01-04-2015, 10:19 AM | #1 |
Rep 1,555
AutoCross Helmet
Just got back from driving school in South Carolina and have the bug. I only did the car control school (Not M school) but it was still much more than I had expected. I plan on doing my first Autocross later this month.
Are the helmets that people wear in autocross the same helmets that bikers wear? Is there anything I need to know about choosing a helmet before I go out to buy one? Thanks for any input you can give.
2015 M4 6-MT
01-04-2015, 11:38 AM | #2 |
Enjoying driving
388
Rep 1,169
They are not the same and if you intend to run with SCCA or PCA for example (I do not know if BMWCCA checks helmets at autox), they won't pass a motorcycle helmet. Generally organizations have loaner helmets on site, but you would want to check before going. Also, if you have a nearby shop that does sell motorsport helmets, they may have few to rent as well. Once you decide to do either autox or DE for longer term, you will need to have your own proper 2010 certified helmet.
01-04-2015, 01:30 PM | #3 |
Rep 10,509
OP, you need to check with the club that you plan to autocross with. I used a motorcycle helmet for autocross for a few years (since I already had one).
If you are buying from scratch, an SA (motorsport) helmet is a better idea. At the risk of stating the obvious, plan to spent a few hours at the helmet shop if this is your first time getting one to make sure you get the fit right |
01-04-2015, 01:38 PM | #4 |
Rep 468
+1 on Snell certified SA 2010, if buying new. Certification is good for 10 years, so you'll have 5 years left, which is a lot...
BMWCCA Golden Gate Chapter allows both SA and M for AutoX and HPDE. DOT helmet is usually not enough. |
01-04-2015, 04:51 PM | #5 | |
Rep 1,555
2015 M4 6-MT
01-04-2015, 04:52 PM | #6 | |
Rep 1,555
2015 M4 6-MT
01-04-2015, 05:05 PM | #7 | |
Rep 551
FWIW, SA 2015 certified helmets will be available on October 1, 2015 when the new standard takes effect. |
01-04-2015, 08:47 PM | #8 |
Rep 1,789
Drives: wife crazy
Garage List 2019 Ford Raptor [0.00]
2016 Porsche 991.1 ... [0.00] 1987 Chevy Camaro I ... [0.00] 1972 Chevy Corvette [0.00] 1999 BMW M3 race car [0.00] |
May as well get one that is Hans compatible too while you're at it. You may progress to DE, TT, and even W2W if the disease takes hold of you hard like it has for many of us.
Road course laptimes for BMW M4 2015 6MT
WHP East Track: 1:04.880, Arizona Motorsports Park: 1:54.352 Road course laptimes for Porsche 911 991.1 GTS 7MT WHP East Track: 1:02.770, Arizona Motorsports Park: 1:48.889 |
01-04-2015, 10:45 PM | #9 | |
Rep 1,997
i definitely WOULD, however, find out from the chapter you plan on running with to make sure you're covered if you find a motorcycle helmet, or if they have any restrictions at all (e.g. less than full coverage helmets, i haven't seen any but easy enough to ask). i'd probably just buy a full-monty helmet .. having the extra face coverage may save you from getting debris embedded in your eye, forehead, cheek…. i've heard stories and it's an easy enough thing to prevent. remember you'll have your window down and driving 100+ on the heels of the guy ahead of you throwing up tons of debris can increase chances of non-collision related injuries. just a thought! the less-than full helmets are definitely more comfortable, easier to communicate while wearing, and cooler temperature wise. finding the right helmet isn't easy, and in-store is ideal but not possible for a lot of us. using an online vendor (such as saferacer dot com) may be your best option. use their sizing information and give them a call if you have questions about fitment. good luck and glad you found a new hobby! do some auto crosses to practice (and get comfortable having the traction control diminished/off) and then take the plunge into HPDEs. have fun and be safe! matt
Gone but not forgotten: '09 STi // '08 335i // '02 M3 // '11 335i // '15 M3 // '16 M3 // '16 Camaro SS // '16 Audi S3 // '18 Boxster 718S // '17 Camaro SS 1LE // '16 M6 GC CP
01-04-2015, 11:11 PM | #10 |
Enjoying driving
388
Rep 1,169
All of those clubs have it in their rule books (I have to double check BMW CCA, but I distinctly remember from 2002 they had it) that motorcycle helmets are not allowed, so if they are passing it during tech inspection regardless that's not my fault On the east cost, I Don't know of any chapter/region that would let it through
01-04-2015, 11:23 PM | #11 | |
Rep 290
OP, these are the SCCA approved helmets and the label inside the helmet to look for - most are for motorcycles: http://scca.cdn.racersites.com/prod/...ert_decals.pdf" rel="ugc" target="_blank">http://<a href="http://scca.cdn.race...decals.pdf</a> In general SNELL rating is required as long as it is not too old, motorcycle or not. |
01-05-2015, 12:33 AM | #12 |
Enjoying driving
388
Rep 1,169
SNELL has multiple certifications that one should look for:
Both SA and K standards include multi-impact roll-bar testing, while the M standard does not, as it is not designed for this use. SA standard requires a flammability test, while the K and M standards do not, and both SA and K standards allow a narrower FoV (field of view) while the M standard requires significantly more peripheral vision. BMW CCA does allow for M certified helmets apparently, even for DE: https://www.bmwcca.org/events/hpde SCCA also allows for M certified helmets in Solo (autox), but not HPDE or time trials: Solo: http://scca.cdn.racersites.com/prod/..._b_reduced.pdf Race/DE/Time Trials, actually require 8860 cert: http://scca.cdn.racersites.com/prod/...CR-January.pdf NASA requires SA cert (1995 at that) for cars and M cert for motorcycles for DE: https://nasa-assets.s3.amazonaws.com...nt/282/ccr.pdf PCA requires SA cert for DE and autox, but varies from region to region as mentioned previously. So if you are buying/using a helmet for safety purposes, and not just due some obligation, please use the proper helmet with certification for its intended purpose. Last edited by FTS; 01-05-2015 at 01:00 AM.. |
01-05-2015, 12:48 AM | #13 | |
Rep 290
01-05-2015, 01:09 AM | #14 |
Enjoying driving
388
Rep 1,169
SCCA also allows for M certified helmets in Solo (autox), but not HPDE or time trials: Solo: http://scca.cdn.racersites.com/prod/..._b_reduced.pdf Race/DE/Time Trials, actually require 8860 cert: http://scca.cdn.racersites.com/prod/...CR-January.pdf NASA requires SA cert (1995 at that) for cars and M cert for motorcycles for DE: https://nasa-assets.s3.amazonaws.com...nt/282/ccr.pdf PCA requires SA cert for DE and autox, but varies from region to region as mentioned previously, my region requires SA cert. So, if a club or region requires SA cert and they check for compliance, they won't pass a M cert helmet. Moreover, as I tried to explain what certs mean briefly, one should not use M cert helmets for auto racing even if allowed, but that is a personal choice. If the argument is that my statement is not 100% accurate for all situations, I conceded; apparently some clubs and regions do allow. However, looking at rule books and understanding the different SNELL ratings is important. |
01-05-2015, 01:30 AM | #15 | |
Rep 290
01-06-2015, 09:49 PM | #16 | |
Rep 1,997
My advice to anyone buying a helmet for HPDE/autox would be to get an SA helmet. I was getting my motorcycle license so I got that helmet and later started doing DEs. my next helmet will definitely be SA and probably look into hans as well.
01-07-2015, 10:56 AM | #17 |
Rep 124
For SCCA Autocross the only requirement is that it is SNELL certified. SNELL offers a motorcycle rating called SNELL-M. So technically YES a SNELL rated motorcycle helmet is allowed for SCCA autocross. Here is a link to an inexpensive helmet that would be approved for SCCA AutoX for the next 5 years. http://www.motorcycle-superstore.com...T.ac=SLIsearch
01-07-2015, 04:34 PM | #18 | |
Rep 10,509
I've heard people say that's not a good idea. |
01-07-2015, 07:09 PM | #19 | |
Rep 253
Drives: '98 M3/4 TiAg, '15 M3 SO
Dave |
01-07-2015, 10:38 PM | #20 | |
Rep 1,789
Drives: wife crazy
http://www.m3forum.net/m3forum/showthread.php?t=488154 Just mentioned for OP to get a Hans compatible helmet but wouldn't necessarily need the Hans yet for just autocross.
01-08-2015, 11:12 AM | #21 | |
Rep 10,509
I know there is that usual "how much is your head worth" argument, but you don't need to get a $1000 arai helmet $180 Racequip helmet, SA2010 rated and is predrilled for HANS http://wescoperformance.stores.yahoo...id=60208817302 I personally use something similar to that for DE and Autox. I don't have a HANS device but am thinking about it |
01-08-2015, 08:31 PM | #22 | |
Rep 253
Do you have harnesses? If you have airbags and 3 point belts, the effectiveness/necessity for a HANS device is questionable. The R3 device was designed to be effective with 3pt belts but it is NLA. For my track car that is getting a roll bar and harnesses this winter, I'm definitely looking into a HANS device. Dave Last edited by dngo; 01-09-2015 at 06:04 AM.. |
