European Auto Source (EAS)
Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Technical Topics > Track / Autocross / Dragstrip / Driving Techniques
      02-10-2015, 06:41 PM   #1
Flying Low
Drives: 2002 M3, 2003 M3, 2015 M4
KMAC Stage 2 camber plates
Has anyone tried or know of any one that has tried the KMAC camber plates (Turner Motorsports) on the new M3 or M4 with the standard or adaptive suspension? From the pictures on the TMS site, I don't see how it could possibly tie into the big aluminum brace that stiffens the whole tower area.
Thanks,
Terry
      02-10-2015, 09:45 PM   #2
Flying Low
Test
      02-11-2015, 10:20 AM   #3
heckyeahbro69
heckyeahbro69's Avatar
518
Drives: m3
I have them sitting on my toolbox. One of these days I'll get them on the car. I was waiting to see if swift springs would ever hit the market so I could just do it all at once. I'm looking at them and wondering the same thing you are. I'll post some pics of the install process.
      02-11-2015, 10:23 AM   #4
MaynardZed
MaynardZed's Avatar
Drives: wife crazy
Says its for passive suspension only and "some fabrication may be required"?
Keep us posted, looks like a PITA job though.
Road course laptimes for BMW M4 2015 6MT
WHP East Track: 1:04.880, Arizona Motorsports Park: 1:54.352
Road course laptimes for Porsche 911 991.1 GTS 7MT
WHP East Track: 1:02.770, Arizona Motorsports Park: 1:48.889
      02-11-2015, 10:54 AM   #5
Flying Low
HeckYeahBro,
Check to see if the top plate of your KMAC has three extra holes on a smaller diameter circle than the outer perimeter holes that mount to the strut tower itself. These extra holes would be needed to screw the big odd shaped aluminum support bracket into. This bracket is obvious when you take the plastic covering off this area.
I'm guessing you don't have these extra holes. I've been talking to KMAC directly in Australia and they seemed not to know of the need for these support bracket mounting points. I think they just assumed that their F30 camber plates would work, but the F30 doesn't have the extra aluminum support bracket.
Terry
      02-11-2015, 11:04 AM   #6
Flying Low
MaynardZed,
How did your R888's hold up without the camber plates? Looks like my first track day, at Spring Mountain, will have to be without camber plates. I have 285 and 295 Hoosiers on 18X10 wheels. I hope I won't ruin them.
Terry
      02-11-2015, 02:38 PM   #7
heckyeahbro69
518
Drives: m3
I just looked at the camber plates, and a car in the showroom and there is no way these will bolt up. They are missing the inner 3 mounts for the strut brace.
      02-11-2015, 03:42 PM   #8
MasterC17
Drives: 2015 BMW M3
Not at all surprised, was thinking they wouldn't work without fabrication. When oh when is someone going to come out with camber plates that will fit!?
2009 X5d | 2007 E90 Track | 2002 M3 Track | 1991 535i Track
      02-11-2015, 05:54 PM   #9
heckyeahbro69
518
Drives: m3
I figured I'd take the gamble and order them. Turner sent me a return label asap so no big deal. Great customer support over there. I should of known right away they didn't when the box said fits "F81" lol
      02-11-2015, 07:58 PM   #10
MaynardZed
MaynardZed's Avatar
Drives: wife crazy
Originally Posted by lo flyn View Post
MaynardZed,
Terry
Holding up surprisingly well. Have about 18 heat cycles and around 2000 street miles on them. Still some tread left, although front left is getting close to gone. Shoulders/walls are very stiff and have not rolled over too bad. I shoot for 34-36 psi hot which is about 26-28 cold.
Hoosiers also have a stiff wall so they'll work too. Depends what you like. I must say I've been using the new R7 on my E36 and have been very impressed. Have around 20 heat cycles and haven't noticed much drop off yet. Got to get them hot for them to stick good, around 3 laps but can stay out the whole session without them getting greasy.
      02-11-2015, 11:36 PM   #11
Flying Low
I talked to TC Kline about his youtube videos and his coilover suspension. He used Hoosier 275 square and he said that after about 7 laps the rear would get hot and greasy. At the front he had 3.5 degrees of camber and that the M4 loves lots of camber. TC is coming out with camber plates for passive suspension very soon but I'm not sure if they will work on adaptive.
Terry
      02-12-2015, 08:20 AM   #12
MaynardZed
MaynardZed's Avatar
Drives: wife crazy
Terry
I like his setup and would be leaning towards his CoilOvers if I was purchasing today. Doesn't surprise my about the rears, challenging getting the power down on corner exit. Car needs a softer rear sway bar, or maybe just remove it if using stiffer CO springs. Has worked on previous gen M cars.
f80post
