01-03-2015, 08:51 PM | #1 |
Rep 539
2012 128i part out
Turned in 128i after lease. All pick up only! zip 44124 (Cleveland area). Best offer on each - Updated BMW OEM 2012 Refreshed front bumper! (Looks MUCH better than 2008-2010) - BMW OEM 2012 Circle Foglights - Original OEM 128i muffler with only 10,000 miles on it - Pair of standard non LED taillights - Oem 128i 6 Speed Shifter - 18 inch APEX ARC-8 Wheels (all same size) in Hyper Black - 4 Continental 18 inch DWS tires with only 3-4k miles on them Wont last long!! Make me offers! Pick up only! THX
01-04-2015, 12:12 AM | #3 |
Rep 539
Specifications
Diameter: 18" Width: 8.5" Offset: 45mm Lug Pattern: 5x120mm Centerbore: 72.56mm Weight: ~18.20lbs Profile 1 Available in 4 Finishes: Hyper Silver Hyper Black Anthracite Satin Black Manufacturing The ARC-8 is produced using the Flow-forming technique. Flow-forming, which has also been called 'spin forging', produces a barrel with similar strength to that of a fully forged wheel. This significantly reduces weight in the barrel, which has the greatest impact on rotational mass and performance. By combining the strength of a forged, lightweight barrel and a more robust face design, we've produced a wheel that welcomes endurance racing, hard driving, and even potholes. ARC-8 Features & Benefits Seventeen unique fitments in 17" and 18" sizes Designed for spacerless fitment for most applications Minimizes the requirement for spacers to achieve a perfect fit Maximize wheel/tire width with model-specific fitments Seventeen inch sizes reduce tire cost for track day wheels Spoke design and barrel work together to create additional brake clearance Seventeens have clearance for up to 355mm BBKs in many applications Eighteens have clearance for up to 380mm BBKs in many applications Mesh design Load is more evenly distributed to reduce stress and enhance durability Aesthetics aren't compromised to create strength Lipless design Maximizes strength in the most vulnerable area of the wheel Greatly reduces bends and damage from small impacts APEX ARC-8 wheels are JWL tested and VIA certified Each size and fitment is tested and certified Factory Fit Designed for BMW applications, the ARC-8 accepts TPMS sensors, factory lug bolts or stud conversion kits, and OEM roundel center caps. All wheels come with APEX center caps. Open center Easy lug access and reduced weight Unpainted lug recesses Prevents wheel bolts or lug nuts from loosening Mounting wheels does not damage the finish The ARC-8 is perfect for street, track, and race.
01-04-2015, 04:46 PM | #5 |
Rep 539
"Turned in 128i after lease. All pick up only! zip 44124 (Cleveland area). Best offer on each"
01-16-2015, 03:07 PM | #6 |
Rep 61
I would like the bumper and fog lights but don't know how soon I could get to Cleveland to pick up. If I paid for them do you have room to store for a while, perhaps 2-3 months?
01-16-2015, 03:08 PM | #7 |
Rep 61
And by the way, was it a big job to change bumpers and fog lights? I have a 2011 128i.
Also, what did you do about the air vents they added in 2012. Was it necessary to block them off or a non-issue? |
