02-05-2015, 11:16 PM | #1 |
Rep 120
Drives: 2002 M3, 2003 M3, 2015 M4
Hoosier 285/30X18 on Apex EC-7 18X10 ET43 Wheel
Just test fit this on the front of my M4. With a 15MM spacer and ET43 offset, I have a little less than 1/8 inch clearance between the strut and the side wall of the Hoosier with the BMW adaptive suspension. Is this enough clearance? The Hoosier is built up a little, close to the wheel like a bit of curb protection. Clearance looks good everywhere else but a bit tight at the fender lip (which is actually quite a way up due to the smaller diameter tire), but camber plates should take care of that.
Thanks, Terry |
02-06-2015, 03:32 PM | #3 |
Rep 20,742
Drives: 2021 911 turbo
Wouldn't that setup be rather smallish from a rolling diameter point of view (5.2% smaller than stock) ?
02-06-2015, 04:01 PM | #4 |
Rep 7,887
02-06-2015, 09:39 PM | #5 |
Rep 120
I would have preferred a 285/35 but couldn't find any in a brand that I could live with. The rears are 295/30 and same situation there as far as availability for a 35 cross section. A friend has 285/30X18 R888 and 315/30X18 R888 on the rear with CCW special made wheels for his M4. He seems very happy with the setup on the track. He is coming from an E90 track car. When APEX comes out with the 11" wheel for the back, I will go to 315/30 in the rear.
Any thoughts on the clearance issue?? Terry |
02-06-2015, 09:43 PM | #6 |
Rep 3,381
Less than an eighth inch clearance is a pretty small margin.
If it were me, I certainly wouldn't feel comfortable with that.
2019 Ruby GT350 - Gen 5 Whipple on corn making 855RWHP.
Sold: 2018 F80 Part Deux /DCT /YMB /Full SS /CF Trim /ZCP /ZEC w/Black 666M Sold: 2015 F80 /DCT /YMB /Full SS /CF Trim /ZEC /ZLP /HK /S&TVC- 18''///M |
02-11-2015, 11:42 AM | #7 |
Rep 390
I've run with 1/8th - 1/16th inch of clearance between the tire and the strut, and never had a problem at the track as far as inner sidewall of the tire deforming and making contact with the strut. You could always run a larger spacer if it ever becomes an issue, but I would rather change the wheels to a different offset.
02-11-2015, 01:27 PM | #9 |
Rep 120
Thanks for the input. I think I'll try it at the track and check after first run for rubbing. I've already ordered a combo of spacers and bolts if I need to go out any further. But I can return them if I don't open them.
Terry
04-14-2015, 09:37 PM | #11 |
Rep 1,789
Drives: wife crazy
Garage List 2019 Ford Raptor [0.00]
2016 Porsche 991.1 ... [0.00] 1987 Chevy Camaro I ... [0.00] 1972 Chevy Corvette [0.00] 1999 BMW M3 race car [0.00] |
Road course laptimes for BMW M4 2015 6MT
WHP East Track: 1:04.880, Arizona Motorsports Park: 1:54.352 Road course laptimes for Porsche 911 991.1 GTS 7MT WHP East Track: 1:02.770, Arizona Motorsports Park: 1:48.889 |
04-14-2015, 10:19 PM | #12 | |
Rep 146
04-15-2015, 02:08 AM | #13 | |
Rep 269
04-15-2015, 08:45 PM | #14 |
Rep 3,834
If possible, I would use 275/35/18. 285 will not clear after market suspension.
As for camber, TC Kline offers just camber plates for our cars now.
Daily: G12 750 MSPORT Weekend Car: E90 M3
04-29-2015, 04:16 PM | #15 |
Rep 120
I forgot to pass on my experience with Hoosiers 285/30X18 and 295/30X18 at Spring Mountain. No rubbing at the struts with only about 3/32" clearance. No rubbing anywhere else as well, front or rear. I might try the 295/30X18 on the front but I'll probably wait to see how the 285's do after the camber plates go in.
Terry
05-01-2015, 10:29 AM | #16 |
Rep 3,834
Our cars don't have issues with under steer. There's no need to run anything larger than 275 front. You really can't tell the difference between 275 and 285. I'd run 275/35/18 all around. If you want staggered, then go 275/35/18 front and 295/35/18 rear.
09-17-2015, 07:42 PM | #17 |
Rep 1,338
09-18-2015, 07:35 AM | #18 |
Rep 68
Issue you may not thought of
18 inch tires in a 30 series do not have a load rating to carry the forces the Mcars produce. Weight yes but not weight + lateral G's + HP combo. Even those hoosier slicks are for a lighter car. You'll need a 35 series to be safe running at high speed corning. Main issue is the higher RPM's the smaller tire turns creates heat and you don't want excess heat in a tire with load on it. Take some time a pick the right tire combo.
14' Porsche 991 C4S
2015 F-250 Platinum PAST 2015 - M4 2010 997.2 GT3 / 2009 IS-F / 00' S2K / 2013 F-250 |
09-26-2015, 12:07 AM | #19 |
Rep 120
Yes the EC-7 et43 clears the front and rear iron brake calipers. No spacer in the back but I now run an 18mm spacer in the front. No rubbing problems anywhere but my tires are 285/30X18 front and 295/30X18 rear.
09-26-2015, 12:13 AM | #20 | |
Rep 120
09-27-2015, 08:49 PM | #21 |
Sameet
740
Rep 2,541
Drives: AY/B M4 '15
Probably a little late but I would not put on straight slicks for this car.
1. You will break an axle unless they are upgraded 2. Assuming you have a DCT, being able to do a proper burnout on this car is VERY difficult and you will not be able to get the slicks to their proper operating temp to hook I would get drag radials instead aka Mickey Tompsons ET Streets |
09-27-2015, 09:59 PM | #22 |
Rep 120
This is a track car and doesn't ever go to the drags. My setup is great for the track as confirmed by one of the PCA instructors who drove it for several laps at Miller Mototsport Park. It is a DCT.
