01-25-2015, 05:37 PM | #1 |
Rep 1,410
Drives: X3 M40i
2012 135i LCI Headlight Condensation
Hey guys - I recently bought a 135i m sport and noticed condensation in both headlights. One is slightly worse than the other and it doesn't seem to burn off with the xenons on. Also there is a very slight shake of one of the headlights over bumps. Could it be a bit loose due to the BMW performance suspension that's installed? It's a very tight / hard ride when combined with the runflats.
Check out the pic and let me know if you have thoughts on the condensation. Car was bought used but has a clean carfax so I don't think it's even been in an accident and had them replaced. Still have warranty so plan on taking it in to be looked at as soon as I get time. |
01-25-2015, 06:18 PM | #2 |
Rep 275
Most likely the bulbs were changed and someone didn't put the covers back on correctly. They are a huge pain to get right. Since you are under warranty I would take it in and make a note of it in case something goes wrong down the road.
02-01-2015, 05:18 PM | #3 |
Rep 164
Agreed, sometimes that can occur from the headlights not being aligned on correctly, taking it in to your local BMW would be your best bet. They will probably help you figure it out and put them on right if that is the case for little to no charge.
02-01-2015, 11:00 PM | #4 |
Rep 1,410
Drives: X3 M40i
also noticed the headlight bounces a bit over bumps in the road... thinking maybe a bracket is broken.. hope BMW replaces it under warranty
