9 157 590) was about $25 from the deal and the process only took about an hour and a half - I moved pretty slow and my approach was to remove as few parts as possible.
Step #1 - Remove the Armrest Console tray.
Pull out the 3 rubber matts and 4 Torx screws to remove the center console tray.
(I forgot to take a picture of the console after removing the try so I stole this pic from another post. Thanks other post!)
Step #2 - Pull the shifter boot holder up.
I have an 8-speed Steptronic Sport transmission and didn't want to bother removing the shifter knob. There is no need.
Step #3 - Pull the center console up - Do not remove completely!
With a minimal approach, there is no need to completely remove the center console.
Note: The front of the console is wedged in pretty tightly between the lower dash and clips. Take your time and be gentle.
Step #4 - Unplug the Ashtray
Depending on your transmission - You might need to move the shifter a bit in order to turn the console sideways. Be sure to tuck the wire away into a safe place where it will not interfere with the sunglasses / storage tray.
Step #5 - Remove the ashtray
There are 4 Torx screws holding the ashtray to the console - two on each side. Again, depending on your transmission, you might need to move the shifter around in order to slide the ashtray out once it's unplugged and the screws are removed.
Step #6 - Install the sunglasses / storage tray
This will take less wrangling than removing the ashtray. Once it's in place, insert all 4 screws.
Once the sunglasses / storage tray is screwed in, simply snap the console and shifter boot back into place and replace the armrest console tray.
Note: Go slow when snapping the center console back in place. Remember, the front is wedged in pretty tight so some force is necessary.
In the end, you will have a much more functional space to hold your cell phone, sunglasses or other nicknacks. And you will have a spare ashtray just in case.
      01-02-2015, 01:29 PM   #2
paris1
Drives: 2013 35i Space Grey over Coral
Thanks for this. Didn't know it was an option and I found one on ebay for $15 incl. shipping!
      01-03-2015, 03:16 AM   #3
nicknaz
nicknaz's Avatar
3189
Drives: C6Z
What year are your cars? My car (12/11 build, 2012 model year) has no navi and came with the empty storage cubby not the ashtray. Do you still have the 12v volt outlet in the passenger footwell, under the glove box?
      01-03-2015, 03:32 PM   #4
CedarZ4
Drives: G05 M50i, Tesla M3P
Ditto. My car also has an empty storage compartment and not the ashtray with 12V outlet.
It looks like you are based in the US as well, which is peculiar. All cars I remember seeing did not have an ashtray there.
      01-03-2015, 04:52 PM   #5
Crazykoh
Crazykoh's Avatar
Drives: 2018 M3 Mineral White
2018 BMW  [0.00]
I thought having the ashtray was an option when building the car. Did you get yours used or off the lot as opposed to an order?
2018 F80 M3, Mineral White, Full Sakhir Orange, ZCP
2015 F15 X5 35i, Mineral Silver, Terra Dakota (Retired)
2012 E89 Z4 35i, Deep Sea Blue, Walnut Kansas (Retired)
      01-03-2015, 05:10 PM   #6
paris1
Mine was a CPO car we purchased in Oct, 2014. So it must have originally been used by a factory rep or something. However, there are no indications it was ever smoked in (thank god!).
      01-03-2015, 06:12 PM   #7
Squddie
Squddie's Avatar
Drives: E89 Z4
I just got a new one in the US and it is ashtrayed. I certainly didn't order it with smoker package.
      01-04-2015, 02:21 PM   #8
digidee
It's a 2013 - no 12 volt under the glove box but I do have one in the center armrest.
      11-13-2017, 11:23 AM   #9
Kessler35is
Drives: 2015 F15 50i, 2016 E89 35is
2016 Z4 35is  [0.00]
2015 X5 50i  [0.00]
Does anyone know the part that is needed to put the 12v plug back in the panel in the footwell?
I want to remove the ashtray and add the power socket down there since it is not there with the ashtray socket. I am guessing the wire that powers the ashtray is the same that powers the footwell socket and that's why you do not get both of them.
Any photos of the backside of the panel & some close up's of the 12v socket & connector it is using since I am seeing multiple types of parts listed.
      02-20-2024, 10:16 PM   #10
mittu
Drives: 530d xdrive
Ater the swap is there any way to re-attach the lid?
      02-21-2024, 12:42 AM   #11
DavesZed
DavesZed's Avatar
Drives: BMW E89 23i, 2011
In short, NO!
Dave
2011, E89 23i, Grey with Red leather.... relatively basic (getting less and less basic with every new retrofit)!
My Z4 E89 YouTube channel...
https://www.youtube.com/channel/UCtt...0vHFUQnoEvKB2Q
      03-30-2024, 09:02 AM   #12
Renfield
Drives: 2013 BMW E89 black on black
Originally Posted by DavesZed View Post
In short, NO!
And there's the rub. Big pass.
      03-30-2024, 09:12 AM   #13
DavesZed
DavesZed's Avatar
You "could" fabricate the new tray onto the ashtray (plastic welding/filler) and retain the folding lid.
It would take a bit of sorting, but not impossible.
Dave
Tags
#5116 9 157 590, diy, e89 diy, replace ashtray, sunglasses holder
zpost
